Hello everyone, I have been facing issues with my NVIDIA driver and Cuda version. I have tried many things on the internet. However, nothing looks to help.
when I run:
$ nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
These are all the steps I have done in order to have a global understanding of what I am seeing.
$ sudo systemctl status nvidia-persistenced
[sudo] password for marvin:
● nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/lib/systemd/system/nvidia-persistenced.service; static; vendor preset: enabled)
Active: inactive (dead)
$ sudo systemctl enable nvidia-persistenced
The unit files have no installation config (WantedBy, RequiredBy, Also, Alias
settings in the [Install] section, and DefaultInstance for template units).
This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
- A unit may be statically enabled by being symlinked from another unit’s
.wants/ or .requires/ directory. - A unit’s purpose may be to act as a helper for some other unit which has
a requirement dependency on it. - A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, …). - In case of template units, the unit is meant to be enabled with some
instance name specified.
I am not able to use GPU in my computer (Precision 7730):
$ lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GP104GLM [Quadro P5200 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
uname -m && cat /etc/*release
x86_64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION=“Ubuntu 18.04.3 LTS”
NAME=“Ubuntu”
VERSION=“18.04.3 LTS (Bionic Beaver)”
$ gcc --version
gcc (Ubuntu 4.8.5-4ubuntu8) 4.8.5
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ sudo ./NVIDIA-Linux-x86_64-430.40.run
1.- The distribution-provided pre-install script failed! Are you sure you want to continue?
→ Continue installation
2.- Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later.
→ Yes
3.-
Install NVIDIA’s 32-bit compatibility libraries?
ERROR: Failed to run /usr/sbin/dkms build -m nvidia -v 430.40 -k 5.0.0-23-generic:
Kernel preparation unnecessary for this kernel. Skipping…
Building module:
cleaning build area...
'make' -j12 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=5.0.0-23-generic IGNORE_CC_MISMATCH='' modules...(bad
exit status: 2)
ERROR (dkms apport): binary package for nvidia: 430.40 not found
Error! Bad return status for module build on kernel: 5.0.0-23-generic (x86_64)
Consult /var/lib/dkms/nvidia/430.40/build/make.log for more information.
4.- ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information.
5.- ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
When I try to install sudo sh cuda_10.1.168_418.67_linux.run, I am having the following error:
[INFO]: /NVIDIA-Linux-x86_64-418.67/kernel/nvidia/nv_uvm_interface.o] Error 1
[INFO]: CC [M] /tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel/nvidia/linux_nvswitch.o
[INFO]: cc: error: unrecognized command line option ‘-fstack-protector-strong’
[INFO]: scripts/Makefile.build:284: recipe for target ‘/tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel/nvidia/nvlink_linux.o’ failed
[INFO]: make[2]: *** [/tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel/nvidia/nvlink_linux.o] Error 1
[INFO]: scripts/Makefile.build:284: recipe for target ‘/tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel/nvidia/linux_nvswitch.o’ failed
[INFO]: make[2]: *** [/tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel/nvidia/linux_nvswitch.o] Error 1
[INFO]: make[2]: Target ‘__build’ not remade because of errors.
[INFO]: Makefile:1606: recipe for target ‘module/tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel’ failed
[INFO]: make[1]: *** [module/tmp/selfgz30574/NVIDIA-Linux-x86_64-418.67/kernel] Error 2
[INFO]: make[1]: Target ‘modules’ not remade because of errors.
[INFO]: make[1]: Leaving directory ‘/usr/src/linux-headers-5.0.0-23-generic’
[INFO]: Makefile:81: recipe for target ‘modules’ failed
[INFO]: make: *** [modules] Error 2
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 418.67 failed, quitting
$ ubuntu-drivers list
nvidia-driver-410
nvidia-driver-390
nvidia-driver-415
nvidia-driver-430
Can anyone help me out how to fix it?
