Hi, I have seen other questions like this unanswered
- kmscube failed to initialize EGL
- sample 08_video_decode don’t use EGL
I need EGL in DRM-KMS as in a cheaper raspberryPI … it’s possible?
If actually not… when?
I think it would work but just we don’t have such sample code. What is the problem for this “kmscube” fails to initialize EGL?
i’ve better investigate problem:
gbm_create_device fails using fd from drmOpen(“drm-nvdc”)
if i load tegra-udrm with: modprobe tegra-udrm modeset=1
gbm_create_device create correctly a device but this fail:
eglGetPlatformDisplayEXT(EGL_PLATFORM_GBM_KHR, gbm->dev, NULL)
some error on libraries symbolic links?
i’ve prepared a poc:
// gcc -o drm_gbm_egl main.cpp -ldrm -lgbm -lEGL -I/usr/include/libdrm -I/usr/include -I/usr/include/aarch64-linux-gnu -L/usr/lib/aarch64-linux-gnu -L/usr/lib/aarch64-linux-gnu/tegra
#include <errno.h>
#include <xf86drm.h>
#include <xf86drmMode.h>
#include <drm.h>
#include <gbm.h>
#include <EGL/egl.h>
#include <EGL/eglext.h>
#include <GL/gl.h>
#include <linux/kd.h>
#include <linux/vt.h>
#include <sys/ioctl.h>
#include <string.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <stdio.h>
#define EXIT(msg) { fputs(msg, stderr); exit(EXIT_FAILURE); }
static int device;
static uint32_t connector_id;
static drmModeModeInfo mode_info;
static drmModeCrtc* crtc;
static gbm_device* gbm_device;
static EGLDisplay display;
static EGLContext context;
static gbm_surface* gbm_surface;
static EGLSurface egl_surface;
static int console_fd = -1;
static int active_vt = -1;
#define _DRM_DEV "/dev/dri/card0" // "drm-nvdc"
static drmModeConnector* find_connector(drmModeRes* resources)
for (int i = 0; i < resources->count_connectors; i++)
drmModeConnector* connector = drmModeGetConnector(device, resources->connectors[i]);
if (connector->connection == DRM_MODE_CONNECTED)
return connector;
drmModeFreeConnector(connector);
return NULL;
static drmModeEncoder* find_encoder(drmModeRes* resources, drmModeConnector* connector)
if (connector->encoder_id)
return drmModeGetEncoder(device, connector->encoder_id);
return NULL;
static void find_display_configuration()
drmModeRes* resources = drmModeGetResources(device);
drmModeConnector* connector = find_connector(resources);
if (!connector)
EXIT("no connector found\n");
connector_id = connector->connector_id;
mode_info = connector->modes[0];
printf("resolution: %ix%i\n", mode_info.hdisplay, mode_info.vdisplay);
drmModeEncoder* encoder = find_encoder(resources, connector);
if (!encoder)
EXIT("no encoder found\n");
if (encoder->crtc_id)
crtc = drmModeGetCrtc(device, encoder->crtc_id);
drmModeFreeEncoder(encoder);
drmModeFreeResources(resources);
static void setup_gbmegl()
gbm_device = gbm_create_device(device);
// printf(eglQueryString(EGL_NO_DISPLAY, EGL_EXTENSIONS));
// HERE PROBLEMS
#define _USE_PLATFORMEXT
#ifdef _USE_PLATFORMEXT
PFNEGLGETPLATFORMDISPLAYEXTPROC eglGetPlatformDisplayEXT = (PFNEGLGETPLATFORMDISPLAYEXTPROC)eglGetProcAddress("eglGetPlatformDisplayEXT");
