However, when I try to install the OTA update with sudo /nv_ota_start.sh ./ota_payload_package.tar.gz it errors out with No Space Left on device for a bunch of things.
Is the command flashing your board successfully?
If so, please share the lsblk result on your board.
Your command is used for preparing the image-based OTA package for external NVMe drive.
Do you connect and flash an NVMe SSD before running nv_ota_start.sh?
Thanks @KevinFFF ! I figured the rootfs is on NVME, but wondering why that is since I flashed it using the internal flag. It doesn’t boot without an NVME (if I physically remove it, it flashes but has a kernel panic) - is there a way to keep the rootfs on the MMC and use the NVME purely as a data partition? /data instead of /.
user@tegra-ubuntu:/tmp/ota/ota_root$ sudo ./nv_ota_start.sh ./ota_payload_package.tar.gz
Current rootfs is on /dev/nvme0n1
init_ota_log /ota_log
Create log file at /ota_log/ota_20240502-160806.log
OTA_LOG_FILE=/ota_log/ota_20240502-160806.log
Extract ./ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
3701--0005--1--jetson-agx-orin-devkit-
Info. Installing mtdblock.
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
TNSPEC 3701-500-0005-M.0-1-0-jetson-agx-orin-devkit-
COMPATIBLE_SPEC 3701--0005--1--jetson-agx-orin-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3701--0005--1--jetson-agx-orin-devkit-.
Info. Uninstalling mtdblock.
check_prerequisites
decompress_ota_package ota_package.tar /ota_work
decompress_ota_package: start at Thu 02 May 2024 04:08:24 PM UTC
Sha1 checksum for /ota_work/ota_package.tar (0824127352bbe1c860c11b7f7bc48f71884e7871) matches
decompress_ota_package: end at Thu 02 May 2024 04:08:33 PM UTC
nv_ota_update_without_layout_change.sh
Command: nv_ota_update_without_layout_change.sh
check_target_board /ota_work TARGET_BOARD
get_chip_id CHIP_ID
ota_choose_images /ota_work
COMPATIBLE_SPEC=3701--0005--1--jetson-agx-orin-devkit-
TEGRA_CHIPID=0x23
_BOARD_SPEC_NAME=3701--0005-
Copy files from ./images-R35-ToT/3701--0005-/ to ./images-R35-ToT/
is_rootfs_a_b_enabled ROOTFS_AB_ENABLED ROOTFS_CURRENT_SLOT
ROOTFS_AB_ENABLED=1
ROOTFS_CURRENT_SLOT=0
is_rootfs_encryption_enabled ROOTFS_ENC_ENABLED
ROOTFS_ENC_ENABLED=0
get_update_slot UPDATE_SLOT
UPDATE_SLOT=B
get_update_control /ota_work UPDATE_BOOTLOADER UPDATE_ROOTFS
UPDATE_BOOTLOADER=1, UPDATE_ROOTFS=1
select_uefi_capsule /ota_work
check_bsp_version /ota_work BASE_VERSION
User release version in system: 0.0
User release version in OTA package: 0.0
User version is to be upgrade from 0.0 to 0.0
update_misc_partitions /ota_work
update_partition_with_alt /ota_work recovery
install_partition_with_alt /ota_work/external_device/images-R35-ToT recovery
prerequisite_check recovery
Verifying image /ota_work/external_device/images-R35-ToT/recovery.img with sha1 chksum file /tmp/sha1sum.tmp
Sha1 checksum for /ota_work/external_device/images-R35-ToT/recovery.img (0baf426682a422c8b38424a77a91d7c624c253a1) matches
update_specified_partitions_alt recovery /ota_work/external_device/images-R35-ToT/recovery.img /tmp/sha1sum.tmp
Start checking update state.
Dump recovery of 47421440 into /tmp/recovery_image.tmp.
Reading 47421440 bytes from /dev/nvme0n1p8: 1KB block=46310 remainder=0 offset=47421440
Dump recovery_alt of 47421440 into /tmp/recovery_alt_image.tmp.
Reading 47421440 bytes from /dev/nvme0n1p11: 1KB block=46310 remainder=0 offset=47421440
Dump whole recovery_alt partition into /tmp/recovery_alt_part.tmp.
Verifying image /tmp/recovery_image.tmp with sha1 chksum file /tmp/sha1sum.tmp
Sha1 checksum for /tmp/recovery_image.tmp (0baf426682a422c8b38424a77a91d7c624c253a1) matches
recovery contains the image to be updated already.
Verifying image /tmp/recovery_alt_image.tmp with sha1 chksum file /tmp/sha1sum.tmp
Sha1 checksum for /tmp/recovery_alt_image.tmp (e09731a46f08a2b2ceaf63a78b191907c06f57d8 != 0baf426682a422c8b38424a77a91d7c624c253a1) does not match
recovery_alt does not contain the image to be updated.
