I have been using the AGX Orin development board, running ubuntu 20.04. Everything was working fine, but now suddenly when I start the board there is no display signal in the DP port.
I am able to access the debug terminal through microusb, and I can see the ubuntu successfully loading. I am able to login successfully in terminal. In addition to display, I am also experiencing issue with wifi. I was using wifi earlier without any issues. Now all of a sudden the wifi interface is also not listing. We are using Drive OS 6.0.6
Could someone please assist me with these issues? Thank you in advance.
Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Dear @sooraj.ms,
Could you poweroff/on the target to see if it fixes the issue. Is it ok to reflash the target to see if the issue is caused due to system state?
Ofcourse we tried poweroff/on the board. Currently we are unable to reflash the hardware as we are not able to login to SDK manager (Not receiving the verification mail). If you could share any debugging steps we can try on hardware, It will really help us.
I am unable to login to NVIDIA account. I have tried from a different account as well.
I am not receiving the verification mail and the authorization token keeps getting expired.
Could you please help ?
Dear @sooraj.ms,
Could you share the screenshot pictures of login issue.
Did you try docker container method as Vick suggested? Firstly, were you able to login to NGC and see DRIVE OS docker?
Dear @sooraj.ms,
Just to confirm, could you check if you received NGC activation email in the past corresponding to your Devzone account? Are you able to login to Devzone(https://developer.nvidia.com/)?
Dear @sooraj.ms,
Firstly, are you able to login to NVIDIA Developer (aka DevZone) (https://developer.nvidia.com) ? If not, what is observed.
Just confirming, Did you sign into NGC (https://ngc/nvidia.com) with their NVIDIA Developer (aka DevZone) credentials?
We were able to flash Drive OS 6.0.8 version to the hardware.
But the WiFi is still not up. Could you please share the steps to bringup/enable WiFi in Drive AGX Orin dev board.
Dear @sooraj.ms,
Wifi is not supported feature on DRIVE AGX Orin platform and hence not validated in DRIVE OS 6.0.8.1. Please use ethernet port to use internet.