display = eglGetPlatformDisplayEXT(EGL_PLATFORM_GBM_KHR, gbm_device, NULL);
#else
display = eglGetDisplay((EGLNativeDisplayType)gbm_device);
//display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
#endif
if (display == NULL)
EXIT("display null... exiting\n");
EGLint major;
EGLint minor;
auto result = eglInitialize(display, &major, &minor);
EGLint attributes[] = {
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_NONE };
EGLConfig config;
EGLint num_config;
eglChooseConfig(display, attributes, &config, 1, &num_config);
context = eglCreateContext(display, config, EGL_NO_CONTEXT, NULL);
gbm_surface = gbm_surface_create(gbm_device, mode_info.hdisplay, mode_info.vdisplay,
GBM_BO_FORMAT_XRGB8888, GBM_BO_USE_SCANOUT | GBM_BO_USE_RENDERING);
egl_surface = eglCreateWindowSurface(display, config, gbm_surface, NULL);
eglMakeCurrent(display, egl_surface, egl_surface, context);
static void clean_up()
drmModeSetCrtc(device, crtc->crtc_id, crtc->buffer_id, crtc->x, crtc->y, &connector_id, 1, &crtc->mode);
drmModeFreeCrtc(crtc);
eglDestroySurface(display, egl_surface);
eglDestroyContext(display, context);
eglTerminate(display);
gbm_surface_destroy(gbm_surface);
gbm_device_destroy(gbm_device);
int main()
device = open(_DRM_DEV, O_RDWR);
find_display_configuration();
setup_gbmegl();
clean_up();
close(device);
return 0;
I am not familiar with gbm_device. Please try to use below node to get EGL display.
egl_dpy = eglGetPlatformDisplayEXT(EGL_PLATFORM_DEVICE_EXT, (void*)egl_dev, displayAttribs);
googling your code i’m landed on:
https://github.com/NVIDIA/cuda-samples/tree/master/Samples/simpleGLES_EGLOutput
and… it work!!
thank you wayne!!
if can help someone, this is my test code:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <unistd.h>
#include <GLES3/gl31.h>
#include "define.h"
#define MAX_DEVICES 16
#define _EXIT(str, n) {printf(str);exit(n);}
static PFNEGLQUERYDEVICESEXTPROC eglQueryDevicesEXT = NULL;
static PFNEGLQUERYDEVICESTRINGEXTPROC eglQueryDeviceStringEXT = NULL;
static PFNEGLGETPLATFORMDISPLAYEXTPROC eglGetPlatformDisplayEXT = NULL;
static PFNEGLGETOUTPUTLAYERSEXTPROC eglGetOutputLayersEXT = NULL;
static PFNEGLCREATESTREAMKHRPROC eglCreateStreamKHR = NULL;
static PFNEGLDESTROYSTREAMKHRPROC eglDestroyStreamKHR = NULL;
static PFNEGLSTREAMCONSUMEROUTPUTEXTPROC eglStreamConsumerOutputEXT = NULL;
static PFNEGLCREATESTREAMPRODUCERSURFACEKHRPROC eglCreateStreamProducerSurfaceKHR = NULL;
EGLDisplay eglDisplay = EGL_NO_DISPLAY;
EGLSurface eglSurface = EGL_NO_SURFACE;
EGLContext eglContext = EGL_NO_CONTEXT;
int plane = -1;
int xsurfsize = 0, ysurfsize = 0;
uint32_t drm_crtc_id, drm_plane_id;
// Extension checking utility
static bool CheckExtension(const char* exts, const char* ext)
int extLen = (int)strlen(ext);
const char* end = exts + strlen(exts);
while (exts < end) {
while (*exts == ' ')
exts++;
int n = strcspn(exts, " ");
if ((extLen == n) && (strncmp(ext, exts, n) == 0))
return true;
exts += n;
return false;
void load_func() {
// Load extension function pointers.
