I previously was using CUDA 10 and NVIDIA-410 for running 2080 ti. Everything was good.
Yesterday, when I started to run a experiment, it showed the problem that cuda was failed. After I type “nvidia-smi”, the error message came out:
“NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.”
Then I follow the steps to reinstall the cuda and the driver, but it does not work. I tried almost all the ways I can find online. None of them works.
My nvidia-bug-report is listed below:
https://drive.google.com/file/d/1WblwvXlK9G937hfD-gPvoblJKkrJv7FH/view?usp=sharing
Thank you very much!