Sha1sum of erased recovery: f6a74cc76e9b1b76ffb631ac46509bd524d5a37c
Create sha1sum of erased recovery to /ota_work/external_device/images-R35-ToT/recovery.img.erased.sha1sum
Verifying image /tmp/recovery_alt_part.tmp with sha1 chksum file /ota_work/external_device/images-R35-ToT/recovery.img.erased.sha1sum
Sha1 checksum for /tmp/recovery_alt_part.tmp (f6a74cc76e9b1b76ffb631ac46509bd524d5a37c) matches
recovery_alt is empty.
Current update state: S4.
The recovery is already updated. Skip update process.
Updating recovery and recovery_alt partitions done
update_partition_with_alt /ota_work recovery-dtb
install_partition_with_alt /ota_work/external_device/images-R35-ToT recovery-dtb
prerequisite_check recovery-dtb
Verifying image /ota_work/external_device/images-R35-ToT/tegra234-p3701-0005-p3737-0000.dtb.rec with sha1 chksum file /tmp/sha1sum.tmp
Sha1 checksum for /ota_work/external_device/images-R35-ToT/tegra234-p3701-0005-p3737-0000.dtb.rec (44b85b40d595a670bf2ebabcf067d3970cb140b3) matches
update_specified_partitions_alt recovery-dtb /ota_work/external_device/images-R35-ToT/tegra234-p3701-0005-p3737-0000.dtb.rec /tmp/sha1sum.tmp
Dump recovery-dtb of 439483 into /tmp/recovery-dtb_image.tmp.
Reading 439483 bytes from /dev/nvme0n1p9: 1KB block=429 remainder=187 offset=439296
Dump recovery-dtb_alt of 439483 into /tmp/recovery-dtb_alt_image.tmp.
Reading 439483 bytes from /dev/nvme0n1p12: 1KB block=429 remainder=187 offset=439296
Dump whole recovery-dtb_alt partition into /tmp/recovery-dtb_alt_part.tmp.
Verifying image /tmp/recovery-dtb_image.tmp with sha1 chksum file /tmp/sha1sum.tmp
Sha1 checksum for /tmp/recovery-dtb_image.tmp (44b85b40d595a670bf2ebabcf067d3970cb140b3) matches
recovery-dtb contains the image to be updated already.
Verifying image /tmp/recovery-dtb_alt_image.tmp with sha1 chksum file /tmp/sha1sum.tmp
Sha1 checksum for /tmp/recovery-dtb_alt_image.tmp (4bb8f64c89477efce1227434517562e8c744fa22 != 44b85b40d595a670bf2ebabcf067d3970cb140b3) does not match
recovery-dtb_alt does not contain the image to be updated.
Sha1sum of erased recovery-dtb: 6a521e1d2a632c26e53b83d2cc4b0edecfc1e68c
Create sha1sum of erased recovery-dtb to /ota_work/external_device/images-R35-ToT/tegra234-p3701-0005-p3737-0000.dtb.rec.erased.sha1sum
Verifying image /tmp/recovery-dtb_alt_part.tmp with sha1 chksum file /ota_work/external_device/images-R35-ToT/tegra234-p3701-0005-p3737-0000.dtb.rec.erased.sha1sum
Sha1 checksum for /tmp/recovery-dtb_alt_part.tmp (6a521e1d2a632c26e53b83d2cc4b0edecfc1e68c) matches
recovery-dtb_alt is empty.
The recovery-dtb is already updated. Skip update process.
Updating recovery-dtb and recovery-dtb_alt partitions done
update_partition_with_alt /ota_work esp
install_partition_with_alt /ota_work/external_device/images-R35-ToT esp
prerequisite_check esp
The /ota_work/external_device/images-R35-ToT/esp.img for partition esp is not found
Skip updating esp partition as no valid image is found
update_rootfs /ota_work
update_rootfs_with_a_b_enabled /ota_work
update_rootfs_runtime /ota_work B external_device
Use rootfs updater: /ota_work/nv_ota_rootfs_updater.sh
Updating rootfs by running command: /ota_work/nv_ota_rootfs_updater.sh -p /dev/mmcblk0p2 -d /ota_work /ota_work/external_device/system.img
update_rootfs_partition /ota_work/external_device/system.img /dev/mmcblk0p2 /ota_work
Validate /ota_work/external_device/system.img
Mounting rootfs partition /dev/mmcblk0p2 ...