eglQueryDevicesEXT = (PFNEGLQUERYDEVICESEXTPROC)eglGetProcAddress("eglQueryDevicesEXT");
eglQueryDeviceStringEXT = (PFNEGLQUERYDEVICESTRINGEXTPROC)eglGetProcAddress("eglQueryDeviceStringEXT");
eglGetOutputLayersEXT = (PFNEGLGETOUTPUTLAYERSEXTPROC)eglGetProcAddress("eglGetOutputLayersEXT");
eglCreateStreamKHR = (PFNEGLCREATESTREAMKHRPROC)eglGetProcAddress("eglCreateStreamKHR");
eglDestroyStreamKHR = (PFNEGLDESTROYSTREAMKHRPROC)eglGetProcAddress("eglDestroyStreamKHR");
eglStreamConsumerOutputEXT = (PFNEGLSTREAMCONSUMEROUTPUTEXTPROC)eglGetProcAddress("eglStreamConsumerOutputEXT");
eglCreateStreamProducerSurfaceKHR = (PFNEGLCREATESTREAMPRODUCERSURFACEKHRPROC)eglGetProcAddress("eglCreateStreamProducerSurfaceKHR");
if (!eglQueryDevicesEXT ||
!eglQueryDeviceStringEXT ||
!eglGetPlatformDisplayEXT ||
!eglGetOutputLayersEXT ||
!eglCreateStreamKHR ||
!eglDestroyStreamKHR ||
!eglStreamConsumerOutputEXT ||
!eglCreateStreamProducerSurfaceKHR)
_EXIT("Missing required function(s)\n", 2);
printf("Loaded extension functions\n");
void graphics_set_drm(EGLDeviceEXT egl_dev) {
bool set_mode = false;
int crtc = -1;
int xoffset = 0, yoffset = 0;
int xmodesize = 0, ymodesize = 0;
int bounce = 0;
const char* drm_name;
int drm_fd;
uint32_t drm_conn_id, drm_enc_id;
uint32_t crtc_mask;
drmModeRes* drm_res_info = NULL;
drmModePlaneRes* drm_plane_res_info = NULL;
drmModeCrtc* drm_crtc_info = NULL;
drmModeConnector* drm_conn_info = NULL;
drmModeEncoder* drm_enc_info = NULL;
drmModePlane* drm_plane_info = NULL;
int drm_mode_index = 0;
// Obtain and open DRM device file
drm_name = eglQueryDeviceStringEXT(egl_dev, EGL_DRM_DEVICE_FILE_EXT);
if (!drm_name)
_EXIT("Couldn't obtain device file \n", 3);
drm_fd = drmOpen(drm_name, NULL);
if (drm_fd == -1)
_EXIT("Couldn't open device file", 3);
printf("Device file: %s\n", drm_name);
// Obtain DRM-KMS resources
drm_res_info = drmModeGetResources(drm_fd);
if (!drm_res_info)
_EXIT("Couldn't obtain DRM-KMS resources\n", 3);
printf("Obtained device information\n");
// If a specific crtc was requested, make sure it exists
if (crtc >= drm_res_info->count_crtcs)
_EXIT("Requested crtc index exceeds count\n", 4);
crtc_mask = (crtc >= 0) ? (1 << crtc) : ((1 << drm_res_info->count_crtcs) - 1);
// If drawing to a plane is requested, obtain the plane info
if (plane >= 0) {
drm_plane_res_info = drmModeGetPlaneResources(drm_fd);
if (!drm_plane_res_info)
_EXIT("Unable to obtain plane resource list\n", 5);
if (plane >= drm_plane_res_info->count_planes)
_EXIT("Requested plane index exceeds count \n", 5);
drm_plane_id = drm_plane_res_info->planes[plane];
drm_plane_info = drmModeGetPlane(drm_fd, drm_plane_id);
if (!drm_plane_info)
_EXIT("Unable to obtain info for plane\n", 5);
crtc_mask &= drm_plane_info->possible_crtcs;
if (!crtc_mask)
_EXIT("Requested crtc and plane not compatible\n", 5);
printf("Obtained plane information\n");
int conn = 0;
// Query info for requested connector
for (conn = 0; conn < drm_res_info->count_connectors; ++conn)
drm_conn_id = drm_res_info->connectors[conn];
drm_conn_info = drmModeGetConnector(drm_fd, drm_conn_id);
if (drm_conn_info != NULL)
printf("connector %d found\n", drm_conn_info->connector_id);
if (drm_conn_info->connection == DRM_MODE_CONNECTED && drm_conn_info->count_modes > 0)
break;
drmModeFreeConnector(drm_conn_info);
if (conn == drm_res_info->count_connectors)
