Driver crashes during inactivity after updating to 570
Hi everyone.
Previously, I used the Nvidia 535.183.01 DKMS driver for a year without any issues. I used it with different kernels from 6.7.1 to 6.11.3. After updating to Linux 6.13.1, I found that the 535 DKMS driver didn’t work anymore, so I replaced it with a regular 570.86.16 driver. Hopefully, 570 has issues that forced me to stay on DKSM fixed, But there is a new critical issue.
There’s a 50% chance of a driver crash after 20-30 minutes of inactivity. Here are some fragments from the logs:
[ 9385.351175] NVRM: GPU at PCI:0000:01:00: GPU-b67c507a-2a6c-d7a3-0569-0afb634dcb7d
[ 9385.351179] NVRM: Xid (PCI:0000:01:00): 79, GPU has fallen off the bus.
[ 9385.351185] NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
[ 9385.351398] NVRM: A GPU crash dump has been created. If possible, please run
               NVRM: nvidia-bug-report.sh as root to collect this data before
               NVRM: the NVIDIA kernel module is unloaded.
[ 9385.351605] NVRM: Xid (PCI:0000:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (GPU Reset Required)
[ 9387.214173] traps: slack[2016] trap int3 ip:61bfc8edc7fe sp:7ffed3303db0 error:0 in slack[60537fe,61bfc4f31000+8996000]
[ 9387.591474] NVRM: Error in service of callback
[ 9392.500349] nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress: 0x0000c77d:0 2:0:4048:4040
Specs:
Laptop: Lenovo Legion Pro 7 16IRX8
GPU: RTX 4070 Laptop (AD106-B)
OS: Arch Linux
Kernel: 6.13.1l
Nvidia driver: 570.86.16
Display server: Xorg 21.1.15
Display manager: SDDM 0.21.0
nvidia-bug-report.log.gz (206.5 KB)
just brainstorming:
570 works pretty stable on other distros with a bit older kernels: how about trying 6.12.x? (it works pretty well for me on Debian-trixie with 570.86.15 and 535.216.03).
Good point @morgwai666, thank you. Trying it now.
Unfortunately, it still happens with Linux 6.12.12 and 6.12.13
I am experiencing the same problem. I am pretty sure the issue is SDDM, as using GDM I do not have this problem. I can also force it with SDDM by switching virtual terminals (ctrl+alt+F1/3), or unplugging the cable from the GPU and plugging it back in.
Going to VT3, I can restart SDDM service and I can get GUI again, but I lose my session ofc.
@jslay88 My case is a bit different. When the GPU driver crashes, I have a black screen (so ctrl+alt+f* doesn’t work) and loud fan noise. But the system isn’t frozen completely, according to logs. I have no issue pressing ctrl+alt+f* and re-plugging the monitor in normal mode.
Recently made updates on the nvidia driver 570. I think PopOS couldn’t shut them down properly and was looping through an error: “Waiting for process: Xorg”.
Here is My OS info and need help.
NAME=“Pop!_OS”
VERSION=“22.04 LTS”
ID=pop
ID_LIKE=“ubuntu debian”
PRETTY_NAME=“Pop!_OS 22.04 LTS”
VERSION_ID=“22.04”
HOME_URL=“https://pop.system76.com
SUPPORT_URL=“https://support.system76.com
BUG_REPORT_URL=“GitHub · Where software is built
PRIVACY_POLICY_URL=“Privacy
VERSION_CODENAME=jammy
UBUNTU_CODENAME=jammy
LOGO=distributor-logo-pop-os
In the meantime I shut down the nvidia drivers until there is a fix: sudo system76-power graphics integrated
