david.L
February 10, 2022, 2:28am
1
Hi:
I want to test the OTA function of NX on NX-DEVKIT. My os is installed on nvme, and the system version is 32.6.
1.Generate the base recovery image and recovery DTB:
sudo ./tools/ota_tools/version_upgrade/build_base_recovery_image.sh jetson-xavier-nx-devkit R32-6 ${BASE_BSP} ${BASE_BSP}/rootfs ${TARGET_BSP}
2.Generate the OTA update payload package:
sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-xavier-nx-devkit R32-6
3.Unpack the OTA payload package and prepare to start OTA:
sudo ./nv_ota_start.sh /dev/mmcblk0 /ota/ota_payload_package.tar.gz
The result:
The board name in OTA package(jetson-xavier-nx-devkit) does not match current board(jetson-xavier-nx-devkit-qspi)
Failed to run "check_target_board /ota_work TARGET_BOARD"
Is this correct?
How did you set up your system to NVMe previously?
david.L
February 10, 2022, 3:13am
4
I used script nvsdkmanager_flash.sh.
sudo ./nvsdkmanager_flash.sh -s nvme0n1p1
Hi 529161095 ,
The nvsdkmanager_flash.sh script is use “jetson-xavier-nx-devkit-qspi ” config to flash image, so when you run the OTA update, you will get not match target_board errors.
There are two solution can fix this issue:
Replace jetson-xavier-nx-devkit-qspi to jetson-xavier-nx-devkit in /etc/nv_boot_control.conf as below:
TNSPEC 3668-200-0000-G.0-1-2-jetson-xavier-nx-devkit-nvme0n1p1
COMPATIBLE_SPEC 3668-100---1--jetson-xavier-nx-devkit-
TEGRA_CHIPID 0x19
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Use l4t_initrd_flash.sh script to flash image on NVMe.
example:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 90GiB --showlogs jetson-xavier-nx-devkit nvme0n1p1
Note: The -S size cannot be bigger than “num_sectors” * “sector_size”, please check README for more detail.
david.L
February 23, 2022, 5:55am
8
I used l4t_initrd_flash.sh script to flash image on NVMe.
2.The “/etc/nv_boot_control.conf” in nx-devkit :
TNSPEC 3668-200-0000-H.0-1-2-jetson-xavier-nx-devkit-qspi-internal
COMPATIBLE_SPEC 3668-100---1--jetson-xavier-nx-devkit-qspi-
TEGRA_CHIPID 0x19
I modified as you suggested:
TEGRA_CHIPID 0x19
3.start OTA
sudo ./nv_ota_start.sh /dev/nvme0n1 /ota/ota_payload_package.tar.gz
The logs is:
Command: ./nv_ota_start.sh /dev/nvme0n1 /ota/ota_payload_package.tar.gz
init_ota_log /ota_log
Create log file at /ota_log/ota_20220223-132941.log
OTA_LOG_FILE=/ota_log/ota_20220223-132941.log
Extract /ota/ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
check_prerequisites
get_chip_id chip_id
nv_ota_update_without_layout_change.sh /ota_work/ota_package.tar.gz
Command: nv_ota_update_without_layout_change.sh /ota_work/ota_package.tar.gz
decompress_ota_package /ota_work/ota_package.tar.gz /ota_work
decompress_ota_package: start at 2022年 02月 23日 星期三 13:30:48 CST
Sha1 checksum for /ota_work/ota_package.tar (e6b0363edf6764624033f91835a3cf08a7cb03d2) matches
decompress_ota_package: end at 2022年 02月 23日 星期三 13:33:19 CST
get_chip_id CHIP_ID
update_utilities_for_BUP_update /ota_work
enable_a_b_redundancy
Nvidia A/B-Redundancy Update tool Version 2.1
enabling A/B redundancy
A/B Redundancy has been enabled.
get_rootfs_a_b_enabled ROOTFS_AB_ENABLED UNIFIED_AB_ENABLED
ROOTFS_AB_ENABLED=0
UNIFIED_AB_ENABLED=0
check_bsp_version /ota_work BASE_VERSION
get_update_control /ota_work UPDATE_BOOTLOADER UPDATE_ROOTFS
UPDATE_BOOTLOADER=1, UPDATE_ROOTFS=1
update_bootloader /ota_work 0 0x19
get_update_slot bootloader 0 update_slot
update_slot=B
update_bootloader_with_UE /ota_work 0x19
verifying update
Verify bootloader update begins.
The rotate count has been restored.
The current slot 0 is marked as boot successful
SM: S1
The priority of current slot 0 has been restored.
Verify rootfs update begins.
RootFS A/B is not enabled, verification finishes.
Got payload file: /ota_work/bl_update_payload
current slot 0
SM: S11
Set slot 1 as unbootable and start updating.
