hello
i was adjusting the bitonic sort example from the cuda SDK to be able to process more items than 512. This works fine for arrays smaller than 32768 items but when i want to sort an array of 32768 items after like 5sec my screen goes black and windows vista restarts the driver :blink: .
Sorting 16384 items only takes about 6ms so it would surprise me if sorting 32768 items takes longer than 5sec.
so i’m wondering:
-is it normal that your screen goes black when your kernel takes long time to execute or does that mean a bug in code? I have a geforce 8600M GS (laptop)
-is there a way to make the time for resetting the device driver in windows vista longer?
my code:
#ifndef _BITONIC_KERNEL_H_
#define _BITONIC_KERNEL_H_
#define NUM 32768
__global__ static void bitonicSort(int * values)
unsigned int tid = threadIdx.x;
unsigned int inc = blockDim.x;
int a;
int b;
// Parallel bitonic sort.
for (unsigned int k = 2; k <= NUM; k *= 2)
// Bitonic merge:
for (unsigned int j = k / 2; j>0; j /= 2)
tid = threadIdx.x;
while(tid < NUM){
unsigned int ixj = tid ^ j; //address we need
if (ixj > tid) //no double swaps
a =values[tid];
b =values[ixj];
if ((tid & k) ==0) //check if we need asc/desc
if ( a > b)
values[tid]=b; //swap items
values[ixj]=a;
}else{
if (a < b)
values[ixj]=a;
tid +=inc;
__syncthreads();
#endif // _BITONIC_KERNEL_H_
kernel call:
bitonicSort<<<1, 512>>>(dvalues);
also get this error:
First-chance exception at 0x764b42eb in bitonic.exe: Microsoft C++ exception: cudaError_enum at memory location 0x0010fc54…
Tom
