I created an additional thread here (sorry, I didn’t identify this one as the same problem):
https://devtalk.nvidia.com/default/topic/1033811/linux/linux-driver-390-works-396-doesn-t/
In short:
same problem on Palit GTX 1060 6GB
independent of the screen (tried two brands/models)
independent of the connection (tried HDMI, DP, DVI)
independent of the OS/kernel (tried Ubuntu 16.04 [kernel 4.13], and a fresh 18.04 [kernel 4.15])
works perfectly fine with 390.48
does not work with 396.24 (the "corrupt" screen on a Philips, a black screen on a Dell)
I’ll attach the nvidia-bug-report.log
(Note: it seems to contain both information from the 390 and the 396 boots).
nvidia-bug-report.log.gz (88.4 KB)
Not warcraft99, but maybe this helps, too (see my post above).
Find attached a nvidia-bug-report.log from the moment the screen is corrupt (Imgur: The magic of the Internet ) with the 396.24 driver, triggered via remote SSH.
If I can help otherwise, please let me know.
nvidia-bug-report.log.gz (62.3 KB)
s3rg3i
May 10, 2018, 11:32am
23
Same here with a 1060 6GB from PNY and 396.24 driver, attached bug report is from the 396.24 driver.
==============NVSMI LOG==============
Timestamp : Thu May 10 13:26:40 2018
Driver Version : 390.48
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : GeForce GTX 1060 6GB
Product Brand : GeForce
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-b568f809-70eb-c126-ba02-e53752e6c75e
Minor Number : 0
VBIOS Version : 86.06.0E.00.71
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.03
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x1C0310DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x119F196E
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 5000 KB/s
Rx Throughput : 0 KB/s
Fan Speed : 25 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 6077 MiB
Used : 214 MiB
Free : 5863 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 6 MiB
Free : 250 MiB
Compute Mode : Default
Utilization
Gpu : 17 %
Memory : 13 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 30 C
GPU Shutdown Temp : 102 C
GPU Slowdown Temp : 99 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 7.45 W
Power Limit : 120.00 W
Default Power Limit : 120.00 W
Enforced Power Limit : 120.00 W
Min Power Limit : 60.00 W
Max Power Limit : 140.00 W
Clocks
Graphics : 139 MHz
SM : 139 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
nvidia-bug-report.log.gz (58.1 KB)
I can confirm that I have the same issue with my PNY GTX 1060 (6GB) on driver 396.24. Unfortunately I’m unable to provide a bug report because installing the driver makes my system unusable, and I don’t have another system to SSH into the problem system.
I can confirm that the problem exists for both Fedora 28 and Ubutnu 18.04, using pre-packaged versions of the driver and the .run (official Nvidia drivers).
I also have the issue with my GTX 1060 (3GB) model(so it can’t be 6GB specific) and the 396 drivers. The 390 driver works fine currently. As above, I cannot produce a bug report due to it breaking my system and not having another to SSH into it with. OS Ubuntu 18.04
I have recently written another post about it so I am among others who have problems with 396.24 driver.
I can confirm the issue also.
Board: Gainward GeForce GTX 1060 6GB Phoenix
Operating System: Linux 4.16.8-1-ARCH
Driver Version: 396.24
nvidia-bug-report.log.gz (58.2 KB)
We have fixed this issue and the fix will be available in upcoming driver release …
That is great news - thank you.
Don’t suppose you have a rough ETA of the release?
And will it be in the next 396.x driver ?
_Mark
May 14, 2018, 4:32pm
30
That is nice, when you come back from vacation and the troubles have magically been fixed :)
I can confirm driver version 396.18.11 working with my PNY 1060/6GB.
That’s fantastic news! Thanks for the update. Really looking forward to the next release, for now I’ll stick with 390.48.
Thanks very much for the quick response and the fix! That’s not what I’m used to as a Linux user with a rare problem :-)
Is there a rough estimation when a driver including this fix will be available? Are we talking days, weeks, months? Can’t wait to try out DXVK …
Has the fix gone out in the latest 396 release?
https://developer.nvidia.com/vulkan-driver - May 24th, 396.24
I only ask, because I don’t see it listed in the release notes
Thanks,
No, 396.24 is from april and doesn’t contain a fix for that. 396.24.02 just contains vulkan updates, no further fixes.
Is there an ETA of when I can expect a 396.x driver I can with Palit 1060’s ?
dleone
May 25, 2018, 10:04pm
36
Did you actually test with 396.24.02? I would expect the bug to be fixed there.
No, I was deducting this from previous micro releases and info regarding those. So this is fixed in 396.24.02? Nice info, thank you.
_Mark
May 26, 2018, 6:26am
38
Vulkan Beta Driver Version 396.24.02 works just fine on my PNY GTX1060/6G. So yes, the problem discussed in this thread is still fixed ;-)
The R396 is a short live branch. We are not looking for any further R396 releases at this time. We suggest please stay on R390[Long Live Branch] drivers for now. The next LLB and SLB branch will have a fix for this issue.
Is there an ETA for the next LLB or SLB which will contain this fix? Effectively being stuck on 390 which isn’t supported by new games(rise of the tomb raider) or things like DXVK.
Thanks,
Alex