Backing up files into /ota_work
back_up_file /tmp/updater/boot/extlinux/extlinux.conf /ota_work/extlinux.conf.ota_backup
The file /tmp/updater/boot/extlinux/extlinux.conf has been backed up to /ota_work/extlinux.conf.ota_backup
back_up_file /tmp/updater/etc/nv_boot_control.conf /ota_work/ota_nv_boot_control.conf
The file /tmp/updater/etc/nv_boot_control.conf has been backed up to /ota_work/ota_nv_boot_control.conf
back_up_file /tmp/updater/etc/fstab /ota_work/fstab.ota_backup
Warning: the specified file /tmp/updater/etc/fstab is not found
ota_backup_customer_files /ota_work /tmp/updater
Backing up specified files listed in /ota_work/ota_backup_files_list.txt
Nothing needs to be backed up in /ota_work/ota_backup_files_list.txt
Deleting directories/files in the /dev/mmcblk0p2
Entering /tmp/updater
find "/tmp/updater" -maxdepth 1 ! -name "ota*" -exec rm -rf {} \;
Exiting /tmp/updater
Decompress rootfs image into /dev/mmcblk0p2 ...
tar -xpf /ota_work/external_device/system.img --checkpoint=10000 --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/updater/
tar: ./usr/local/go/api: Cannot mkdir: No space left on device
tar: ./usr/local/go/api/go1.19.txt: Cannot open: No such file or directory
tar: ./usr/local/go/api/go1.txt: Cannot open: No such file or directory
tar: ./usr/local/go/api/go1.14.txt: Cannot open: No such file or directory
tar: ./usr/local/go/api/except.txt: Cannot open: No such file or directory
tar: ./usr/local/go/api/go1.3.txt: Cannot open: No such file or directory
tar: ./usr/local/go/api/go1.11.txt: Cannot open: No such file or directory
tar: ./usr/local/go/bin: Cannot mkdir: No space left on device
tar: ./usr/local/go/bin/gofmt: Cannot open: No such file or directory
^C
NOTE: I renamed the /tmp/mnt to /tmp/updater, but that isn’t the thing causing the issue since this issue existed previously too
The updates will update not just the jetpack, but other things as well, eg. proprietary company software. And trying to ship that via the image-based OTA.
If you want rootfs in internal eMMC and just want to use NVMe as storage, then you don’t need to flash NVMe.
You can just format the NVMe as ext4 and mount it after boot up.
sudo ROOTFS_AB=1 ROOTFS_ENC=1 ./flash.sh -i "encrypted.key" jetson-agx-orin-devkit internal should not flash on the NVME, right? I did this and the rootfs seems to be on the NVME partition. Cannot format that partition when / is mounted on there.
It either gives me a kernel panic, and editing the bootloader order doesn’t change anything, the rootfs is still on NVME, which means it will have all the bin util files. That aside, I don’t think that is the solution for “No space left on device” given I am flashing with internal flag and generating OTA with internal flag. Logs below for the panic incase necessary.
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
FDT /boot/dtb/kernel_tegra234-p3701-0005-p3737-0000.dtb
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=b5a8d3e4-d91c-4ad9-8c7d-ed83a16d3111 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
# sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
# MENU LABEL backup kernel
# LINUX /boot/Image.backup
# FDT /boot/dtb/kernel_tegra234-p3701-0005-p3737-0000.dtb
# INITRD /boot/initrd
# APPEND ${cbootargs}
Is this PARTUUID from internal eMMC or NVMe on your board?
Can I clarify your use case again with you?
You want to use internal eMMC as rootfs device and also perform OTA update for internal eMMC.
External NVMe is just used as storage and it could be mounted after bootup.
If so, can you remove the NVMe and enter force-recovery state and run the following command to flash your board?
$ sudo ./flash jetson-agx-orin-devkit mmcblk0p1
Please let me know if you can flash the board and boot up successfully.
My usecase is I don’t particularly care where the rootfs is stored, I want to have the NVME to store data that is persistent between upgrades, and I want to allow for encrypted OTA updated with an encrypted rootfs which has an A/B redundancy enabled.
Fair enough, I was just keeping it high level enough to communicate clearly my requirements wrt Jetson.
I think rootfs on mmcblk0 will be just fine! From what I understand UDA is the partition that is “left over”, for our case I think that will be nvme0. I do not want to put rootfs on NVME. I want to keep NVME purely for data storage that persists between OTA upgrades. As for the answers:
Actually, these 2 requirements are conflict.
If you want your data encrypted in NVMe SSD, then you should use NVMe as rootfs.
Disk-encryption feature is used to encrypt the rootfs.
It seems you are using R35.5 as your result of “cat /etc/nv_tegra_release”.
Do you want to perform image-based OTA update to the same R35.5 release?
May I know if you can boot up the board successfully after running the following command to flash your board?
(w/o connecting NVMe drive)
