Hi karen
thanks for feedback !
just installed MFT and MST (mft-4.6.0.48-10EM-600.0.0.2494585.x86_64.vib and net-mst_4.6.0.48-1OEM.600.0.0.2494585.vib)
Installation Result
Message: The update completed successfully, but the system needs to be rebooted for the changes to be effective.
Reboot Required: true
VIBs Installed: Mellanox_bootbank_mft_4.6.0.48-0
Installation Result
VIBs Installed: MEL_bootbank_net-mst_4.6.0.48-1OEM.600.0.0.2494585
but got some issue when using mst; it says mst is loaded but when issuing “mst status” it says it is not running ?
adapter is present and running, see below:
start mst by
[esxi-02:~] /opt/mellanox/bin/mst start
Module mst loaded successfully
[esxi-02:~] /opt/mellanox/bin/mst status -v
No MST devices were found or MST modules are not loaded.
You may need to run ‘mst start’ to load MST modules.
Module mst is already loaded
[esxi-02:~] lspci | grep Mellanox
0000:01:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3] [vmnic2]
[esxi-02:~] esxcli software vib list | grep Mellanox
mft 4.6.0.48-0 Mellanox PartnerSupported 2017-05-21
[esxi-02:~] esxcli system module list | grep mlx4
nmlx4_core true true
nmlx4_en true true
nmlx4_rdma true true
