Driver crashes early after boot (even in text mode) on laptop with RTX 4070
Hi!
I have a Dell G16 laptop with two GPUs: RTX 4070 and Intel GPU, but the latter is permanently disabled in the BIOS.
The problem is that the nvidia driver crashes shortly after the system boots. At the latest, this happens when GDM loads - I don’t even get the chance to log in.
In many cases, the crash also occurs in text mode before reaching the graphical environment and GDM.
The issue is reproducible every time.
I was unable to generate a report immediately after the crash, as the machine becomes completely unresponsive.
I have attached journals from crashed sessions separately.
Tested on Arch Linux
kernel 6.13.7-arch1-1
nvidia 570.124.04
journal.log.gz (196.3 KB)
nvidia-bug-report.log.gz (295.2 KB)
kernel: Call Trace:
kernel:  <TASK>
kernel:  ? __die_body.cold+0x19/0x27
kernel:  ? page_fault_oops+0x15c/0x2e0
kernel:  ? exc_page_fault+0x81/0x190
kernel:  ? asm_exc_page_fault+0x26/0x30
kernel:  ? _nv000825rm+0x1d/0x70 [nvidia c3111a6e950890130c8c68d21ede3ef9edd55ba7]
kernel:  ? _nv013256rm+0x3c/0x310 [nvidia c3111a6e950890130c8c68d21ede3ef9edd55ba7]
kernel:  _nv056282rm+0xd6/0x1a0 [nvidia c3111a6e950890130c8c68d21ede3ef9edd55ba7]
kernel:  ? refresh_cpu_vm_stats+0x1f0/0x240
kernel:  _nv000825rm+0x1d/0x70 [nvidia c3111a6e950890130c8c68d21ede3ef9edd55ba7]
kernel:  rm_acpi_notify+0xf1/0x280 [nvidia c3111a6e950890130c8c68d21ede3ef9edd55ba7]
kernel:  ? lock_timer_base+0x76/0xa0
kernel:  acpi_ev_notify_dispatch+0x4b/0x70
kernel:  acpi_os_execute_deferred+0x17/0x30
kernel:  process_one_work+0x17b/0x330
kernel:  worker_thread+0x2ce/0x3f0
kernel:  ? __pfx_worker_thread+0x10/0x10
kernel:  kthread+0xcf/0x100
kernel:  ? __pfx_kthread+0x10/0x10
kernel:  ret_from_fork+0x31/0x50
kernel:  ret_from_fork_asm+0x1a/0x30
I see the same call path (rm_acpi_notify+0xf1/0x280 from acpi_ev_notify_dispatch) on a GTX 960M laptop with 580.178.04 and kernel 6.8, crashing on every boot on battery. Since kernel 6.8, ACPI notify handlers can run in parallel on several CPUs, and the driver’s notify handler is not reentrant. Analysis and a tested workaround patch (a mutex in nv-acpi.c): 580.178.04: oops in rm_acpi_notify on kernel 6.8+ (ACPI notify handlers now run in parallel), crash on every boot on battery
