DS5 : deepstream-app not working on AWS: only one frame processed
• Hardware Platform (Jetson / GPU) Tesla T4 on AWS
• DeepStream Version 5
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2
I am trying to run deepstream-app on AWS instance. On running it just processes one frame and generates out.mp4 but then does not do anything. The out.mp4 contains only one image. While running the app the nvidia-smi shows 0 GPU load even though its taking 800MB in Mem
Same is the behaviour with all the test apps. All apps work on my laptop with RTX 2080 without any issue. Can you please check/
-rw-rw-rw- 1 25011 dip 3978 Apr 27 13:26 source30_1080p_dec_infer-resnet_tiled_display_int8.txt
I edited the configuration file source30_1080p_dec_infer-resnet_tiled_display_int8.txt to disable [sink0] and enable [sink1] for file output.
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1408 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:00.982011433 111 0x5647fd35e190 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1566> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:00.982044042 111 0x5647fd35e190 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1673> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:00.982056566 111 0x5647fd35e190 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:13.038904379 111 0x5647fd35e190 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1624> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine successfully
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:34 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:13.045153531 111 0x5647fd35e190 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg)FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg) FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
**PERF: 0.00 (0.00) 0.09 (0.08) 0.00 (0.00) 0.09 (0.08) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.09 (0.08) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.09 (0.08) 0.09 (0.08) 0.00 (0.00)
**PERF: 0.00 (0.00) 0.00 (0.06) 0.00 (0.00) 0.00 (0.06) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.06) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.06) 0.00 (0.06) 0.00 (0.00)
**PERF: 0.00 (0.00) 0.00 (0.04) 0.00 (0.00) 0.00 (0.04) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.04) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.04) 0.00 (0.04) 0.00 (0.00)
**PERF: 0.05 (0.05) 0.05 (0.06) 0.05 (0.05) 0.05 (0.06) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.06) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.05) 0.05 (0.06) 0.05 (0.06) 0.05 (0.05)
**PERF: 0.00 (0.04) 0.00 (0.05) 0.00 (0.04) 0.00 (0.05) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.05) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.04) 0.00 (0.05) 0.00 (0.05) 0.00 (0.04)
PERF: 0.00 (0.03) 0.00 (0.05) 0.00 (0.03) 0.00 (0.05) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.05) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.03) 0.00 (0.05) 0.00 (0.05) 0.00 (0.03)
^C
ERROR: <_intr_handler:140>: User Interrupted…
Quitting
^C^C^C^C^C
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# ll
total 140
drwxr-xrwx 1 root root 4096 May 12 06:40 ./
drwxr-xrwx 1 root root 4096 Apr 27 13:33 …/
-rw-rw-rw- 1 25011 dip 3134 Apr 27 13:26 config_infer_primary.txt
-rw-rw-rw- 1 25011 dip 3247 Apr 27 13:26 config_infer_primary_endv.txt
-rw-rw-rw- 1 25011 dip 3094 Apr 27 13:26 config_infer_primary_nano.txt
-rw-rw-rw- 1 25011 dip 2626 Apr 27 13:26 config_infer_secondary_carcolor.txt
-rw-rw-rw- 1 25011 dip 2620 Apr 27 13:26 config_infer_secondary_carmake.txt
-rw-rw-rw- 1 25011 dip 2650 Apr 27 13:26 config_infer_secondary_vehicletypes.txt
-rw-rw-rw- 1 25011 dip 13028 Apr 27 13:26 config_mux_source30.txt
-rw-rw-rw- 1 25011 dip 2294 Apr 27 13:26 config_mux_source4.txt
-rw-rw-rw- 1 25011 dip 31 Apr 27 13:26 iou_config.txt
-rw-r–r-- 1 root root 46230 May 12 06:41 out.mp4
-rw-rw-rw- 1 25011 dip 2899 Apr 27 13:26 source1_usb_dec_infer_resnet_int8.txt
-rw-rw-rw- 1 25011 dip 3978 May 12 01:21 source30_1080p_dec_infer-resnet_tiled_display_int8.txt
-rw-rw-rw- 1 25011 dip 4900 Apr 27 13:26 source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
-rw-rw-rw- 1 25011 dip 4754 Apr 27 13:26 source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
-rw-rw-rw- 1 25011 dip 5322 Apr 27 13:26 tracker_config.yml
root@ip-10-255-254-21:/home/ubuntu# nvidia-smi
Tue May 12 06:10:42 2020
| NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2 |
| 0 Tesla T4 Off | 00000000:00:1E.0 Off | 0 |
| N/A 44C P0 27W / 70W | 840MiB / 15109MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 20793 C ./deepstream-app 801MiB |
I tried on DS4.0 also. I have tried both Container Runtime as well as Native Support
docker run -it --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --volume=“/home/$USER:/home/$USER” --name ds2 -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:4.0.2-19.12-samples
docker run -it --net=host --gpus all -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --volume=“/home/$USER:/home/$USER” --name ds2 -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:4.0.2-19.12-samples
Still get same issue.
Hi @Mike,
I have the similar setup as yours, T4, NVIDIA-SMI 440.64.00 Driver Version: 440.64.00 CUDA Version: 10.2, I followed your steps (edit source30_1080p_dec_infer-resnet_tiled_display_int8.txt to enable sink1 and disable sink0), and tried both DS5.0 and DS4.0, can’t reproduce your issue, that is, I can get the video file (out.mp4) generated successfully and the fps is good.
Could you “export GST_DEBUG=*:3” and run the command again and share the log?
Are you using an AWS instance? On my laptop with RTX 2080 I can run all the samples but not on AWS.
Here are the logs
root@09ebad3f8e3b:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# cp -rp source30_1080p_dec_infer-resnet_tiled_display_int8.txt dd.txt
root@09ebad3f8e3b:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# vi dd.txt
root@09ebad3f8e3b:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# deepstream-app -c dd.txt ^C
root@09ebad3f8e3b:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# export GST_DEBUG=*:3
0:00:00.075548363 14 0x55bd2882c810 WARN ladspa gstladspa.c:507:plugin_init: no LADSPA plugins found, check LADSPA_PATH
0:00:00.112821536 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x120000: ‘AVR (Audio Visual Research)’ is not mapped
0:00:00.112840171 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x180000: ‘CAF (Apple Core Audio File)’ is not mapped
0:00:00.112850365 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x100000: ‘HTK (HMM Tool Kit)’ is not mapped
0:00:00.112861437 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xc0000: ‘MAT4 (GNU Octave 2.0 / Matlab 4.2)’ is not mapped
0:00:00.112872664 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xd0000: ‘MAT5 (GNU Octave 2.1 / Matlab 5.0)’ is not mapped
0:00:00.112879867 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x210000: ‘MPC (Akai MPC 2k)’ is not mapped
0:00:00.112889091 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xe0000: ‘PVF (Portable Voice Format)’ is not mapped
0:00:00.112899581 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x160000: ‘SD2 (Sound Designer II)’ is not mapped
0:00:00.112910713 14 0x55bd2882c810 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x190000: ‘WVE (Psion Series 3)’ is not mapped
0:00:00.752611228 14 0x55bd2882c810 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtrtserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14): GStreamer-WARNING **: 11:55:10.971: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
0:00:01.483315751 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:01.483343057 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat YM12
0:00:01.483355700 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:01.483368548 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat YM12
0:00:01.483383002 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x555ce6911500 Failed to determine interlace mode
0:00:01.483419071 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:01.483428655 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe minimum capture size for pixelformat H264
0:00:01.483439075 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:01.483446499 13 0x555ce69dce60 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe maximum capture size for pixelformat H264
0:00:01.876309623 13 0x555ce69dce60 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1566> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:01.876336942 13 0x555ce69dce60 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1673> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:01.876348970 13 0x555ce69dce60 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
0:00:13.865040006 13 0x555ce69dce60 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1624> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine successfully
0:00:13.871229164 13 0x555ce69dce60 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
0:00:13.871782660 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.872069717 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.872518437 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.872692363 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.873125868 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.873363500 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.873743321 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.873971686 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.874407908 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.874707584 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.875379669 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.875642561 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.876080803 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.876675454 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.877185564 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.877537090 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.877987431 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.878363523 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.879111053 13 0x7f04c80036d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.879212689 13 0x7f04c80036d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.879378186 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.879682397 13 0x7f04dc0426d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.879703579 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.880209573 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.880574169 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.880587281 13 0x555d2b0d6ed0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.880629562 13 0x7f04dc0426d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.881380332 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.881508758 13 0x555d2b0d6ed0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.881788853 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.882200533 13 0x7f04dc040140 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.882330398 13 0x7f04dc040140 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.882694942 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.882996635 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.883119101 13 0x7f04ec002850 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.883198825 13 0x7f04ec002850 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.883706200 13 0x7f04a0003590 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.884454623 13 0x7f04a0003590 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.884926455 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.885168329 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.886803203 13 0x7f0484003590 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.887410057 13 0x7f0484003590 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.887899675 13 0x7f0474012850 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.888403140 13 0x7f04980036d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.888521085 13 0x7f0474012850 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.889056128 13 0x7f04980036d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.889647837 13 0x7f043c013400 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.889857842 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.890119846 13 0x7f043c013400 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.891148182 13 0x7f0418003450 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.891289212 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.891814876 13 0x7f0418003450 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.892098476 13 0x7f04140032d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.892945957 13 0x7f04140032d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.893183021 13 0x7f04280154f0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.893261086 13 0x555d2b0d6c50 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.893264875 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.893776204 13 0x555d2b0d6c50 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.893902596 13 0x7f04280154f0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.893910318 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.894505566 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.895028151 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.895875340 13 0x7f046408ecf0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.896053178 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.896511212 13 0x7f046408ecf0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.896710763 13 0x7f049800dc50 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.896921108 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.897090161 13 0x7f049800dc50 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.897779187 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.897925996 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.898718153 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.898719466 13 0x7f04a4014f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.898941426 13 0x7f04a4014f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.898982625 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.899386338 13 0x7f04dc04b6d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.899676125 13 0x7f04dc04b6d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.899714007 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.900215048 13 0x7f04d0015140 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.900215187 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.900506255 13 0x7f04d0015140 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.901286076 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.901563233 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.901997074 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.902253633 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.902662752 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.902814594 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.903146609 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.903511743 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.903699661 13 0x7f0468011de0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.904127370 13 0x7f0468011de0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.904148107 13 0x555d25cf44f0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.904240002 13 0x555d25cf44f0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.904394223 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.904727253 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.905126010 13 0x7f043c080ad0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.905335377 13 0x7f043c080ad0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.905604976 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.905855290 13 0x555d25cf4450 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.905916587 13 0x555d25cf4540 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.905955760 13 0x555d25cf4450 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.906035754 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.906359219 13 0x555d25cf4540 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.906740463 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.907158280 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.907486727 13 0x7f046c084c50 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.907612998 13 0x7f0454007ed0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.908092449 13 0x7f0454007ed0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.908325079 13 0x7f046c084c50 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.908658892 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.908986143 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.910042792 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.910203415 13 0x7f04b0012050 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.910299036 13 0x555ce69dce60 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:13.910395243 13 0x7f04b0012050 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
0:00:13.910504062 13 0x7f04a4093000 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg)FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
