I’m trying to run the egl demo code kmscube: https://gitlab.freedesktop.org/mesa/kmscube
I’ve built the source successfully. Then I use ctrl-alt-f1 to drop out to a command line login.
Every time I try to run the sample I get:
drmGetDevices2 failed: no such file or directory
could not open drm device
failed to initialize legacy drm
I’ve used the same steps to get this to run on a amd64 machine.
This testing was done on a fresh install of the latest Jetpack 4.4 that I fully patched.
Any help getting this running would be greatly appreciated.