_EXIT("No active connectors found\n", 6);
printf("Obtained connector information\n");
// If there is already an encoder attached to the connector, choose
// it unless not compatible with crtc/plane
drm_enc_id = drm_conn_info->encoder_id;
drm_enc_info = drmModeGetEncoder(drm_fd, drm_enc_id);
if (drm_enc_info) {
if (!(drm_enc_info->possible_crtcs & crtc_mask)) {
drmModeFreeEncoder(drm_enc_info);
// If we didn't have a suitable encoder, find one
if (!drm_enc_info) {
int i = 0;
for (i = 0; i < drm_conn_info->count_encoders; ++i) {
drm_enc_id = drm_conn_info->encoders[i];
if (drm_enc_info) {
if (crtc_mask & drm_enc_info->possible_crtcs) {
crtc_mask &= drm_enc_info->possible_crtcs;
break;
if (i == drm_conn_info->count_encoders)
_EXIT("Unable to find suitable encoder\n", 7);
printf("Obtained encoder information\n");
// Select a suitable crtc. Give preference to any that's already
// attached to the encoder. (Could make this more sophisticated
// by finding one not already bound to any other encoders. But
// this is just a basic test, so we don't really care that much.)
assert(crtc_mask);
for (int i = 0; i < drm_res_info->count_crtcs; ++i) {
if (crtc_mask & (1 << i)) {
drm_crtc_id = drm_res_info->crtcs[i];
if (drm_res_info->crtcs[i] == drm_enc_info->crtc_id) {
break;
// Query info for crtc
drm_crtc_info = drmModeGetCrtc(drm_fd, drm_crtc_id);
if (!drm_crtc_info)
_EXIT("Unable to obtain info for crtc\n", 4);
printf("Obtained crtc information\n");
// If dimensions are specified and not using a plane, find closest mode
if ((xmodesize || ymodesize) && (plane < 0)) {
// Find best fit among available modes
int best_index = 0;
int best_fit = 0x7fffffff;
for (int i = 0; i < drm_conn_info->count_modes; ++i) {
drmModeModeInfoPtr mode = drm_conn_info->modes + i;
int fit = 0;
if (xmodesize)
fit += abs((int)mode->hdisplay - xmodesize) * (int)mode->vdisplay;
if (ymodesize)
fit += abs((int)mode->vdisplay - ymodesize) * (int)mode->hdisplay;
if (fit < best_fit) {
best_index = i;
best_fit = fit;
// Choose this size/mode
drm_mode_index = best_index;
xmodesize = (int)drm_conn_info->modes[best_index].hdisplay;
ymodesize = (int)drm_conn_info->modes[best_index].vdisplay;
// We'll only set the mode if we have to. This hopefully allows
// multiple instances of this application to run, writing to
// separate planes of the same display, as long as they don't
// specifiy incompatible settings.
if ((drm_conn_info->encoder_id != drm_enc_id) ||
(drm_enc_info->crtc_id != drm_crtc_id) ||
!drm_crtc_info->mode_valid ||
((plane < 0) && xmodesize && (xmodesize != (int)drm_crtc_info->mode.hdisplay)) ||
((plane < 0) && ymodesize && (ymodesize != (int)drm_crtc_info->mode.vdisplay))) {
set_mode = true;
// If dimensions haven't been specified, figure out good values to use
if (!xmodesize || !ymodesize) {
// If mode requires reset, just pick the first one available
// from the connector
if (set_mode) {
xmodesize = (int)drm_conn_info->modes[0].hdisplay;
ymodesize = (int)drm_conn_info->modes[0].vdisplay;
// Otherwise get it from the current crtc settings
else {
xmodesize = (int)drm_crtc_info->mode.hdisplay;
ymodesize = (int)drm_crtc_info->mode.vdisplay;
printf("Determine mode settings\n");
// If surf size is unspecified, default to fullscreen normally
// or to 1/4 fullscreen if in animated bounce mode.