0:00:13.911161502 13 0x7f04a4093000 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.911870749 13 0x7f04d4008450 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.911973224 13 0x7f04d4008450 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.913269042 13 0x7f04fc014e30 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:13.913345113 13 0x7f04fc014e30 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:13.946563399 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946582507 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.946592547 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946598235 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.946612565 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946628189 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.946638041 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946646885 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.946673174 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946684093 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:13.946688319 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946692709 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:13.946707285 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946714638 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:13.946721425 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:13.946728572 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:13.946789455 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:13.946797823 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:13.946804421 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:13.946813120 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:13.946838077 13 0x7f043c012e30 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f0410123f20 Failed to determine interlace mode
0:00:13.946870582 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.946887838 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.946901162 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.946913598 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.946934631 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.946948277 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.946959153 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.946969102 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.946989693 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.946999751 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:13.947004765 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.947009130 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:13.947029190 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.947065954 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:13.947077682 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:13.947088626 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:13.947127670 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:13.947139628 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:13.947149871 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:13.947159364 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
0:00:13.947241331 13 0x7f04100128f0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f043001dc80 Failed to determine interlace mode
0:00:13.948278621 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948296923 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.948306950 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948314721 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.948390474 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948415719 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.948426434 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948435894 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.948450368 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948456543 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H265
0:00:13.948461930 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948468446 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H265
0:00:13.948483797 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948489570 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H264
0:00:13.948494874 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:13.948500419 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H264
0:00:13.948528799 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:13.948537946 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe minimum capture size for pixelformat NM12
0:00:13.948547935 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:13.948558216 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe maximum capture size for pixelformat NM12
0:00:13.948570908 13 0x7f0468003f70 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f0438022430 Failed to determine interlace mode
0:00:13.948989381 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949003151 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.949015120 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949025074 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.949044793 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949053532 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.949063263 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949072268 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.949094129 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949103400 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H265
0:00:13.949112493 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949121791 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H265
0:00:13.949151736 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949162832 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H264
0:00:13.949173468 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:13.949183190 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H264
0:00:13.949213973 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:13.949222610 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe minimum capture size for pixelformat NM12
0:00:13.949231576 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:13.949265466 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe maximum capture size for pixelformat NM12
0:00:13.949294524 13 0x7f0468011590 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f04b40a7e00 Failed to determine interlace mode
0:00:13.953258317 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.953273640 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.953284484 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.953292840 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.953307256 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.954572018 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.954588309 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.954597977 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.954623295 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.954634961 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat H265
0:00:13.954643430 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.954677108 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat H265
0:00:13.954712368 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.954726681 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat H264
0:00:13.954736698 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:13.954758870 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat H264
0:00:13.954899045 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:src Unable to try format: Unknown error -1
0:00:13.954997776 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:src Could not probe minimum capture size for pixelformat NM12
0:00:13.955010282 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:src Unable to try format: Unknown error -1
0:00:13.955018153 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:src Could not probe maximum capture size for pixelformat NM12
0:00:13.955031418 13 0x7f050c013f70 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f04180ae380 Failed to determine interlace mode
0:00:13.957326483 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957342582 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.957352994 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957359714 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.957371310 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957381111 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.957392000 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957406146 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.957444267 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957462427 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe minimum capture size for pixelformat H265
0:00:13.957488816 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957509698 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe maximum capture size for pixelformat H265
0:00:13.957551789 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957564497 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe minimum capture size for pixelformat H264
0:00:13.957574575 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:sink Unable to try format: Unknown error -1
0:00:13.957583520 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:sink Could not probe maximum capture size for pixelformat H264
0:00:13.957618949 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:src Unable to try format: Unknown error -1
0:00:13.957626357 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:src Could not probe minimum capture size for pixelformat NM12
0:00:13.957632736 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder5:src Unable to try format: Unknown error -1
0:00:13.957643049 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder5:src Could not probe maximum capture size for pixelformat NM12
0:00:13.957661394 13 0x7f050c0134f0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f056801bca0 Failed to determine interlace mode
0:00:13.960563309 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960583660 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.960597041 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960612387 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.960637134 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960648144 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.960659046 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960669018 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.960694883 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960708324 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe minimum capture size for pixelformat H265
0:00:13.960720210 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960731664 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe maximum capture size for pixelformat H265
0:00:13.960754824 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960766198 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe minimum capture size for pixelformat H264
0:00:13.960776761 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:sink Unable to try format: Unknown error -1
0:00:13.960787139 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:sink Could not probe maximum capture size for pixelformat H264
0:00:13.960824095 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:src Unable to try format: Unknown error -1
0:00:13.960833534 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:src Could not probe minimum capture size for pixelformat NM12
0:00:13.960842456 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder6:src Unable to try format: Unknown error -1
0:00:13.960853206 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder6:src Could not probe maximum capture size for pixelformat NM12
0:00:13.960868979 13 0x7f0480017f70 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f04bc0215c0 Failed to determine interlace mode
0:00:13.963355951 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963372598 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.963382537 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963498148 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.963518170 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963529279 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.963540442 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963550226 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.963568082 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963575108 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe minimum capture size for pixelformat H265
0:00:13.963581955 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963593219 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe maximum capture size for pixelformat H265
0:00:13.963613802 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963620756 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe minimum capture size for pixelformat H264
0:00:13.963627230 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:sink Unable to try format: Unknown error -1
0:00:13.963633580 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:sink Could not probe maximum capture size for pixelformat H264
0:00:13.963657044 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.963670148 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:src Unable to try format: Unknown error -1
0:00:13.963684681 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:src Could not probe minimum capture size for pixelformat NM12
0:00:13.963697284 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder7:src Unable to try format: Unknown error -1
0:00:13.963709013 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder7:src Could not probe maximum capture size for pixelformat NM12
0:00:13.963721139 13 0x7f04800174f0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f049c020390 Failed to determine interlace mode
0:00:13.963671167 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.964085759 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.964101833 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.964131528 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.964143440 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.964148566 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.964155732 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.964167453 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.964226448 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe minimum capture size for pixelformat H265
0:00:13.964235168 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.964244014 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe maximum capture size for pixelformat H265
0:00:13.964269490 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.964278322 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe minimum capture size for pixelformat H264
0:00:13.964284622 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:sink Unable to try format: Unknown error -1
0:00:13.965731890 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:sink Could not probe maximum capture size for pixelformat H264
0:00:13.965770781 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:src Unable to try format: Unknown error -1
0:00:13.965780006 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:src Could not probe minimum capture size for pixelformat NM12
0:00:13.965785375 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder8:src Unable to try format: Unknown error -1
0:00:13.965792599 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder8:src Could not probe maximum capture size for pixelformat NM12
0:00:13.965806048 13 0x7f0468003590 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f04781f37f0 Failed to determine interlace mode
0:00:13.966062033 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.966075871 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.966086241 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.966096475 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.966114768 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.966126582 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.966138176 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.966210560 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.966248395 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.966269891 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe minimum capture size for pixelformat H265
0:00:13.966302990 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.966320858 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe maximum capture size for pixelformat H265
0:00:13.966351986 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.967655123 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe minimum capture size for pixelformat H264
0:00:13.967667769 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:sink Unable to try format: Unknown error -1
0:00:13.967685772 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:sink Could not probe maximum capture size for pixelformat H264
0:00:13.967784120 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.967798581 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.967808302 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.967815082 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.967861241 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:src Unable to try format: Unknown error -1
0:00:13.967876587 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:src Could not probe minimum capture size for pixelformat NM12
0:00:13.967886153 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder9:src Unable to try format: Unknown error -1
0:00:13.967864052 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.967899566 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder9:src Could not probe maximum capture size for pixelformat NM12
0:00:13.967932333 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.967946637 13 0x7f0418018140 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f0490019660 Failed to determine interlace mode
