Just wondering if anyone has been able to run the Nvidia beta driver (396.18) with KDE - I need to use it to run the new Tomb raider game…
I have used the ubuntu PPA (OS is KDE neon) and got the 396.18.02 driver, I was previously on the 390.48 driver, which worked (as have all previous versions I have tried over the last 18 odd months of having Neon installed)
When I use 396.18.02 the desktop breaks as soon as X loads, I am unable to see anything expect random squares and lines, sort of like a commodore 64 loading screen, I am unable to go to a TTY also (as it looks the same).
That looks rather like a complete hardware incompatibility with the R396 driver, it’s exploding right on driver init. So no sddm/KDE issue imho. Unfortunately, due to the rminit message flood the dmesg output is not very helpful. Maybe just try a later kernel?
I has worked with every driver series I have used since I bought the card 1 year ago (I have always run the latest via PPA (and latest in Arch Linux) - it works fine for example with 390.48 - I can go to single/rescue mode and remove the 396 driver and replace with 390.
BTW when you say is the R390 driver, Do you just mean the nvidia binary driver 390.x series ?
R390=release 390, just any 390.x driver version.
A different thought: This should be a PNY branded card, is that the case? Or did you buy it recently for small money? Does it have a VGA connector? Then it’s a fake, a reflashed Fermi which doesn’t work any more with driver 396.
Unfortunately I am affected by this error too :(
Same card (PNY GTX 1060/6GB). Driver version 396.24 does not fix the problem. I get the same kernel error messages and scrambled screen like shown above.
And I am also affected by the driver issues with the Windows 397.31 driver [1].
I’m running Kubuntu 18.04 with Kernel 4.16.7 atm. But the problem existed with (K)Ubuntu 17.10/kernel 4.13 as well. Luckily I could revert back to 390.48 by booting into “recovery mode” and installing the old driver from the text console. So the problems only start once the X server is started.
Is this issue specific to 1060 6GB PNY and Palit boards? Please attach nvidia bug report who has not attached. We are tracking this issue under Bug 200411026
i have a 1060 gtx from palit on manjaro. After the update to 396.24 the system boots to black screen.
The 390 driver has no problems. The attached bugreport is generated on 4.14 kernel + nvidia 390 driver. (maybe not very usefull)
in the systemd log:
Mai 09 12:49:51 dellas-pc kernel: NVRM: RmInitAdapter failed! (0x53:0xffff:1957)
Mai 09 12:49:51 dellas-pc kernel: BUG: unable to handle kernel paging request at 0000000000001fa8
Mai 09 12:49:51 dellas-pc kernel: IP: nv010416rm+0x30/0x1a0 [nvidia]
Mai 09 12:49:51 dellas-pc kernel: NVRM: rm_init_adapter failed for device bearing minor number 0
Mai 09 12:49:51 dellas-pc kernel: PGD 0 P4D 0
Mai 09 12:49:51 dellas-pc kernel: Oops: 0000 [#1] PREEMPT SMP PTI
Mai 09 12:49:51 dellas-pc kernel: Modules linked in: nct6775 hwmon_vid msr nls_iso8859_1 nls_cp437 vfat fat f2fs eeepc_wmi asus_wmi iTCO_wdt iTCO_vendor_support sparse_keymap rfkill wmi_bmof ppdev snd_hda_codec_hdmi intel_rapl x86_pkg>
Mai 09 12:49:51 dellas-pc kernel: nvidia_modeset(PO) drm_kms_helper drm agpgart syscopyarea sysfillrect sysimgblt fb_sys_fops nvidia(PO) ipmi_devintf ipmi_msghandler vboxpci(O) vboxnetflt(O) vboxnetadp(O) vboxdrv(O) sg crypto_user ip_>
Mai 09 12:49:51 dellas-pc kernel: CPU: 2 PID: 422 Comm: kworker/2:3 Tainted: P O 4.16.7-1-MANJARO #1
Mai 09 12:49:51 dellas-pc kernel: Hardware name: System manufacturer System Product Name/P8H77-M PRO, BIOS 1505 10/17/2014
Mai 09 12:49:51 dellas-pc kernel: Workqueue: events os_execute_work_item [nvidia]
Mai 09 12:49:51 dellas-pc kernel: RIP: 0010:_nv010416rm+0x30/0x1a0 [nvidia]
Mai 09 12:49:51 dellas-pc kernel: RSP: 0018:ffff907f4182bd88 EFLAGS: 00010246
Mai 09 12:49:51 dellas-pc kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000001
Mai 09 12:49:51 dellas-pc kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8c5d62448008
Mai 09 12:49:51 dellas-pc kernel: RBP: ffff8c5d58bbdff8 R08: 00000006afd45400 R09: 0000000000000087
Mai 09 12:49:51 dellas-pc kernel: R10: ffff907f4182bd38 R11: 000000000032dcd5 R12: ffff8c5d4af8cfc8
Mai 09 12:49:51 dellas-pc kernel: R13: 0000000000000000 R14: ffff8c5d45222c88 R15: ffff8c5d6fb21180
Mai 09 12:49:51 dellas-pc kernel: FS: 0000000000000000(0000) GS:ffff8c5d6fb00000(0000) knlGS:0000000000000000
Mai 09 12:49:51 dellas-pc kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 09 12:49:51 dellas-pc kernel: CR2: 0000000000001fa8 CR3: 000000008100a006 CR4: 00000000001606e0
Mai 09 12:49:51 dellas-pc kernel: Call Trace:
Mai 09 12:49:51 dellas-pc kernel: ? _nv001065rm+0x84/0xe0 [nvidia]
Mai 09 12:49:51 dellas-pc kernel: ? rm_execute_work_item+0x49/0xc0 [nvidia]
Mai 09 12:49:51 dellas-pc kernel: ? kmem_cache_alloc+0x41/0x1b0
Mai 09 12:49:51 dellas-pc kernel: ? os_execute_work_item+0x40/0x60 [nvidia]
Mai 09 12:49:51 dellas-pc kernel: ? process_one_work+0x1ce/0x3f0
Mai 09 12:49:51 dellas-pc kernel: ? worker_thread+0x2b/0x3d0
Mai 09 12:49:51 dellas-pc kernel: ? process_one_work+0x3f0/0x3f0
Mai 09 12:49:51 dellas-pc kernel: ? kthread+0x113/0x130
Mai 09 12:49:51 dellas-pc kernel: ? kthread_create_on_node+0x70/0x70
Mai 09 12:49:51 dellas-pc kernel: ? ret_from_fork+0x35/0x40
Mai 09 12:49:51 dellas-pc kernel: Code: 89 f4 53 48 83 ed 08 89 fb e8 8d 11 00 00 85 c0 0f 85 0d 01 00 00 48 8b 05 ce 9d bb 00 89 de 45 31 ed 48 89 c7 ff 90 88 01 00 00 <48> 8b b0 a8 1f 00 00 48 89 c7 48 89 c3 e8 ae 4c 2c 00 48 85 c0
Mai 09 12:49:51 dellas-pc kernel: RIP: _nv010416rm+0x30/0x1a0 [nvidia] RSP: ffff907f4182bd88
Mai 09 12:49:51 dellas-pc kernel: —[ end trace aae1ba5b0b111201 ]— nvidia-bug-report.log.gz (122 KB)
