Drivers installed, NVIDIA-SMI failed
Hardware: Dell G7 15.6" Laptop
GPU:
apollys@ApollysG7:~$ lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GP106M [GeForce GTX 1060 Mobile] (rev a1)
Installed NVIDIA drivers:
apollys@ApollysG7:~$ dpkg -l | grep -i nvidia
ii  libnvidia-cfg1-390:amd64                   390.48-0ubuntu3                     amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.48-0ubuntu3                     all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.48-0ubuntu3                     amd64        NVIDIA libcompute package
ii  libnvidia-compute-390:i386                 390.48-0ubuntu3                     i386         NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.48-0ubuntu3                     amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-390:i386                  390.48-0ubuntu3                     i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.48-0ubuntu3                     amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-390:i386                  390.48-0ubuntu3                     i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.48-0ubuntu3                     amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-390:i386                    390.48-0ubuntu3                     i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.48-0ubuntu3                     amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-390:i386                      390.48-0ubuntu3                     i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.48-0ubuntu3                     amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-390:i386                    390.48-0ubuntu3                     i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-390                   390.48-0ubuntu3                     amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.48-0ubuntu3                     amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.48-0ubuntu3                     amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.48-0ubuntu3                     amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.48-0ubuntu3                     amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8                               all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                            390.42-0ubuntu1                     amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-390                           390.48-0ubuntu3                     amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-nvidia-390              390.48-0ubuntu3                     amd64        NVIDIA binary Xorg driver
Unable to run nvidia-smi:
apollys@ApollysG7:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Any suggestions for what I can do to properly set up my drivers?
There’s not enough information here to diagnose
I suggest starting over with a clean install of the linux OS, then read the CUDA linux install guide carefully, in its entirety, make sure you are compliant with it, then install.
installing on a notebook GPU can be particularly difficult, because the notebook GPU may be disabled by hardware/OS control. You may want to research nvidia-prime
Is CUDA compatible with Ubuntu 16.0.4.5 LTS? I noticed in the guide it said 16.0.4.4, but perhaps that’s not critical or simply hasn’t been updated.
It should be fine. I would expect no issues with CUDA itself, but installing the GPU driver may possibly be affected. If you have any trouble with GPU driver install associated with the CUDA toolkit itself, I suggest trying a newer driver.
If you install a newer driver, be sure to select “no” when prompted for driver install when installing the CUDA toolkit.