0:00:13.967966550 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.968012202 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.968048672 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.968062171 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe minimum capture size for pixelformat H265
0:00:13.968074761 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.968087834 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe maximum capture size for pixelformat H265
0:00:13.968110624 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.968138621 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe minimum capture size for pixelformat H264
0:00:13.968151107 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:sink Unable to try format: Unknown error -1
0:00:13.968160944 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:sink Could not probe maximum capture size for pixelformat H264
0:00:13.968200549 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:src Unable to try format: Unknown error -1
0:00:13.968211087 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:src Could not probe minimum capture size for pixelformat NM12
0:00:13.968217256 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder10:src Unable to try format: Unknown error -1
0:00:13.968228599 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder10:src Could not probe maximum capture size for pixelformat NM12
0:00:13.968242019 13 0x7f045c0036d0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f043412e020 Failed to determine interlace mode
0:00:13.972371555 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972390419 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.972399167 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972406815 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.972423373 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972431464 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.972446407 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972459016 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.972480223 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972494151 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe minimum capture size for pixelformat H265
0:00:13.972520389 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972531175 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe maximum capture size for pixelformat H265
0:00:13.972552440 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972564547 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe minimum capture size for pixelformat H264
0:00:13.972572211 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:sink Unable to try format: Unknown error -1
0:00:13.972579822 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:sink Could not probe maximum capture size for pixelformat H264
0:00:13.972614591 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:src Unable to try format: Unknown error -1
0:00:13.972623607 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:src Could not probe minimum capture size for pixelformat NM12
0:00:13.972629926 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder11:src Unable to try format: Unknown error -1
0:00:13.972636731 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder11:src Could not probe maximum capture size for pixelformat NM12
0:00:13.972647731 13 0x7f04dc0401e0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x555cf51cd060 Failed to determine interlace mode
0:00:13.973454161 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973483556 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.973492354 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973501911 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.973521349 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973530715 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.973537305 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973547053 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.973568024 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973577439 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe minimum capture size for pixelformat H265
0:00:13.973584949 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973592888 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe maximum capture size for pixelformat H265
0:00:13.973618700 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973627557 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe minimum capture size for pixelformat H264
0:00:13.973635783 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:sink Unable to try format: Unknown error -1
0:00:13.973644647 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:sink Could not probe maximum capture size for pixelformat H264
0:00:13.973678540 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:src Unable to try format: Unknown error -1
0:00:13.973688148 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:src Could not probe minimum capture size for pixelformat NM12
0:00:13.973696003 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder12:src Unable to try format: Unknown error -1
0:00:13.973703327 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder12:src Could not probe maximum capture size for pixelformat NM12
0:00:13.973716009 13 0x7f0444003f70 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f0430014a60 Failed to determine interlace mode
0:00:13.974617614 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.974632647 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.974660068 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.974684621 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.974702301 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.974709724 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.976042491 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.976074604 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.976098734 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.976107652 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe minimum capture size for pixelformat H265
0:00:13.976114464 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.976126865 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe maximum capture size for pixelformat H265
0:00:13.976152215 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.976161764 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe minimum capture size for pixelformat H264
0:00:13.976170320 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:sink Unable to try format: Unknown error -1
0:00:13.976176992 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:sink Could not probe maximum capture size for pixelformat H264
0:00:13.976212932 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:src Unable to try format: Unknown error -1
0:00:13.976229281 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:src Could not probe minimum capture size for pixelformat NM12
0:00:13.976237243 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder13:src Unable to try format: Unknown error -1
0:00:13.976244235 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder13:src Could not probe maximum capture size for pixelformat NM12
0:00:13.976257495 13 0x7f045c01e630 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f04a0031050 Failed to determine interlace mode
0:00:13.978449707 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978473585 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe minimum capture size for pixelformat MJPG
0:00:13.978486442 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978501407 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe maximum capture size for pixelformat MJPG
0:00:13.978558436 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978609960 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe minimum capture size for pixelformat MPG4
0:00:13.978641480 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978659648 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe maximum capture size for pixelformat MPG4
0:00:13.978709056 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978746184 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe minimum capture size for pixelformat H265
0:00:13.978773850 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978786542 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe maximum capture size for pixelformat H265
0:00:13.978811958 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978826062 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe minimum capture size for pixelformat H264
0:00:13.978836248 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:sink Unable to try format: Unknown error -1
0:00:13.978847690 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:sink Could not probe maximum capture size for pixelformat H264
0:00:13.978888807 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:src Unable to try format: Unknown error -1
0:00:13.978901289 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:src Could not probe minimum capture size for pixelformat NM12
0:00:13.978914570 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder14:src Unable to try format: Unknown error -1
0:00:13.978926493 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder14:src Could not probe maximum capture size for pixelformat NM12
0:00:13.978940198 13 0x555d25cf44a0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f04741293a0 Failed to determine interlace mode
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
^C
ERROR: <_intr_handler:140>: User Interrupted…
Quitting
0:01:38.029575771 13 0x555ce69dacf0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<sink_sub_bin_sink1> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
Config
I just followed the steps to change config from Integrating an Inferencing Pipeline with NVIDIA DeepStream and the G4 Instance Family | AWS Compute Blog
Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=5
columns=6
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://…/…/streams/sample_1080p_h264.mp4
num-sources=15
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=15
gpu-id=0
cudadec-memtype=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=30
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=30
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tests]
file-loop=0
Steps after getting the AWS Instance
sudo apt-get update
mkdir ~/work ; cd ~/work
wget http://us.download.nvidia.com/tesla/440.33.01/nvidia-driver-local-repo-ubuntu1604-440.33.01_1.0-1_amd64.deb
sudo apt-key add /var/nvidia-driver-local-repo-440.33.01/7fa2af80.pub
sudo dpkg -i nvidia-driver-local-repo-ubuntu1604-440.33.01_1.0-1_amd64.deb
sudo apt-get update
sudo apt-get install cuda-drivers
nvidia-smi
distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
sudo apt install curl
curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add -
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit
sudo systemctl restart docker
sudo apt-get update
sudo apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo apt-key fingerprint 0EBFCD88
sudo add-apt-repository “deb [arch=amd64] Index of linux/ubuntu/ $(lsb_release -cs) stable”
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io
apt-cache madison docker-ce
sudo docker run hello-world
docker run --gpus all nvidia/cuda:9.0-base nvidia-smi
sudo groupadd docker
sudo usermod -aG docker $USER
Nvidia Runtime Installation
curl -s -L https://nvidia.github.io/nvidia-container-runtime/gpgkey |
sudo apt-key add -
curl -s -L https://nvidia.github.io/nvidia-container-runtime/$distribution/nvidia-container-runtime.list |
sudo tee /etc/apt/sources.list.d/nvidia-container-runtime.list
sudo apt-get update
sudo apt-get install nvidia-container-runtime
Systemd drop-in file
sudo mkdir -p /etc/systemd/system/docker.service.d
sudo tee /etc/systemd/system/docker.service.d/override.conf <<EOF
[Service]
ExecStart=
ExecStart=/usr/bin/dockerd --host=fd:// --add-runtime=nvidia=/usr/bin/nvidia-container-runtime
EOF
sudo systemctl daemon-reload
Steps to login to the Deepstream docker: I tried all four combinations but same result.
docker run -it --gpus all -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --volume=“/home/$USER:/home/$USER” --name ds2 -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:5.0-dp-20.04-devel
docker run -it --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --volume=“/home/$USER:/home/$USER” --name ds1 -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:5.0-dp-20.04-devel
docker run -it --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --volume=“/home/$USER:/home/$USER” --name ds2 -e DISPLAY=$DISPLAY -w /root [nvcr.io/nvidia/deepstream:4.0.2-19.12-samples](http://nvcr.io/nvidia/deepstream:
4.0.2-19.12-samples)
docker run -it --net=host --gpus all -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --volume=“/home/$USER:/home/$USER” --name ds2 -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:4.0.2-19.12-samples
What’s your input ?
Its in the config file
I get the same error on my laptop as well but it works.
Does it have something to do with AWS? Are there any special considerations?
I also followed the exact same steps mentioned in the Integrating an Inferencing Pipeline with NVIDIA DeepStream and the G4 Instance Family | AWS Compute Blog
I spun up a new instance g4dn.xlarge and logged in. All the steps same as in the above link but still no results.
__| | )
| ( / Deep Learning AMI (Amazon Linux) Version 28.1
|_|
Please use one of the following commands to start the required environment with the framework of your choice:
for MXNet(+Keras2) with Python3 (CUDA 10.1 and Intel MKL-DNN) ____________________________________ source activate mxnet_p36
for MXNet(+Keras2) with Python2 (CUDA 10.1 and Intel MKL-DNN) ____________________________________ source activate mxnet_p27
for MXNet(+Amazon Elastic Inference) with Python3 _______________________________________ source activate amazonei_mxnet_p36
for MXNet(+Amazon Elastic Inference) with Python2 _______________________________________ source activate amazonei_mxnet_p27
for TensorFlow(+Keras2) with Python3 (CUDA 10.0 and Intel MKL-DNN) __________________________ source activate tensorflow_p36
for TensorFlow(+Keras2) with Python2 (CUDA 10.0 and Intel MKL-DNN) __________________________ source activate tensorflow_p27
for Tensorflow(+Amazon Elastic Inference) with Python2 _____________________________ source activate amazonei_tensorflow_p27
for Tensorflow(+Amazon Elastic Inference) with Python3 _____________________________ source activate amazonei_tensorflow_p36
for TensorFlow 2(+Keras2) with Python3 (CUDA 10.1 and Intel MKL-DNN) _______________________ source activate tensorflow2_p36
for TensorFlow 2(+Keras2) with Python2 (CUDA 10.1 and Intel MKL-DNN) _______________________ source activate tensorflow2_p27
for TensorFlow 2(+Amazon Elastic Inference) with Python3 __________________________ source activate amazonei_tensorflow2_p36
for TensorFlow 2(+Amazon Elastic Inference) with Python2 __________________________ source activate amazonei_tensorflow2_p27
for PyTorch with Python3 (CUDA 10.1 and Intel MKL) _____________________________________________ source activate pytorch_p36
for PyTorch with Python2 (CUDA 10.1 and Intel MKL) _____________________________________________ source activate pytorch_p27
for PyTorch(+Amazon Elastic Inference) with Python3 ___________________________________ source activate amazonei_pytorch_p36
for Chainer with Python2 (CUDA 10.0 and Intel iDeep) ___________________________________________ source activate chainer_p27
for Chainer with Python3 (CUDA 10.0 and Intel iDeep) ___________________________________________ source activate chainer_p36
for base Python2 (CUDA 10.0) _______________________________________________________________________ source activate python2
for base Python3 (CUDA 10.0) _______________________________________________________________________ source activate python3
Official Conda User Guide: User guide — conda 4.14.0.post39+de3db7f75 documentation
AWS Deep Learning AMI Homepage: Deep Learning AMIs - Amazon Web Services
Developer Guide and Release Notes: What Is the AWS Deep Learning AMI? - Deep Learning AMI
Support: Find Answers to AWS Questions about AWS Deep Learning AMIs | AWS re:Post
For a fully managed experience, check out Amazon SageMaker at Machine Learning – Amazon Web Services
No packages needed for security; 1 packages available
Run “sudo yum update” to apply all updates.
[ec2-user@ip-172-31-40-83 ~]$ docker pull nvcr.io/nvidia/deepstream:4.0-19.07
4.0-19.07: Pulling from nvidia/deepstream
6abc03819f3e: Pull complete
05731e63f211: Pull complete
0bd67c50d6be: Pull complete
2f87bc35d330: Pull complete
9fe964cf4376: Pull complete
e4732fdd9b39: Pull complete
b6d41e19faf6: Pull complete
94dea506ace8: Pull complete
b248e477ad27: Pull complete
4bc5c8802384: Pull complete
9c4a5b7d5776: Pull complete
213004265555: Pull complete
7092094accc1: Pull complete
9cc3233abc4a: Pull complete
daff5e5f4fe3: Pull complete
5c2adfebe05e: Pull complete
eb0b03bec7ec: Pull complete
11f636721e6b: Pull complete
67c009e8b441: Pull complete
96cddb4da6e3: Pull complete
31982d083e06: Pull complete
9d02697d31ca: Pull complete
Digest: sha256:2531e68d3899623db01dd275b72502abfd6a19cba0e3695ea6d5e9269ebd6693
Status: Downloaded newer image for nvcr.io/nvidia/deepstream:4.0-19.07
[ec2-user@ip-172-31-40-83 ~]$ nvidia-docker run -it --rm -v /usr/lib/x86_64-linux-gnu/libnvidia-encode.so:/usr/lib/x86_64-linux-gnu/libnvidia-encode.so -v /tmp/.X11-unix:/tmp/.X11-unix -p 8554:8554 -e DISPLAY=$DISPLAY nvcr.io/nvidia/deepstream: 4.0-19.07
docker: invalid reference format.
