Driver / library mismatch with nvtop
When typing
nvtop
or
nvidia-smi
in a bash terminal, I get the following error:
Impossible to initialize nvidia nvml : Driver/library version mismatch.
So I am trying to uninstall the current cuda according to nvidia documentation (Installation Guide Linux :: CUDA Toolkit Documentation). The documentation says to run the following command
sudo dnf remove <package_name>
but I don’t know the package name. Is there a way to find it ?
I am running Fedora 28.
sudo dnf remove cuda
may be what you want
This assumes you used a package manager method to install it. If you used a runfile installer, the uninstall/removal process is different, but the documentation you linked covers that as well.