if (!xsurfsize || !ysurfsize) {
if (bounce) {
xsurfsize = xmodesize / 2;
ysurfsize = ymodesize / 2;
else {
xsurfsize = xmodesize;
ysurfsize = ymodesize;
printf("Determine surface size\n");
// If necessary, set the mode
if (set_mode) {
drmModeSetCrtc(drm_fd, drm_crtc_id, -1, 0, 0, &drm_conn_id, 1, drm_conn_info->modes + drm_mode_index);
printf("Set mode\n");
// If plane is in use, set it
if (plane >= 0) {
drmModeSetPlane(drm_fd, drm_plane_id, drm_crtc_id, -1, 0,
xoffset, yoffset, xsurfsize, ysurfsize,
0, 0, xsurfsize << 16, ysurfsize << 16);
printf("Set plane configuration\n");
void graphics_set_egl(EGLDeviceEXT egl_dev) {
int fifo = 0;
EGLOutputLayerEXT egl_lyr;
EGLConfig egl_cfg;
EGLStreamKHR egl_str;
EGLint major, minor;
// Obtain and initialize EGLDisplay
eglDisplay = eglGetPlatformDisplayEXT(EGL_PLATFORM_DEVICE_EXT, (void*)egl_dev, NULL);
if (eglDisplay == EGL_NO_DISPLAY)
_EXIT("Couldn't obtain EGLDisplay for device\n", 8);
if (!eglInitialize(eglDisplay, &major, &minor))
_EXIT("Couldn't initialize EGLDisplay (error)\n", eglGetError());
printf("Obtained EGLDisplay\n");
// Check for stream_consumer_egloutput + output_drm support
const char* dpy_exts = eglQueryString(eglDisplay, EGL_EXTENSIONS);
const char* dev_exts = eglQueryDeviceStringEXT(egl_dev, EGL_EXTENSIONS);
if (!CheckExtension(dpy_exts, "EGL_EXT_output_base"))
_EXIT("Missing required extension: EGL_EXT_output_base\n", 2);
if (!CheckExtension(dev_exts, "EGL_EXT_device_drm"))
_EXIT("Missing required extension: EGL_EXT_device_drm\n", 2);
if (!CheckExtension(dpy_exts, "EGL_EXT_output_drm"))
_EXIT("Missing required extension: EGL_EXT_output_drm\n", 2);
if (!CheckExtension(dpy_exts, "EGL_EXT_stream_consumer_egloutput"))
_EXIT("Missing required extension: EGL_EXT_stream_consumer_egloutput\n", 2)
// Choose a config and create a context
EGLint cfg_attr[] = {
EGL_SURFACE_TYPE, EGL_STREAM_BIT_KHR,
EGL_RENDERABLE_TYPE, EGL_OPENGL_ES2_BIT,
EGL_ALPHA_SIZE, 1,
EGL_NONE
int n;
if (!eglChooseConfig(eglDisplay, cfg_attr, &egl_cfg, 1, &n) || !n)
_EXIT("Unable to obtain config that supports stream rendering (error)\n", eglGetError());
EGLint ctx_attr[] = { EGL_CONTEXT_CLIENT_VERSION, 2, EGL_NONE };
eglBindAPI(EGL_OPENGL_ES_API);
eglContext = eglCreateContext(eglDisplay, egl_cfg, EGL_NO_CONTEXT, ctx_attr);
if (eglContext == EGL_NO_CONTEXT)
_EXIT("Unable to create context (error)\n", eglGetError());
printf("Obtained EGLConfig and EGLContext\n");
// Get the layer for this crtc/plane
EGLAttrib layer_attr[] = { EGL_NONE, EGL_NONE, EGL_NONE };
if (plane >= 0) {
layer_attr[0] = EGL_DRM_PLANE_EXT;
layer_attr[1] = (EGLAttrib)drm_plane_id;
else {
layer_attr[0] = EGL_DRM_CRTC_EXT;
layer_attr[1] = (EGLAttrib)drm_crtc_id;