See ‘docker run --help’.
nvidia-debugdump nvidia-docker
[ec2-user@ip-172-31-40-83 ~]$ nvidia-docker ^C
[ec2-user@ip-172-31-40-83 ~]$ nvidia-docker run -it --rm -v /usr/lib/x86_64-linux-gnu/libnvidia-encode.so:/usr/lib/x86_64-linux-gnu/libnvidia-encode.so -v /tmp/.X11-unix:/tmp/.X11-unix -p 8554:8554 -e DISPLAY=$DISPLAY nvcr.io/nvidia/deepstream:4.0-19.07
root@2528df78fdca:/#
root@2528df78fdca:/# ll
total 80
drwxr-xr-x 1 root root 4096 May 12 12:50 ./
drwxr-xr-x 1 root root 4096 May 12 12:50 …/
-rwxr-xr-x 1 root root 0 May 12 12:50 .dockerenv*
drwxr-xr-x 2 root root 4096 May 15 2019 bin/
drwxr-xr-x 2 root root 4096 Apr 24 2018 boot/
drwxr-xr-x 5 root root 440 May 12 12:50 dev/
drwxr-xr-x 1 root root 4096 May 12 12:50 etc/
drwxr-xr-x 2 root root 4096 Apr 24 2018 home/
drwxr-xr-x 1 root root 4096 Jun 4 2019 lib/
drwxr-xr-x 2 root root 4096 May 15 2019 lib64/
drwxr-xr-x 2 root root 4096 May 15 2019 media/
drwxr-xr-x 2 root root 4096 May 15 2019 mnt/
drwxr-xr-x 1 root root 4096 Jul 22 2019 opt/
dr-xr-xr-x 134 root root 0 May 12 12:50 proc/
drwx------ 1 root root 4096 Jul 22 2019 root/
drwxr-xr-x 1 root root 4096 May 15 2019 run/
drwxr-xr-x 1 root root 4096 Jul 22 2019 sbin/
drwxr-xr-x 2 root root 4096 May 15 2019 srv/
dr-xr-xr-x 13 root root 0 May 12 12:50 sys/
drwxrwxrwt 1 root root 4096 May 12 12:50 tmp/
drwxr-xr-x 1 root root 4096 May 15 2019 usr/
drwxr-xr-x 1 root root 4096 Jul 22 2019 var/
root@2528df78fdca:/# cd /root/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app/
root@2528df78fdca:~/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app# ll
total 60
drwxr-xr-x 2 root root 4096 Jul 19 2019 ./
drwxr-xr-x 3 root root 4096 Jul 19 2019 …/
-rw-r–r-- 1 25011 dip 2939 Jul 19 2019 config_infer_primary.txt
-rw-r–r-- 1 25011 dip 2899 Jul 19 2019 config_infer_primary_nano.txt
-rw-r–r-- 1 25011 dip 2540 Jul 19 2019 config_infer_secondary_carcolor.txt
-rw-r–r-- 1 25011 dip 2534 Jul 19 2019 config_infer_secondary_carmake.txt
-rw-r–r-- 1 25011 dip 2564 Jul 19 2019 config_infer_secondary_vehicletypes.txt
-rw-r–r-- 1 25011 dip 31 Jul 19 2019 iou_config.txt
-rw-r–r-- 1 25011 dip 2461 Jul 19 2019 source1_usb_dec_infer_resnet_int8.txt
-rw-r–r-- 1 25011 dip 3539 Jul 19 2019 source30_1080p_dec_infer-resnet_tiled_display_int8.txt
-rw-r–r-- 1 25011 dip 4284 Jul 19 2019 source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
-rw-r–r-- 1 25011 dip 4190 Jul 19 2019 source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
-rw-r–r-- 1 25011 dip 1709 Jul 19 2019 tracker_config.yml
root@2528df78fdca:~/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app# cp -rp source30_1080p_dec_infer-resnet_tiled_display_int8.txt dd.txt
root@2528df78fdca:~/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app# vi dd.txt
root@2528df78fdca:~/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app# deepstream-app -c dd.txt
(deepstream-app:14): GLib-GObject-WARNING **: 12:51:12.975: g_object_set_is_valid_property: object class ‘nvv4l2h264enc’ has no property named ‘bufapi-version’
Creating LL OSD context new
0:00:03.056917129 14 0x7f418c0022d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:useEngineFile(): Failed to read from model engine file
0:00:03.056965214 14 0x7f418c0022d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:12.774190746 14 0x7f418c0022d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /root/deepstream_sdk_v4.0_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg)FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
** INFO: <bus_callback:163>: Pipeline ready
^C
Quitting
Segmentation fault
could you try this command ?
$ gst-launch-1.0 filesrc location=…/…/streams/sample_1080p_h264.mp4 ! qtdemux ! queue ! h264parse ! nvv4l2decoder ! filesink location=output.file -e
and check if the size of output.file is zero.
It does not work. The outfile is just few hundred bytes.
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/streams# export GST_DEBUG=*:4
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/streams# gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! queue ! h264parse ! nvv4l2decoder ! filesink location=output.file -e
0:00:00.000055080 38 0x557c4ac7ec00 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000094557 38 0x557c4ac7ec00 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000109570 38 0x557c4ac7ec00 INFO GST_INIT gst.c:607:init_pre: Linux ip-10-255-254-21 4.4.0-1106-aws #117-Ubuntu SMP Wed Apr 8 09:52:02 UTC 2020 x86_64
0:00:00.000282118 38 0x557c4ac7ec00 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.000587930 38 0x557c4ac7ec00 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.000726206 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000790846 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.000802151 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.000820613 38 0x557c4ac7ec00 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.009916936 38 0x557c4ac7ec00 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.x86_64.bin in 0.009074 seconds
0:00:00.009964956 38 0x557c4ac7ec00 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.011248868 38 0x557c4ac7ec00 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.011263632 38 0x557c4ac7ec00 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.011275299 38 0x557c4ac7ec00 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.011287518 38 0x557c4ac7ec00 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.011295423 38 0x557c4ac7ec00 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.011322930 38 0x557c4ac7ec00 INFO GST_PIPELINE gstparse.c:337:gst_parse_launch_full: parsing pipeline description ‘filesrc location=sample_1080p_h264.mp4 ! qtdemux ! queue ! h264parse ! nvv4l2decoder ! filesink location=output.file ’
0:00:00.011787955 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.011803108 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “filesrc”
0:00:00.011889575 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x557c4aeb21e0 adding pad ‘src’
0:00:00.011927564 38 0x557c4ac7ec00 INFO filesrc gstfilesrc.c:261:gst_file_src_set_location: filename : sample_1080p_h264.mp4
0:00:00.011939245 38 0x557c4ac7ec00 INFO filesrc gstfilesrc.c:262:gst_file_src_set_location: uri : file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
0:00:00.013063330 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstisomp4.so” loaded
0:00:00.013080846 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “qtdemux”
0:00:00.013162985 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQTDemux@0x557c4accc3f0 adding pad ‘sink’
0:00:00.013193511 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “queue”
0:00:00.013263211 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x557c4aec4110 adding pad ‘sink’
0:00:00.013277563 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x557c4aec4110 adding pad ‘src’
0:00:00.013553511 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so” loaded
0:00:00.013565889 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “h264parse”
0:00:00.013623851 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x557c4aec8a60 adding pad ‘sink’
0:00:00.013636253 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x557c4aec8a60 adding pad ‘src’
0:00:00.013650660 38 0x557c4ac7ec00 INFO baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:GstH264Parse@0x557c4aec8a60 PTS interpolation: no
0:00:00.016033422 38 0x557c4ac7ec00 INFO GST_PLUGIN_LOADING gstplugin.c:901:priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so” loaded
0:00:00.016049627 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “nvv4l2decoder”
0:00:00.016143280 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x557c4aee7c80 adding pad ‘sink’
0:00:00.016157149 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x557c4aee7c80 adding pad ‘src’
0:00:00.016180775 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “filesink”
0:00:00.016245605 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x557c4aeed3e0 adding pad ‘sink’
0:00:00.016275822 38 0x557c4ac7ec00 INFO filesink gstfilesink.c:294:gst_file_sink_set_location: filename : output.file
0:00:00.016285713 38 0x557c4ac7ec00 INFO filesink gstfilesink.c:295:gst_file_sink_set_location: uri : file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/output.file
0:00:00.016300185 38 0x557c4ac7ec00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “pipeline”
0:00:00.016373473 38 0x557c4ac7ec00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstFileSrc named filesrc0 to some pad of GstQTDemux named qtdemux0 (0/0) with caps “(NULL)”
0:00:00.016384085 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element filesrc0:(any) to element qtdemux0:(any)
0:00:00.016393763 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link filesrc0:src and qtdemux0:sink
0:00:00.016413852 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: filesrc0 and qtdemux0 in same bin, no need for ghost pads
0:00:00.016428357 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link filesrc0:src and qtdemux0:sink
0:00:00.016440367 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked filesrc0:src and qtdemux0:sink, successful
0:00:00.016448524 38 0x557c4ac7ec00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.016457466 38 0x557c4ac7ec00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:filesrc0:src Received event on flushing pad. Discarding
0:00:00.016474897 38 0x557c4ac7ec00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstQTDemux named qtdemux0 to some pad of GstQueue named queue0 (0/0) with caps “(NULL)”
0:00:00.016483629 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element qtdemux0:(any) to element queue0:(any)
0:00:00.016496666 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue0:src pad has no peer
0:00:00.016516326 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'video
%u’ in element “qtdemux0”
0:00:00.016528300 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstutils.c:1227:gst_element_get_compatible_pad: Could not find a compatible pad to link to queue0:sink
0:00:00.016534325 38 0x557c4ac7ec00 INFO default gstutils.c:2162:gst_element_link_pads_filtered: Could not link pads: qtdemux0:(null) - queue0:(null)
0:00:00.016547370 38 0x557c4ac7ec00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstQueue named queue0 to some pad of GstH264Parse named h264parse0 (0/0) with caps “(NULL)”
0:00:00.016553540 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element queue0:(any) to element h264parse0:(any)
0:00:00.016559855 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link queue0:src and h264parse0:sink
0:00:00.016573048 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue0:sink pad has no peer
0:00:00.016587267 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264parse0:src pad has no peer
0:00:00.016602848 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: queue0 and h264parse0 in same bin, no need for ghost pads
0:00:00.016611882 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link queue0:src and h264parse0:sink
0:00:00.016623868 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue0:sink pad has no peer
0:00:00.016631790 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264parse0:src pad has no peer
0:00:00.016639800 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked queue0:src and h264parse0:sink, successful
0:00:00.016647033 38 0x557c4ac7ec00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.016654626 38 0x557c4ac7ec00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:queue0:src Received event on flushing pad. Discarding
0:00:00.016667282 38 0x557c4ac7ec00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstH264Parse named h264parse0 to some pad of nvv4l2decoder named nvv4l2decoder0 (0/0) with caps “(NULL)”
0:00:00.016678354 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element h264parse0:(any) to element nvv4l2decoder0:(any)
0:00:00.016690379 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link h264parse0:src and nvv4l2decoder0:sink
0:00:00.016703526 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvv4l2decoder0:src pad has no peer
0:00:00.016752435 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: h264parse0 and nvv4l2decoder0 in same bin, no need for ghost pads
0:00:00.016763971 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link h264parse0:src and nvv4l2decoder0:sink
0:00:00.016769807 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvv4l2decoder0:src pad has no peer
0:00:00.016797355 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked h264parse0:src and nvv4l2decoder0:sink, successful
0:00:00.016808004 38 0x557c4ac7ec00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.016817801 38 0x557c4ac7ec00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:h264parse0:src Received event on flushing pad. Discarding
0:00:00.016834725 38 0x557c4ac7ec00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of nvv4l2decoder named nvv4l2decoder0 to some pad of GstFileSink named filesink0 (0/0) with caps “(NULL)”
0:00:00.016845351 38 0x557c4ac7ec00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvv4l2decoder0:(any) to element filesink0:(any)
0:00:00.016851662 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvv4l2decoder0:src and filesink0:sink
0:00:00.016862475 38 0x557c4ac7ec00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvv4l2decoder0 and filesink0 in same bin, no need for ghost pads
0:00:00.016873662 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvv4l2decoder0:src and filesink0:sink
0:00:00.016883411 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvv4l2decoder0:src and filesink0:sink, successful
0:00:00.016891077 38 0x557c4ac7ec00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.016900283 38 0x557c4ac7ec00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvv4l2decoder0:src Received event on flushing pad. Discarding
Setting pipeline to PAUSED …
0:00:00.016938163 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.016992488 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.017001119 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.017016840 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 2(READY) successfully
0:00:00.017028838 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.552042338 38 0x557c4ac7ec00 INFO v4l2 v4l2_calls.c:622:gst_v4l2_open:nvv4l2decoder0:sink Opened device ‘’ (/dev/nvhost-nvdec) successfully
0:00:00.552065852 38 0x557c4ac7ec00 INFO v4l2 v4l2_calls.c:723:gst_v4l2_dup:nvv4l2decoder0:src Cloned device ‘’ (/dev/nvhost-nvdec) successfully
0:00:00.552082815 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1281:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink got 7 format(s):
0:00:00.552092101 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink YM12
0:00:00.552100124 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink MJPG
0:00:00.552107927 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink MPG4
0:00:00.552117113 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink H265
0:00:00.552125371 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink VP90
0:00:00.552132332 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink VP80
0:00:00.552139822 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink H264
0:00:00.552182791 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552191969 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:00.552198659 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552206140 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:00.552222049 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552229664 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:00.552234335 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552240545 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:00.552251602 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552256752 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:00.552261205 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552270561 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:00.552289997 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552301151 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:00.552309633 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.552319030 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:00.552354247 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:4466:gst_v4l2_object_probe_caps:nvv4l2decoder0:sink probed caps: image/jpeg, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], parsed=(boolean)true; video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], parsed=(boolean)true; video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], parsed=(boolean)true; video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ]
