Running driver version: 396.24
OS: pop-os 18.04 (Ubuntu 18.04 with Nvidia drivers by System76)
X Server version: 11.0
X Server vendor version: 1.19.6 (11906000)
NV-CONTROL Version: 1.29
Resolution: 3840x2160
CPU: core i7 8th gen 6 core
Memory: 32GB
Laptop model: Oryx Pro - System76 (new)
When I start the laptop the video card fans produce a constant noise which does not stop after the laptop has booted and is idle (GPU fan speed 4823 according to sensors) and the laptop heats up. When I open a webpage in chrome or firefox, scrolling stutters. It does not go smooth at all, I can even see a refresh line in the middle of my screen. When I move a window, the I can also see a refresh line at the windowâs edges.
When I start some development work using Intellij IDEA, the fans start spinning louder and heat increases dramatically as well. Iâve also tried to use a 1920x1080 resolution, but the same happens.
When I switch to the Intel onboard graphics, the laptop is silent and graphics performance increases.
Iâve tried contacting System76 and they donât seem to have a solution.
I donât know what settings I could try.
Any tips? Thanks! :)
hestersco@pop-os:~ $ nvidia-smi
Sat Sep 15 18:44:29 2018
| NVIDIA-SMI 396.24 Driver Version: 396.24 |
| 0 GeForce GTX 107... Off | 00000000:01:00.0 Off | N/A |
| N/A 56C P0 41W / N/A | 1185MiB / 8119MiB | 11% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2289 G /usr/lib/xorg/Xorg 665MiB |
| 0 2447 G /usr/bin/gnome-shell 330MiB |
| 0 2929 G ...-token=30A8EBE621B4C6709CC029AEEE6A741F 81MiB |
| 0 3862 G /usr/bin/nvidia-settings 2MiB |
| 0 6125 G /usr/lib/firefox/firefox 2MiB |
| 0 6401 G /usr/lib/firefox/firefox 2MiB |
| 0 7727 G /usr/lib/firefox/firefox 2MiB |
| 0 8313 G ...quest-channel-token=5488405317577830755 97MiB |
nvidia-bug-report.log.gz (183 KB)