if (!eglGetOutputLayersEXT(eglDisplay, layer_attr, &egl_lyr, 1, &n) || !n)
_EXIT("Unable to obtain EGLOutputLayer ", 10);
printf("Obtained EGLOutputLayer\n");
// Create a stream and connect to the output
EGLint stream_attr[] = { EGL_STREAM_FIFO_LENGTH_KHR, fifo, EGL_NONE };
egl_str = eglCreateStreamKHR(eglDisplay, stream_attr);
if (egl_str == EGL_NO_STREAM_KHR)
_EXIT("Unable to create stream (error)\n", eglGetError());
if (!eglStreamConsumerOutputEXT(eglDisplay, egl_str, egl_lyr))
_EXIT("Unable to connect stream (error)\n", eglGetError());
// Create a surface to feed the stream
EGLint srf_attr[] = { EGL_WIDTH, xsurfsize, EGL_HEIGHT, ysurfsize, EGL_NONE };
eglSurface = eglCreateStreamProducerSurfaceKHR(eglDisplay, egl_cfg, egl_str, srf_attr);
if (eglSurface == EGL_NO_SURFACE)
_EXIT("Unable to create rendering surface (error)\n", eglGetError());
printf("Bound layer to rendering surface\n");
// Make current
if (!eglMakeCurrent(eglDisplay, eglSurface, eglSurface, eglContext))
_EXIT("Unable to make context/surface current (error)\n", eglGetError());
EGLint Context_RendererType;
eglQueryContext(eglDisplay, eglContext, EGL_CONTEXT_CLIENT_TYPE, &Context_RendererType);
int graphics_setup_window(int xpos, int ypos, int width, int height)
load_func();
// Query device
int device = 0;
EGLDeviceEXT egl_devs[MAX_DEVICES];
int n;
if (!eglQueryDevicesEXT(device + 1, egl_devs, &n) || (n <= device))
_EXIT("Requested device index not found\n", 2);
EGLDeviceEXT egl_dev = egl_devs[device];
graphics_set_drm(egl_dev);
graphics_set_egl(egl_dev);
return 1;
void graphics_swap_buffers()
eglSwapBuffers(eglDisplay, eglSurface);
void graphics_close_window()
if (eglDisplay != EGL_NO_DISPLAY)
eglMakeCurrent(eglDisplay, EGL_NO_SURFACE, EGL_NO_SURFACE, EGL_NO_CONTEXT);
if (eglContext != EGL_NO_CONTEXT)
eglDestroyContext(eglDisplay, eglContext);
if (eglSurface != EGL_NO_SURFACE)
eglDestroySurface(eglDisplay, eglSurface);
eglTerminate(eglDisplay);
printf("Released display resources\n");
static void InitGraphicsState() {
char* GL_version = (char*)glGetString(GL_VERSION);
char* GL_vendor = (char*)glGetString(GL_VENDOR);
char* GL_renderer = (char*)glGetString(GL_RENDERER);
printf("Version: %s\n", GL_version);
printf("Vendor: %s\n", GL_vendor);
printf("Renderer: %s\n", GL_renderer);
void ClearColor(float r, float g, float b, float a) {
glClearColor(r, g, b, a);
glClear(GL_COLOR_BUFFER_BIT);
graphics_swap_buffers();
int main(int argc, char** argv) {
graphics_setup_window(0, 0, 1920, 1080);
InitGraphicsState();
ClearColor(0, 0.5, 1, 1);
usleep(1000000);
ClearColor(0, 1, 1, 1);
usleep(1000000);
ClearColor(1, 0.5, 1, 1);
usleep(1000000);
ClearColor(1, 1, 1, 1);
usleep(1000000);
graphics_close_window();