0:00:00.552685343 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1281:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src got 6 format(s):
0:00:00.552696312 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src MJPG
0:00:00.552703908 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src NM12
0:00:00.552710887 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src MPG4
0:00:00.552717978 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src VP80
0:00:00.552727600 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src H265
0:00:00.552738069 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src H264
0:00:00.552752955 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:00.552764179 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:00.552775166 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:00.552786688 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:00.552800897 38 0x557c4ac7ec00 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x557c4aeea4c0 Failed to determine interlace mode
0:00:00.552826403 38 0x557c4ac7ec00 INFO v4l2 gstv4l2object.c:4466:gst_v4l2_object_probe_caps:nvv4l2decoder0:src probed caps: video/x-raw, format=(string)NV12, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], pixel-aspect-ratio=(fraction)1/1
0:00:00.552839394 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.552852051 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.552870711 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 2(READY) successfully
0:00:00.552885453 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.552896106 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.552904656 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.552913117 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 2(READY) successfully
0:00:00.552926236 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.552937254 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.552945957 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.552955198 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 2(READY) successfully
0:00:00.552964899 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.552974960 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.552984338 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.552991034 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 2(READY) successfully
0:00:00.552997574 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.553009088 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.553020396 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.553028535 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 2(READY) successfully
0:00:00.553037817 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.553048766 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.553068620 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.553083580 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.553104816 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘filesink0’ is changing state asynchronously to PAUSED
0:00:00.553112348 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.553126463 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.553137480 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.553144827 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 3(PAUSED) successfully
0:00:00.553153309 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.553365629 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.553375418 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.553385310 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 3(PAUSED) successfully
0:00:00.553393912 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.553409873 38 0x557c4ac7ec00 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x557c4aeb48d0 on task 0x557c4aebe5f0
0:00:00.553418676 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:queue0:src created task 0x557c4aebe5f0
0:00:00.553465984 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.553476748 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.553486312 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 3(PAUSED) successfully
0:00:00.553493748 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.553503599 38 0x557c4ac7ec00 INFO filesrc gstfilesrc.c:468:gst_file_src_start: opening file sample_1080p_h264.mp4
0:00:00.553539147 38 0x557c4ac7ec00 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:00.553554512 38 0x557c4ac7ec00 INFO filesrc gstfilesrc.c:468:gst_file_src_start: opening file sample_1080p_h264.mp4
0:00:00.553579848 38 0x557c4ac7ec00 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x557c4aeb4430 on task 0x557c4aebe710
0:00:00.553588489 38 0x557c4ac7ec00 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:qtdemux0:sink created task 0x557c4aebe710
0:00:00.553637297 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.553649821 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.553659836 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 3(PAUSED) successfully
0:00:00.553671493 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.553686890 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.553702857 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.553717977 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 3(PAUSED) successfully
Pipeline is PREROLLING …
0:00:00.554023546 38 0x557c4aebce30 INFO qtdemux qtdemux.c:13235:qtdemux_parse_tree: timescale: 1000
0:00:00.554034899 38 0x557c4aebce30 INFO qtdemux qtdemux.c:13236:qtdemux_parse_tree: duration: 48100
0:00:00.554044326 38 0x557c4aebce30 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:00.554080028 38 0x557c4aebce30 INFO qtdemux qtdemux.c:10812:qtdemux_parse_trak: type avc1 caps video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001a67640028acd940780227e584000003000400000300f03c60c65801000668ebe3cb22c0
0:00:00.554138994 38 0x557c4aebce30 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:00.554165946 38 0x557c4aebce30 INFO qtdemux qtdemux.c:11547:qtdemux_parse_trak: type mp4a caps audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500
0:00:00.554213420 38 0x557c4aebce30 INFO GST_SCHEDULING gstpad.c:4895:gst_pad_get_range_unchecked:filesrc0:src getrange failed, flow: eos
0:00:00.554219485 38 0x557c4aebce30 INFO GST_SCHEDULING gstpad.c:5110:gst_pad_pull_range:qtdemux0:sink pullrange failed, flow: eos
0:00:00.554252103 38 0x557c4aebce30 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad qtdemux0:sink
0:00:00.554283436 38 0x557c4aebce30 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001a67640028acd940780227e584000003000400000300f03c60c65801000668ebe3cb22c0, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1
0:00:00.554291788 38 0x557c4aebce30 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘video_0’
0:00:00.554302503 38 0x557c4aebce30 INFO GST_PIPELINE grammar.y:524:gst_parse_found_pad: trying delayed linking one pad some pad of GstQTDemux named qtdemux0 to some pad of GstQueue named queue0
0:00:00.554309199 38 0x557c4aebce30 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element qtdemux0:(any) to element queue0:(any)
0:00:00.554316334 38 0x557c4aebce30 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link qtdemux0:video_0 and queue0:sink
0:00:00.554371523 38 0x557c4aebce30 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: qtdemux0 and queue0 in same bin, no need for ghost pads
0:00:00.554380139 38 0x557c4aebce30 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link qtdemux0:video_0 and queue0:sink
0:00:00.554415403 38 0x557c4aebce30 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked qtdemux0:video_0 and queue0:sink, successful
0:00:00.554419969 38 0x557c4aebce30 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.554442971 38 0x557c4aebce30 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad qtdemux0:sink
0:00:00.554458748 38 0x557c4aebce30 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2
0:00:00.554464943 38 0x557c4aebce30 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘audio_0’
0:00:00.554487056 38 0x557c4aebce30 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.066666666, offset=0:00:00.000000000, stop=0:00:48.166666666, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.066666666, duration 99:99:99.999999999
0:00:00.554602314 38 0x557c4aebce30 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=0:00:48.022000000, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.554654824 38 0x557c4aebcf70 INFO baseparse gstbaseparse.c:4777:gst_base_parse_set_upstream_tags: upstream tags: taglist, video-codec=(string)“H.264\ /\ AVC”, language-code=(string)en, bitrate=(uint)5675753;
0:00:00.554781716 38 0x557c4aebcf70 INFO baseparse gstbaseparse.c:4004:gst_base_parse_set_latency: min/max latency 0:00:00.033333333, 0:00:00.033333333
0:00:00.554851693 38 0x557c4aebcf70 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)high, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
0:00:00.557615348 38 0x557c4aebcf70 INFO v4l2 gstv4l2object.c:3148:gst_v4l2_object_setup_pool:nvv4l2decoder0:sink accessing buffers via mode 2
0:00:00.557710444 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:817:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink increasing minimum buffers to 2
0:00:00.557720456 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:824:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink increasing minimum buffers to 4
0:00:00.557729434 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:830:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink reducing maximum buffers to 32
0:00:00.557734647 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:841:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink can’t allocate, setting maximum to minimum
0:00:00.557855617 38 0x557c4aebcf70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ /\ AVC”, language-code=(string)en, bitrate=(uint)5675753;
0:00:00.557972824 38 0x557c4aebcf70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753;
0:00:01.637793261 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637813698 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637841359 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637850480 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637879161 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637890261 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637923471 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637933536 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637976126 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.637984251 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.638015102 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.638053729 38 0x557c4aebcf70 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.638128479 38 0x557c4aebcf70 INFO v4l2 gstv4l2object.c:4466:gst_v4l2_object_probe_caps:nvv4l2decoder0:src probed caps: image/jpeg, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-raw, format=(string)NV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string){ progressive, interleaved }, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-vp8, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }
0:00:01.638244221 38 0x557c4aebcf70 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
0:00:01.638278851 38 0x557c4aebcf70 INFO v4l2 gstv4l2object.c:3148:gst_v4l2_object_setup_pool:nvv4l2decoder0:src accessing buffers via mode 2
0:00:01.638337298 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:817:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src increasing minimum buffers to 2
0:00:01.638345368 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:824:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src increasing minimum buffers to 4
0:00:01.638351453 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:830:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src reducing maximum buffers to 32
0:00:01.638358821 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:841:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src can’t allocate, setting maximum to minimum
0:00:01.638366381 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:846:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src adding needed video meta
0:00:01.638422237 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:830:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src reducing maximum buffers to 32
0:00:01.638432762 38 0x557c4aebcf70 INFO v4l2bufferpool gstv4l2bufferpool.c:841:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:src can’t allocate, setting maximum to minimum
0:00:01.638472613 38 0x557c4aebcf70 WARN v4l2videodec gstv4l2videodec.c:1609:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:01.638496866 38 0x557c4aebcf70 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:01.638560273 38 0x557c4aebcf70 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x557c4aeb5210 on task 0x557c4aebeb90
0:00:01.638569510 38 0x557c4aebcf70 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:nvv4l2decoder0:src created task 0x557c4aebeb90
0:00:01.639065902 38 0x7f2858003050 WARN v4l2bufferpool gstv4l2bufferpool.c:1535:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:01.639130217 38 0x7f2858003050 INFO videodecoder gstvideodecoder.c:3201:gst_video_decoder_clip_and_push_buf: First buffer since flush took 0:00:01.086002013 to produce
0:00:01.639153443 38 0x7f2858003050 INFO GST_STATES gstbin.c:3424:bin_handle_async_done: committing state from READY to PAUSED, old pending PAUSED
0:00:01.639174323 38 0x7f2858003050 INFO GST_STATES gstbin.c:3444:bin_handle_async_done: completed state change, pending VOID
0:00:01.639185259 38 0x7f2858003050 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
0:00:01.639383973 38 0x557c4ac7ec00 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:01.639411164 38 0x557c4ac7ec00 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:01.639428731 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.639444690 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639458422 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.639471372 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 4(PLAYING) successfully
0:00:01.639481352 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.639491161 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639500120 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.639510264 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 4(PLAYING) successfully
0:00:01.639523682 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.639531091 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639539964 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.639551247 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 4(PLAYING) successfully
0:00:01.639561181 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.639575895 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639589034 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.639600492 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 4(PLAYING) successfully
0:00:01.639613110 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.639620940 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639633061 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.639643592 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 4(PLAYING) successfully
0:00:01.639655484 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.639666961 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639677408 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.639687412 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 4(PLAYING) successfully
0:00:01.639697887 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:01.639704172 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
New clock: GstSystemClock
0:01:15.640206698 38 0x557c4aebcf70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7486320, maximum-bitrate=(uint)7486320;
0:01:36.786986704 38 0x557c4aebcf70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7255680, maximum-bitrate=(uint)7486320;
^Chandling interrupt.
