Not sure if this matters, but here is the dmesg output.
[root@esxi04:/opt/mellanox/bin] dmesg |grep mlx
VMB: 323: name: /nmlx4_co.v00
VMB: 323: name: /nmlx4_en.v00
VMB: 323: name: /nmlx4_rd.v00
VMB: 323: name: /nmlx5_co.v00
VMB: 323: name: /nmlx5_rd.v00
VMB: 323: name: /net_mlx4.v00
VMB: 323: name: /net_mlx4.v01
2020-01-14T19:45:20.902Z cpu0:65536)VisorFSTar: 1982: nmlx4_co.v00 for 0xb5980 bytes
2020-01-14T19:45:20.904Z cpu0:65536)VisorFSTar: 1982: nmlx4_en.v00 for 0xbcd08 bytes
2020-01-14T19:45:20.906Z cpu0:65536)VisorFSTar: 1982: nmlx4_rd.v00 for 0x51ca0 bytes
2020-01-14T19:45:20.907Z cpu0:65536)VisorFSTar: 1982: nmlx5_co.v00 for 0x16e920 bytes
2020-01-14T19:45:20.911Z cpu0:65536)VisorFSTar: 1982: nmlx5_rd.v00 for 0x3f928 bytes
2020-01-14T19:45:21.307Z cpu0:65536)VisorFSTar: 1982: net_mlx4.v00 for 0x57e88 bytes
2020-01-14T19:45:21.308Z cpu0:65536)VisorFSTar: 1982: net_mlx4.v01 for 0x3b10a bytes
2020-01-14T19:45:32.360Z cpu2:66047)Loading module nmlx4_core …
2020-01-14T19:45:32.362Z cpu2:66047)Elf: 2043: module nmlx4_core has license BSD
2020-01-14T19:45:32.376Z cpu2:66047)<NMLX_INF> nmlx4_core: init_module called
2020-01-14T19:45:32.376Z cpu2:66047)Device: 191: Registered driver ‘nmlx4_core’ from 23
2020-01-14T19:45:32.376Z cpu2:66047)Mod: 4972: Initialization of nmlx4_core succeeded with module ID 23.
2020-01-14T19:45:32.376Z cpu2:66047)nmlx4_core loaded successfully.
2020-01-14T19:45:32.385Z cpu0:65975)<NMLX_INF> nmlx4_core: 0000:06:00.0: nmlx4_core_Attach - (partners/mlnx/nmlx4/nmlx4_core/nmlx4_core_main.c:2476) running
2020-01-14T19:45:32.385Z cpu0:65975)DMA: 646: DMA Engine ‘nmlx4_core’ created using mapper ‘DMANull’.
2020-01-14T19:45:41.235Z cpu0:65975)<NMLX_INF> nmlx4_core: 0000:06:00.0: nmlx4_CmdQueryDevCap - (partners/mlnx/nmlx4/nmlx4_core/nmlx4_core_fw.c:391) Device supports DMFS
2020-01-14T19:45:41.235Z cpu0:65975)<NMLX_ERR> nmlx4_core: 0000:06:00.0: nmlx4_FillDevCap - (partners/mlnx/nmlx4/nmlx4_core/nmlx4_core_main.c:954) HCA’s port number 1 has not supported port type IB, aborting.
2020-01-14T19:45:41.235Z cpu0:65975)<NMLX_ERR> nmlx4_core: 0000:06:00.0: nmlx4_HcaInit - (partners/mlnx/nmlx4/nmlx4_core/nmlx4_core_main.c:1541) nmlx4_FillDevCap failed: Not supported
2020-01-14T19:45:41.235Z cpu0:65975)<NMLX_ERR> nmlx4_core: 0000:06:00.0: nmlx4_core_Attach - (partners/mlnx/nmlx4/nmlx4_core/nmlx4_core_main.c:2580) nmlx4_HcaInit failed: Not supported
2020-01-14T19:45:42.235Z cpu0:65975)DMA: 691: DMA Engine ‘nmlx4_core’ destroyed.
2020-01-14T19:45:45.766Z cpu3:66127)Loading module mlx4_core …
2020-01-14T19:45:45.775Z cpu3:66127)Elf: 2043: module mlx4_core has license GPL
2020-01-14T19:45:45.781Z cpu3:66127)module heap vmklnx_mlx4_core: Initial heap size = 16384, max heap size = 539607040
2020-01-14T19:45:45.781Z cpu3:66127)module mempool vmklnx_mlx4_core_skb: creation succeeded. initial size = 524288, max size = 23068672
2020-01-14T19:45:45.781Z cpu3:66127)module heap vmklnx_mlx4_core: using memType 2
2020-01-14T19:45:45.781Z cpu3:66127)module heap vmklnx_mlx4_core: creation succeeded. id = 0x43061488c000
2020-01-14T19:45:45.781Z cpu3:66127)PCI: driver mlx4_core is looking for devices
<6>mlx4_core: Mellanox ConnectX core driver v1.9.7.0 (Dec-03-2012)
2020-01-14T19:45:45.781Z cpu3:66127)<6>mlx4_core: Initializing 0000:06:00.0
2020-01-14T19:45:51.989Z cpu0:66127)<6>mlx4_core 0000:06:00.0: port=1 IB MTU=2048
2020-01-14T19:45:51.989Z cpu0:66127)<6>mlx4_core 0000:06:00.0: port=2 IB MTU=2048
2020-01-14T19:45:51.989Z cpu0:66127)PCI: driver mlx4_core claimed device 0000:06:00.0
2020-01-14T19:45:51.989Z cpu0:66127)PCI: driver mlx4_core claimed 1 device
2020-01-14T19:45:51.989Z cpu0:66127)Mod: 4972: Initialization of mlx4_core succeeded with module ID 4129.
2020-01-14T19:45:51.989Z cpu0:66127)mlx4_core loaded successfully.
2020-01-14T19:45:54.536Z cpu0:65938)Activating Jumpstart plugin mlx4_en.
2020-01-14T19:45:54.559Z cpu12:66272)Loading module mlx4_en …
2020-01-14T19:45:54.561Z cpu12:66272)Elf: 2043: module mlx4_en has license GPL
2020-01-14T19:45:54.565Z cpu12:66272)module heap vmklnx_mlx4_en: Initial heap size = 16384, max heap size = 4833280
2020-01-14T19:45:54.565Z cpu12:66272)module mempool vmklnx_mlx4_en_skb: creation succeeded. initial size = 524288, max size = 23068672
2020-01-14T19:45:54.565Z cpu12:66272)module heap vmklnx_mlx4_en: using memType 2
2020-01-14T19:45:54.565Z cpu12:66272)module heap vmklnx_mlx4_en: creation succeeded. id = 0x4305e5f09000
<6>mlx4_en: Mellanox ConnectX HCA Ethernet driver v1.9.7.0 (Dec-03-2012)
2020-01-14T19:45:54.565Z cpu12:66272)Mod: 4972: Initialization of mlx4_en succeeded with module ID 4154.
2020-01-14T19:45:54.565Z cpu12:66272)mlx4_en loaded successfully.
2020-01-14T19:45:54.571Z cpu4:65938)Jumpstart plugin mlx4_en activated.
