Dual Monitor & Audio not working
My Second monitor does not get signal through its DVI Port & My audio from my second monitor & PC case does not work either. Here is my output of inxi -Fzxx
System:
  Kernel: 6.10.4-200.fc40.x86_64 arch: x86_64 bits: 64 compiler: gcc
    v: 2.41-37.fc40
  Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_wayland dm: 1: GDM
    2: SDDM note: stopped Distro: Fedora Linux 40 (Workstation Edition)
Machine:
  Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: M.D0
    date: 05/17/2021
CPU:
  Info: 12-core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
    rev: 0 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
  Speed (MHz): avg: 2484 high: 4343 min/max: 2200/4672 boost: enabled cores:
    1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200
    10: 4343 11: 2175 12: 3545 13: 2797 14: 2200 15: 2200 16: 2200 17: 2200
    18: 2200 19: 3598 20: 2200 21: 2200 22: 3617 23: 2151 24: 2200
    bogomips: 182388
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Graphics:
  Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] driver: nvidia v: 555.58.02
    arch: Turing pcie: speed: 8 GT/s lanes: 16 ports: active: none
    off: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 26:00.0 chip-ID: 10de:1f06
  Display: wayland server: X.org v: 1.20.14 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 3840x1080
    display-ID: 0
  Monitor-1: DVI-D-1 pos: right res: 1920x1080 size: N/A
  Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A
  API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: swrast
    gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11:
    drv: zink inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060
    SUPER/PCIe/SSE2 display-ID: :0.0
  API: Vulkan v: 1.3.283 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: N/A device-ID: 10de:1f06 device: 1 type: cpu
    driver: N/A device-ID: 10005:0000
Audio:
  Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: speed: 8 GT/s lanes: 16 bus-ID: 26:00.1 chip-ID: 10de:10f9
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 28:00.4 chip-ID: 1022:1487
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 1-9:4 chip-ID: 0d8c:0005
  API: ALSA v: k6.10.4-200.fc40.x86_64 status: kernel-api
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 931.51 GiB used: 456.57 GiB (49.0%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
    speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 34.9 C
Partition:
  ID-1: / size: 929.91 GiB used: 456.22 GiB (49.1%) fs: btrfs dev: /dev/dm-0
    mapped: luks-699f94b8-5c7b-4629-b809-e4c36e94d587
  ID-2: /boot size: 973.4 MiB used: 341.6 MiB (35.1%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-3: /boot/efi size: 598.8 MiB used: 19 MiB (3.2%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-4: /home size: 929.91 GiB used: 456.22 GiB (49.1%) fs: btrfs
    dev: /dev/dm-0 mapped: luks-699f94b8-5c7b-4629-b809-e4c36e94d587
Swap:
  ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) priority: 100
    dev: /dev/zram0
Sensors:
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 32 GiB available: 31.26 GiB used: 3.97 GiB (12.7%)
  Processes: 527 Power: uptime: 9m wakeups: 0 Init: systemd v: 255
    target: graphical (5) default: graphical
  Packages: pm: flatpak pkgs: 53 Compilers: gcc: 14.2.1 Shell: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
I have reported this problem in the 555 release feedback & discussion board as well, but this problem has been going on for a month and seems to have not been fixed yet.