Interrupt: Stopping pipeline …
EOS on shutdown enabled – Forcing EOS on the pipeline
Waiting for EOS…
0:03:01.368109324 38 0x557c4aebce30 INFO GST_SCHEDULING gstpad.c:4895:gst_pad_get_range_unchecked:filesrc0:src getrange failed, flow: eos
0:03:01.368131715 38 0x557c4aebce30 INFO GST_SCHEDULING gstpad.c:5110:gst_pad_pull_range:qtdemux0:sink pullrange failed, flow: eos
0:03:01.368143381 38 0x557c4aebcf70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7129680, maximum-bitrate=(uint)7486320;
0:03:01.368158815 38 0x557c4aebce30 INFO task gsttask.c:316:gst_task_func:qtdemux0:sink Task going to paused
Interrupt while waiting for EOS - stopping pipeline…
Execution ended after 0:03:15.129249418
0:03:16.769010519 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:03:16.769033126 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘filesink0’ is changing state asynchronously to PAUSED
0:03:16.769043959 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:03:16.769056214 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:03:16.769084330 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:03:16.769104003 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 3(PAUSED) successfully
0:03:16.769117587 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:03:16.769126554 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:03:16.769133745 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:03:16.769143796 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 3(PAUSED) successfully
0:03:16.769155259 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:03:16.769165113 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:03:16.769174716 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:03:16.769186918 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 3(PAUSED) successfully
0:03:16.769197450 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:03:16.769210846 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:03:16.769221793 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:03:16.769232134 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 3(PAUSED) successfully
0:03:16.769243410 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:03:16.769253582 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:03:16.769273203 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:03:16.769286508 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 3(PAUSED) successfully
Setting pipeline to READY …
0:03:16.769322991 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending PAUSED, desired next READY
0:03:16.769360779 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:03:16.769369952 38 0x557c4ac7ec00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to READY (VOID_PENDING pending)
0:03:16.769380015 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 2(READY) successfully
0:03:16.769391548 38 0x557c4ac7ec00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
^C^C^C
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/streams# ll
total 178208
drwxr-xrwx 1 root root 4096 May 12 18:00 ./
drwxr-xrwx 1 root root 4096 Apr 27 13:33 …/
-rw-r–r-- 1 root root 640 May 12 18:15 output.file
-rw-rw-rw- 1 25011 dip 34952625 Aug 14 2019 sample_1080p_h264.mp4
-rw-rw-rw- 1 25011 dip 14018396 Aug 14 2019 sample_1080p_h265.mp4
-rw-rw-rw- 1 25011 dip 14759548 Aug 14 2019 sample_720p.h264
-rw-rw-rw- 1 25011 dip 50434312 Aug 14 2019 sample_720p.mjpeg
-rw-rw-rw- 1 25011 dip 15574709 Aug 14 2019 sample_720p.mp4
-rw-rw-rw- 1 25011 dip 27496987 Sep 17 2019 sample_cam5.mp4
-rw-rw-rw- 1 25011 dip 24999084 Aug 14 2019 sample_cam6.mp4
I have one more observation. When I replace the decoder nvv4l2decoder with avdec_h264 the pipeline works but I need to use nvv4l2decoder
gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! queue ! h264parse ! avdec_h264 ! filesink location=output.file -e
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/streams# gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! queue ! h264parse ! avdec_h264 ! filesink location=output.file -e
0:00:00.000053029 74 0x564785920c00 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000089887 74 0x564785920c00 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000101861 74 0x564785920c00 INFO GST_INIT gst.c:607:init_pre: Linux ip-10-255-254-21 4.4.0-1106-aws #117-Ubuntu SMP Wed Apr 8 09:52:02 UTC 2020 x86_64
0:00:00.000289448 74 0x564785920c00 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.000604472 74 0x564785920c00 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.000751414 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000819495 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.000839766 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.000866818 74 0x564785920c00 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.009868280 74 0x564785920c00 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.x86_64.bin in 0.008976 seconds
0:00:00.009912427 74 0x564785920c00 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.011183242 74 0x564785920c00 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.011195550 74 0x564785920c00 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.011204768 74 0x564785920c00 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.011212557 74 0x564785920c00 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.011218536 74 0x564785920c00 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.011241999 74 0x564785920c00 INFO GST_PIPELINE gstparse.c:337:gst_parse_launch_full: parsing pipeline description ‘filesrc location=sample_1080p_h264.mp4 ! qtdemux ! queue ! h264parse ! avdec_h264 ! filesink location=output.file ’
0:00:00.011715300 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.011732568 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “filesrc”
0:00:00.011819308 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x564785b541e0 adding pad ‘src’
0:00:00.011858063 74 0x564785920c00 INFO filesrc gstfilesrc.c:261:gst_file_src_set_location: filename : sample_1080p_h264.mp4
0:00:00.011867146 74 0x564785920c00 INFO filesrc gstfilesrc.c:262:gst_file_src_set_location: uri : file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
0:00:00.012966303 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstisomp4.so” loaded
0:00:00.012982839 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “qtdemux”
0:00:00.013063100 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQTDemux@0x56478596e3f0 adding pad ‘sink’
0:00:00.013097999 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “queue”
0:00:00.013169456 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x564785b66110 adding pad ‘sink’
0:00:00.013184204 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x564785b66110 adding pad ‘src’
0:00:00.013433660 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so” loaded
0:00:00.013444328 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “h264parse”
0:00:00.013499157 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x564785b6aa60 adding pad ‘sink’
0:00:00.013515530 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x564785b6aa60 adding pad ‘src’
0:00:00.013534082 74 0x564785920c00 INFO baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:GstH264Parse@0x564785b6aa60 PTS interpolation: no
0:00:00.052126006 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_avs
0:00:00.052210589 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_bfstm
0:00:00.052239975 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_brstm
0:00:00.052272383 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_daud
0:00:00.052303667 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_ea
0:00:00.052328211 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_ffm
0:00:00.052358236 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_4xm
0:00:00.052393760 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_gxf
0:00:00.052418918 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_idcin
0:00:00.052445992 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_ipmovie
0:00:00.052484176 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_mm
0:00:00.052501562 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_mmf
0:00:00.052536357 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_nsv
0:00:00.052557997 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_nut
0:00:00.052610743 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_film_cpk
0:00:00.052635284 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_smk
0:00:00.052653175 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_sol
0:00:00.052673232 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_psxstr
0:00:00.052708581 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_vmd
0:00:00.052732149 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_wc3movie
0:00:00.052761983 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_wsaud
0:00:00.052785105 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_wsvqa
0:00:00.052809164 74 0x564785920c00 INFO GST_TYPEFIND gsttypefind.c:72:gst_type_find_register: registering typefind function for avtype_yuv4mpegpipe
0:00:00.053084641 74 0x564785920c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstlibav.so” loaded
0:00:00.053094730 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “avdec_h264”
0:00:00.053203658 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x564785c12fa0 adding pad ‘sink’
0:00:00.053217087 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x564785c12fa0 adding pad ‘src’
0:00:00.053293894 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “filesink”
0:00:00.053352498 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x564785c240e0 adding pad ‘sink’
0:00:00.053382723 74 0x564785920c00 INFO filesink gstfilesink.c:294:gst_file_sink_set_location: filename : output.file
0:00:00.053391235 74 0x564785920c00 INFO filesink gstfilesink.c:295:gst_file_sink_set_location: uri : file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/output.file
0:00:00.053404630 74 0x564785920c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “pipeline”
0:00:00.053485440 74 0x564785920c00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstFileSrc named filesrc0 to some pad of GstQTDemux named qtdemux0 (0/0) with caps “(NULL)”
0:00:00.053493705 74 0x564785920c00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element filesrc0:(any) to element qtdemux0:(any)
0:00:00.053500505 74 0x564785920c00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link filesrc0:src and qtdemux0:sink
0:00:00.053511963 74 0x564785920c00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: filesrc0 and qtdemux0 in same bin, no need for ghost pads
0:00:00.053522731 74 0x564785920c00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link filesrc0:src and qtdemux0:sink
0:00:00.053536183 74 0x564785920c00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked filesrc0:src and qtdemux0:sink, successful
0:00:00.053545714 74 0x564785920c00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.053554496 74 0x564785920c00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:filesrc0:src Received event on flushing pad. Discarding
0:00:00.053571474 74 0x564785920c00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstQTDemux named qtdemux0 to some pad of GstQueue named queue0 (0/0) with caps “(NULL)”
0:00:00.053582563 74 0x564785920c00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element qtdemux0:(any) to element queue0:(any)
0:00:00.053592647 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue0:src pad has no peer
0:00:00.053610603 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'video
0:00:00.053623665 74 0x564785920c00 INFO GST_ELEMENT_PADS gstutils.c:1227:gst_element_get_compatible_pad: Could not find a compatible pad to link to queue0:sink
0:00:00.053634309 74 0x564785920c00 INFO default gstutils.c:2162:gst_element_link_pads_filtered: Could not link pads: qtdemux0:(null) - queue0:(null)
0:00:00.053649789 74 0x564785920c00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstQueue named queue0 to some pad of GstH264Parse named h264parse0 (0/0) with caps “(NULL)”
0:00:00.053658378 74 0x564785920c00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element queue0:(any) to element h264parse0:(any)
0:00:00.053670611 74 0x564785920c00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link queue0:src and h264parse0:sink
0:00:00.053679906 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue0:sink pad has no peer
0:00:00.053692359 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264parse0:src pad has no peer
0:00:00.053705841 74 0x564785920c00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: queue0 and h264parse0 in same bin, no need for ghost pads
0:00:00.053718787 74 0x564785920c00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link queue0:src and h264parse0:sink
0:00:00.053727312 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue0:sink pad has no peer
0:00:00.053734125 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264parse0:src pad has no peer
0:00:00.053746251 74 0x564785920c00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked queue0:src and h264parse0:sink, successful
0:00:00.053753703 74 0x564785920c00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.053757963 74 0x564785920c00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:queue0:src Received event on flushing pad. Discarding
0:00:00.053772820 74 0x564785920c00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstH264Parse named h264parse0 to some pad of avdec_h264 named avdec_h264-0 (0/0) with caps “(NULL)”
0:00:00.053783314 74 0x564785920c00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element h264parse0:(any) to element avdec_h264-0:(any)
0:00:00.053795332 74 0x564785920c00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link h264parse0:src and avdec_h264-0:sink
0:00:00.053806472 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<avdec_h264-0:src> pad has no peer
0:00:00.053828249 74 0x564785920c00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: h264parse0 and avdec_h264-0 in same bin, no need for ghost pads
0:00:00.053840237 74 0x564785920c00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link h264parse0:src and avdec_h264-0:sink
0:00:00.053849203 74 0x564785920c00 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<avdec_h264-0:src> pad has no peer
0:00:00.053861614 74 0x564785920c00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked h264parse0:src and avdec_h264-0:sink, successful
0:00:00.053865969 74 0x564785920c00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.053873221 74 0x564785920c00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:h264parse0:src Received event on flushing pad. Discarding
0:00:00.053887414 74 0x564785920c00 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of avdec_h264 named avdec_h264-0 to some pad of GstFileSink named filesink0 (0/0) with caps “(NULL)”
0:00:00.053898565 74 0x564785920c00 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element avdec_h264-0:(any) to element filesink0:(any)
0:00:00.053909443 74 0x564785920c00 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link avdec_h264-0:src and filesink0:sink
0:00:00.053923160 74 0x564785920c00 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: avdec_h264-0 and filesink0 in same bin, no need for ghost pads
0:00:00.053935693 74 0x564785920c00 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link avdec_h264-0:src and filesink0:sink
0:00:00.053944046 74 0x564785920c00 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked avdec_h264-0:src and filesink0:sink, successful
0:00:00.053950386 74 0x564785920c00 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.053954411 74 0x564785920c00 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<avdec_h264-0:src> Received event on flushing pad. Discarding
