I am having a similar problem , I would also need to see a working example on how to use a rtsp sink in code with deepstream test app 1/2/3/4 . It would be really helpful if someone can share a working example of adding a rtsp sink in the app pipeline.
Yes It is unclear how to stream jetsonNano’s test app’s output over RTSP using a RTSP sink . A Working example would clear how to integrate a rtsp sink in the pipeline …
All samples are open source and we encourage users to do customization. Actually deepstream-app should cover most general cases. It may be easier to modify config files and run deepstream-app instead of customizing deepstream test apps.
For deepstream-test4 + RTSP sink, we suggest refer to deepstream-test5.