0:00:00.053998345 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.054049709 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.054056969 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.054073220 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 2(READY) successfully
0:00:00.054083661 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current NULL pending VOID_PENDING, desired next READY
0:00:00.054090864 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<avdec_h264-0> completed state change to READY
0:00:00.054098686 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<avdec_h264-0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.054111092 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 2(READY) successfully
0:00:00.054120745 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.054128686 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.054136612 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.054146305 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 2(READY) successfully
0:00:00.054156110 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.054167812 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.054174897 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.054183417 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 2(READY) successfully
0:00:00.054190600 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.054199015 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.054207293 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.054219413 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 2(READY) successfully
0:00:00.054227912 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.054238014 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.054246686 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.054257976 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 2(READY) successfully
0:00:00.054271074 74 0x564785920c00 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.054278463 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.054294863 74 0x564785920c00 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.054305761 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.054315624 74 0x564785920c00 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘filesink0’ is changing state asynchronously to PAUSED
0:00:00.054326864 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.054379873 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<avdec_h264-0> completed state change to PAUSED
0:00:00.054385750 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<avdec_h264-0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.054392608 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 3(PAUSED) successfully
0:00:00.054401620 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.054596622 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.054606018 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.054615908 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 3(PAUSED) successfully
0:00:00.054625698 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.054644103 74 0x564785920c00 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x564785b568d0 on task 0x564785b605f0
0:00:00.054654968 74 0x564785920c00 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:queue0:src created task 0x564785b605f0
0:00:00.054713563 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.054722926 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.054730807 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 3(PAUSED) successfully
0:00:00.054740400 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.054749033 74 0x564785920c00 INFO filesrc gstfilesrc.c:468:gst_file_src_start: opening file sample_1080p_h264.mp4
0:00:00.054778220 74 0x564785920c00 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:00.054792373 74 0x564785920c00 INFO filesrc gstfilesrc.c:468:gst_file_src_start: opening file sample_1080p_h264.mp4
0:00:00.054808147 74 0x564785920c00 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x564785b56430 on task 0x564785b60710
0:00:00.054813282 74 0x564785920c00 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:qtdemux0:sink created task 0x564785b60710
0:00:00.054851748 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.054862883 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.054875089 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 3(PAUSED) successfully
0:00:00.054884237 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.054890634 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.054899159 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.054905543 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 3(PAUSED) successfully
0:00:00.055037341 74 0x564785b5eed0 INFO qtdemux qtdemux.c:13235:qtdemux_parse_tree: timescale: 1000
0:00:00.055058125 74 0x564785b5eed0 INFO qtdemux qtdemux.c:13236:qtdemux_parse_tree: duration: 48100
0:00:00.055071412 74 0x564785b5eed0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:00.055114261 74 0x564785b5eed0 INFO qtdemux qtdemux.c:10812:qtdemux_parse_trak: type avc1 caps video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001a67640028acd940780227e584000003000400000300f03c60c65801000668ebe3cb22c0
0:00:00.055176511 74 0x564785b5eed0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:00.055207699 74 0x564785b5eed0 INFO qtdemux qtdemux.c:11547:qtdemux_parse_trak: type mp4a caps audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500
0:00:00.055256542 74 0x564785b5eed0 INFO GST_SCHEDULING gstpad.c:4895:gst_pad_get_range_unchecked:filesrc0:src getrange failed, flow: eos
0:00:00.055272533 74 0x564785b5eed0 INFO GST_SCHEDULING gstpad.c:5110:gst_pad_pull_range:qtdemux0:sink pullrange failed, flow: eos
0:00:00.055327100 74 0x564785b5eed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad qtdemux0:sink
0:00:00.055364551 74 0x564785b5eed0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001a67640028acd940780227e584000003000400000300f03c60c65801000668ebe3cb22c0, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1
0:00:00.055376312 74 0x564785b5eed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘video_0’
0:00:00.055391581 74 0x564785b5eed0 INFO GST_PIPELINE grammar.y:524:gst_parse_found_pad: trying delayed linking one pad some pad of GstQTDemux named qtdemux0 to some pad of GstQueue named queue0
0:00:00.055400581 74 0x564785b5eed0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element qtdemux0:(any) to element queue0:(any)
0:00:00.055414640 74 0x564785b5eed0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link qtdemux0:video_0 and queue0:sink
0:00:00.055452148 74 0x564785b5eed0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: qtdemux0 and queue0 in same bin, no need for ghost pads
0:00:00.055470330 74 0x564785b5eed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link qtdemux0:video_0 and queue0:sink
0:00:00.055498245 74 0x564785b5eed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked qtdemux0:video_0 and queue0:sink, successful
0:00:00.055506493 74 0x564785b5eed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.055531699 74 0x564785b5eed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad qtdemux0:sink
0:00:00.055552334 74 0x564785b5eed0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2
0:00:00.055564017 74 0x564785b5eed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘audio_0’
0:00:00.055592721 74 0x564785b5eed0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.066666666, offset=0:00:00.000000000, stop=0:00:48.166666666, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.066666666, duration 99:99:99.999999999
0:00:00.055736584 74 0x564785b5eed0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=0:00:48.022000000, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.055754929 74 0x564785b5ef70 INFO baseparse gstbaseparse.c:4004:gst_base_parse_set_latency: min/max latency 0:00:00.033333333, 0:00:00.033333333
0:00:00.055831514 74 0x564785b5ef70 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001a67640028acd940780227e584000003000400000300f03c60c65801000668ebe3cb22c0, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
Redistribute latency…
0:00:00.057449289 74 0x564785b5ef70 INFO baseparse gstbaseparse.c:4777:gst_base_parse_set_upstream_tags: upstream tags: taglist, video-codec=(string)“H.264\ /\ AVC”, language-code=(string)en, bitrate=(uint)5675753;
0:00:00.057465887 74 0x564785920c00 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.057483076 74 0x564785920c00 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:00.057547823 74 0x564785b5ef70 INFO baseparse gstbaseparse.c:4004:gst_base_parse_set_latency: min/max latency 0:00:00.033333333, 0:00:00.033333333
0:00:00.057641230 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ /\ AVC”, language-code=(string)en, bitrate=(uint)5675753;
0:00:00.057665364 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753;
0:00:00.057735885 74 0x564785b5ef70 INFO libav :0:: Got unexpected packet after EOF
0:00:00.058191810 74 0x7f55380046c0 INFO libav :0:: Reinit context to 1920x1088, pix_fmt: yuv420p
0:00:00.081447916 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7486320, maximum-bitrate=(uint)7486320;
0:00:00.087443683 74 0x564785b5ef70 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
0:00:00.087670209 74 0x564785920c00 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.087698438 74 0x564785920c00 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:00.089769929 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:3201:gst_video_decoder_clip_and_push_buf:<avdec_h264-0> First buffer since flush took 0:00:00.035422326 to produce
0:00:00.089802073 74 0x564785b5ef70 INFO GST_STATES gstbin.c:3424:bin_handle_async_done: committing state from READY to PAUSED, old pending PAUSED
0:00:00.089814007 74 0x564785b5ef70 INFO GST_STATES gstbin.c:3444:bin_handle_async_done: completed state change, pending VOID
0:00:00.089823523 74 0x564785b5ef70 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.090016723 74 0x564785920c00 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.090046951 74 0x564785920c00 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:00.090072210 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.090092193 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.090110195 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.090126709 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 4(PLAYING) successfully
0:00:00.090139087 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.090147763 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<avdec_h264-0> completed state change to PLAYING
0:00:00.090156352 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<avdec_h264-0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.090169646 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 4(PLAYING) successfully
0:00:00.090181451 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.090189615 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.090197709 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.090210115 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 4(PLAYING) successfully
0:00:00.090219831 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.090227659 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.090237247 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.090246815 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 4(PLAYING) successfully
0:00:00.090260323 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.090273104 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.090284215 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.090297541 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 4(PLAYING) successfully
0:00:00.090309733 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.090321009 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.090331380 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.090341482 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 4(PLAYING) successfully
0:00:00.090353189 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.090362886 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.092530663 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7255680, maximum-bitrate=(uint)7486320;
0:00:00.111930672 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7129680, maximum-bitrate=(uint)7486320;
0:00:00.122270673 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)7129680, maximum-bitrate=(uint)7752000;
0:00:00.126275021 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)6751920, maximum-bitrate=(uint)7752000;
0:00:00.130742783 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)6751920, maximum-bitrate=(uint)8130720;
0:00:00.135166947 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)6502320, maximum-bitrate=(uint)8130720;
0:00:00.142833913 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)6398640, maximum-bitrate=(uint)8130720;
0:00:00.145880339 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)6099360, maximum-bitrate=(uint)8130720;
0:00:00.155339003 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)3237120, maximum-bitrate=(uint)8130720;
0:00:00.168551159 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)3237120, maximum-bitrate=(uint)9494400;
0:00:00.174590123 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)3237120, maximum-bitrate=(uint)10056000;
0:00:00.178135114 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)3237120, maximum-bitrate=(uint)12262320;
0:00:00.181446272 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)3237120, maximum-bitrate=(uint)13313280;
0:00:00.189274172 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)2337120, maximum-bitrate=(uint)13313280;
0:00:00.195393624 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)1800480, maximum-bitrate=(uint)13313280;
0:00:00.210593552 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)1670880, maximum-bitrate=(uint)13313280;
0:00:00.216216818 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)1437360, maximum-bitrate=(uint)13313280;
0:00:00.301945092 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)1437360, maximum-bitrate=(uint)16241520;
0:00:00.307498632 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)1437360, maximum-bitrate=(uint)16334880;
0:00:00.322141051 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)904560, maximum-bitrate=(uint)16334880;
0:00:00.336536230 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)729600, maximum-bitrate=(uint)16334880;
0:00:00.342590798 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)729600, maximum-bitrate=(uint)18887760;
0:00:00.508180374 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)729600, maximum-bitrate=(uint)19415040;
0:00:00.792662008 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)729600, maximum-bitrate=(uint)42570960;
0:00:01.435251509 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)676560, maximum-bitrate=(uint)42570960;
0:00:01.459146043 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)607680, maximum-bitrate=(uint)42570960;
0:00:01.468602904 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)593280, maximum-bitrate=(uint)42570960;
0:00:01.493289259 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)593280, maximum-bitrate=(uint)51508320;
0:00:04.050888542 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)465360, maximum-bitrate=(uint)51508320;
0:00:04.069580314 74 0x564785b5eed0 INFO task gsttask.c:316:gst_task_func:qtdemux0:sink Task going to paused
0:00:04.151624072 74 0x564785b5ef70 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default:<avdec_h264-0> upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, language-code=(string)en, bitrate=(uint)5675753, minimum-bitrate=(uint)166080, maximum-bitrate=(uint)51508320;
0:00:04.179997863 74 0x564785b5ef70 INFO task gsttask.c:316:gst_task_func:queue0:src Task going to paused
Got EOS from element “pipeline0”.
Execution ended after 0:00:04.089641996
Setting pipeline to PAUSED …
0:00:04.180066572 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:04.180083932 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:04.180096502 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180118638 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 3(PAUSED) successfully
0:00:04.180133896 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:04.180146306 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<avdec_h264-0> completed state change to PAUSED
0:00:04.180157358 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<avdec_h264-0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180168994 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 3(PAUSED) successfully
0:00:04.180179926 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:04.180187480 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:04.180194354 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180203553 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 3(PAUSED) successfully
0:00:04.180214279 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:04.180221297 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:04.180233452 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180245323 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 3(PAUSED) successfully
0:00:04.180258502 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:04.180270321 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:04.180281040 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180291224 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 3(PAUSED) successfully
0:00:04.180302821 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:04.180312040 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:04.180323120 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180334494 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 3(PAUSED) successfully
0:00:04.180344139 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:04.180351048 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:04.180373952 74 0x564785920c00 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func: getting state
0:00:04.180402604 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:04.180417745 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:04.180428310 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.180438486 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 2(READY) successfully
0:00:04.180446867 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current PAUSED pending VOID_PENDING, desired next READY
0:00:04.185008076 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<avdec_h264-0> completed state change to READY
0:00:04.185029176 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<avdec_h264-0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.185047553 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 2(READY) successfully
0:00:04.185061276 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:04.185121658 74 0x564785920c00 INFO baseparse gstbaseparse.c:4777:gst_base_parse_set_upstream_tags: upstream tags: (NULL)
0:00:04.185137100 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:04.185149326 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.185161582 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 2(READY) successfully
0:00:04.185172241 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:04.185197513 74 0x564785b5ef70 INFO task gsttask.c:318:gst_task_func:queue0:src Task resume from paused
0:00:04.185238821 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:04.185248601 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.185272465 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 2(READY) successfully
0:00:04.185284037 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:04.185350844 74 0x564785b5eed0 INFO task gsttask.c:318:gst_task_func:qtdemux0:sink Task resume from paused
0:00:04.185410738 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘video_0’
0:00:04.185427178 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking qtdemux0:video_0(0x564785b57d30) and queue0:sink(0x564785b56610)
0:00:04.185440740 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked qtdemux0:video_0 and queue0:sink
0:00:04.185464115 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘audio_0’
0:00:04.185475137 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:04.185483781 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.185495083 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 2(READY) successfully
0:00:04.185512529 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next READY
0:00:04.185522468 74 0x564785920c00 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state: skipping transition from READY to READY
0:00:04.185530636 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 2(READY) successfully
0:00:04.185542487 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current READY pending VOID_PENDING, desired next READY
0:00:04.185549982 74 0x564785920c00 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<avdec_h264-0> skipping transition from READY to READY
0:00:04.185557945 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 2(READY) successfully
0:00:04.185567475 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next READY
0:00:04.185575357 74 0x564785920c00 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state: skipping transition from READY to READY
0:00:04.185583659 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 2(READY) successfully
0:00:04.185592215 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next READY
0:00:04.185602371 74 0x564785920c00 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state: skipping transition from READY to READY
0:00:04.185610251 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 2(READY) successfully
0:00:04.185618541 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next READY
0:00:04.185624587 74 0x564785920c00 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state: skipping transition from READY to READY
0:00:04.185629281 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 2(READY) successfully
0:00:04.185635751 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:04.185647321 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:04.185652659 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.185662671 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 2(READY) successfully
0:00:04.185674365 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:04.185684463 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:04.185700971 74 0x564785920c00 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func: getting state
Setting pipeline to NULL …
0:00:04.185730124 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:18.876859867 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:18.876888567 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:18.876913259 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesink0’ changed state to 1(NULL) successfully
0:00:18.876931490 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<avdec_h264-0> current READY pending VOID_PENDING, desired next NULL
0:00:18.876945487 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<avdec_h264-0> completed state change to NULL
0:00:18.876953565 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<avdec_h264-0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:18.876961103 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘avdec_h264-0’ changed state to 1(NULL) successfully
0:00:18.876969945 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:18.876981488 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:18.876992486 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:18.877001974 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 1(NULL) successfully
0:00:18.877011517 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:18.877020912 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:18.877031319 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:18.877042459 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘queue0’ changed state to 1(NULL) successfully
0:00:18.877053927 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:18.877066269 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:18.877076820 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:18.877083516 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘qtdemux0’ changed state to 1(NULL) successfully
0:00:18.877092131 74 0x564785920c00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:18.877100070 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:18.877107356 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:18.877114816 74 0x564785920c00 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘filesrc0’ changed state to 1(NULL) successfully
0:00:18.877150151 74 0x564785920c00 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:18.877159821 74 0x564785920c00 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
Freeing pipeline …
0:00:18.877191852 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking avdec_h264-0:src(0x564785b571a0) and filesink0:sink(0x564785b573f0)
0:00:18.877206162 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked avdec_h264-0:src and filesink0:sink
0:00:18.877217848 74 0x564785920c00 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “filesink0”
0:00:18.877234972 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x564785c240e0 dispose
0:00:18.877243216 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘sink’
0:00:18.877251625 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x564785c240e0 parent class dispose
0:00:18.877259436 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x564785c240e0 finalize
0:00:18.877266727 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x564785c240e0 finalize parent
0:00:18.877276964 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking h264parse0:src(0x564785b56d00) and avdec_h264-0:sink(0x564785b56f50)
0:00:18.877284428 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked h264parse0:src and avdec_h264-0:sink
0:00:18.877291048 74 0x564785920c00 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “avdec_h264-0”
0:00:18.877301724 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<avdec_h264-0> 0x564785c12fa0 dispose
0:00:18.877308699 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<avdec_h264-0> removing pad ‘sink’
0:00:18.877318754 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<avdec_h264-0> removing pad ‘src’
0:00:18.877327564 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<avdec_h264-0> 0x564785c12fa0 parent class dispose
0:00:18.877349490 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<avdec_h264-0> 0x564785c12fa0 finalize
0:00:18.877357995 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<avdec_h264-0> 0x564785c12fa0 finalize parent
0:00:18.877368660 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking queue0:src(0x564785b56860) and h264parse0:sink(0x564785b56ab0)
0:00:18.877377736 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked queue0:src and h264parse0:sink
0:00:18.877391540 74 0x564785920c00 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “h264parse0”
0:00:18.877401805 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x564785b6aa60 dispose
0:00:18.877406784 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘sink’
0:00:18.877416656 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘src’
0:00:18.877423577 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x564785b6aa60 parent class dispose
0:00:18.877847750 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x564785b6aa60 finalize
0:00:18.877856646 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x564785b6aa60 finalize parent
0:00:18.877866390 74 0x564785920c00 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “queue0”
0:00:18.877878646 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x564785b66110 dispose
0:00:18.877887091 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘sink’
0:00:18.877897358 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘src’
0:00:18.877904994 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x564785b66110 parent class dispose
0:00:18.877914874 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x564785b66110 finalize
0:00:18.877924582 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x564785b66110 finalize parent
0:00:18.877935093 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking filesrc0:src(0x564785b56170) and qtdemux0:sink(0x564785b563c0)
0:00:18.877945096 74 0x564785920c00 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked filesrc0:src and qtdemux0:sink
0:00:18.877952398 74 0x564785920c00 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “qtdemux0”
0:00:18.877963555 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x56478596e3f0 dispose
0:00:18.877968798 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘sink’
0:00:18.877978998 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x56478596e3f0 parent class dispose
0:00:18.877985058 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x56478596e3f0 finalize
0:00:18.877996132 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x56478596e3f0 finalize parent
0:00:18.878009342 74 0x564785920c00 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “filesrc0”
0:00:18.878018820 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x564785b541e0 dispose
0:00:18.878027959 74 0x564785920c00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘src’
0:00:18.878037144 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x564785b541e0 parent class dispose
0:00:18.878045701 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x564785b541e0 finalize
0:00:18.878054989 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x564785b541e0 finalize parent
0:00:18.878066439 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x564785c261e0 dispose
0:00:18.878091099 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x564785c261e0 parent class dispose
0:00:18.878102689 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x564785c261e0 finalize
0:00:18.878110539 74 0x564785920c00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x564785c261e0 finalize parent
0:00:18.878121131 74 0x564785920c00 INFO GST_INIT gst.c:1083:gst_deinit: deinitializing GStreamer
0:00:18.879638450 74 0x564785920c00 INFO GST_INIT gst.c:1231:gst_deinit: deinitialized GStreamer
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/streams# ll
total 4561324
drwxr-xrwx 1 root root 4096 May 12 18:00 ./
drwxr-xrwx 1 root root 4096 May 12 18:17 …/
-rw-r–r-- 1 root root 4488307200 May 12 18:24 output.file
-rw-rw-rw- 1 25011 dip 34952625 Aug 14 2019 sample_1080p_h264.mp4
-rw-rw-rw- 1 25011 dip 14018396 Aug 14 2019 sample_1080p_h265.mp4
-rw-rw-rw- 1 25011 dip 14759548 Aug 14 2019 sample_720p.h264
-rw-rw-rw- 1 25011 dip 50434312 Aug 14 2019 sample_720p.mjpeg
-rw-rw-rw- 1 25011 dip 15574709 Aug 14 2019 sample_720p.mp4
-rw-rw-rw- 1 25011 dip 27496987 Sep 17 2019 sample_cam5.mp4
-rw-rw-rw- 1 25011 dip 24999084 Aug 14 2019 sample_cam6.mp4
root@ip-10-255-254-21:/opt/nvidia/deepstream/deepstream-5.0/samples/streams# rm output.file
Solved the issue by using latest driver.