Start running: /usr/sbin/nv_bootloader_payload_updater --no-dependent-partition /ota_work/bl_update_payload
Got update payload: /ota_work/bl_update_payload
Tegra User Block Device: /dev/disk/by-partlabel
Tegra Boot Block Device: /dev/mtdblock0
HEADER: MAGIC NVIDIA__BLOB__V2
HEX_VALUE 16909857
BLOB_SIZE 49900468
HEADER_SIZE 48
NUMBER_OF_ELEMENTS 29
HEADER_TYPE 0
UNCOMP_SIZE 49900468
MB1_RATCHET_LV 0
MTS_RATCHET_LV 0
ROLLBACK_FUSE_LV 0
Device TN Spec: 3668-200-0000-H.0-1-2-jetson-xavier-nx-devkit-nvme0n1p1
Device Compatible Spec: 3668-100---1--jetson-xavier-nx-devkit-
Device is fused board.
ENTRY_TABLE:
PART POS LEN VER TNSPEC TYPE UPDATABLE
spe-fw 3528 94960 12897 0 1
mb2 98488 181232 12897 0 1
cpu-bootloader 279720 469840 12897 0 1
secure-os 749560 410560 12897 0 1
bpmp-fw 1160120 856352 12897 0 1
eks 2016472 5136 12897 0 1
adsp-fw 2021608 81312 12897 0 1
rce-fw 2102920 272752 12897 0 1
mts-preboot 2375672 24016 12897 0 1
mts-mce 2399688 143200 12897 0 1
mts-proper 2542888 3430416 12897 0 1
sc7 5973304 65504 12897 0 1
bpmp-fw-dtb 6038808 199808 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 1
bpmp-fw-dtb 6238616 199808 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 0
bootloader-dtb 6438424 208272 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 1
bootloader-dtb 6646696 208272 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 0
VER 6854968 102 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 1
VER 6855070 102 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 0
mb1 6855172 249312 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 2 1
mb1 7104484 249312 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 2 0
BCT 7353796 2888 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 2 1
BCT 7356684 2888 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 2 0
MB1_BCT 7359572 30240 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 1
MB1_BCT 7389812 30240 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 0
MEM_BCT 7420052 198656 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 1
MEM_BCT 7618708 198656 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 0 0
kernel 7817364 41666560 12897 1 1
kernel-dtb 49483924 208272 12897 3668-100-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 1 1
kernel-dtb 49692196 208272 12897 3668-301-0000--1-2-jetson-xavier-nx-devkit-mmcblk0p1 1 0
Saving Entry table to /opt/ota_package/entry_table
spe-fw write: slot = 1 offset = 1572864 bytes = 94960
mb2 write: slot = 1 offset = 2097152 bytes = 181232
cpu-bootloader write: slot = 1 offset = 13500416 bytes = 469840
secure-os write: slot = 1 offset = 18874368 bytes = 410560
bpmp-fw write: slot = 1 offset = 29491200 bytes = 856352
eks write: slot = 1 offset = 21561344 bytes = 5136
adsp-fw write: slot = 1 offset = 22675456 bytes = 81312
rce-fw write: slot = 1 offset = 24772608 bytes = 272752
mts-preboot write: slot = 1 offset = 2424832 bytes = 24016
mts-mce write: slot = 1 offset = 2686976 bytes = 143200
mts-proper write: slot = 1 offset = 7077888 bytes = 3430416
sc7 write: slot = 1 offset = 11403264 bytes = 65504
bpmp-fw-dtb write: slot = 1 offset = 32112640 bytes = 199808
bootloader-dtb write: slot = 1 offset = 15400960 bytes = 208272
VER write: slot = 1 offset = 33357824 bytes = 102
MB1_BCT write: slot = 1 offset = 720896 bytes = 30240
MEM_BCT write: slot = 1 offset = 1048576 bytes = 198656
Writing 41666560 bytes to /dev/disk/by-partlabel/kernel_b for kernel
Writing 208272 bytes to /dev/disk/by-partlabel/kernel-dtb_b for kernel-dtb
Update bup successfully
SM: S12
Setting slot 1 as active boot slot
Got payload file: /ota_work/xusb_only_payload
current slot 0
SM: S11
Start running: /usr/sbin/nv_bootloader_payload_updater --no-dependent-partition /ota_work/xusb_only_payload
Got update payload: /ota_work/xusb_only_payload
HEX_VALUE 16909857
BLOB_SIZE 133288
HEADER_SIZE 48
NUMBER_OF_ELEMENTS 1
HEADER_TYPE 0
UNCOMP_SIZE 133288
MB1_RATCHET_LV 0
MTS_RATCHET_LV 0
ROLLBACK_FUSE_LV 0
ENTRY_TABLE:
xusb-fw 168 133120 12897 0 1
xusb-fw write: slot = 1 offset = 11862016 bytes = 133120
GetEntryTable failed for mb1
Skipping partition: mb1
GetEntryTable failed for BCT
Skipping partition: BCT
SM: S12
Copy /opt/ota_package/entry_table into /ota_work/entry_table.ota_backup
Bootloader on non-current slot(B) is updated
update_rootfs /ota_work 0
update_rootfs_with_a_b_disabled /ota_work
write_base_recovery /ota_work
Verifying image /ota_work/recovery.img.R32_3_4 with sha1 chksum file /ota_work/recovery.img.R32_3_4.sha1sum
Sha1 checksum for /ota_work/recovery.img.R32_3_4 (bcf90830ae148d659aef6d6a37545ba40a8819e4) matches
Verifying image /ota_work/recovery.dtb.R32_3_4 with sha1 chksum file /ota_work/recovery.dtb.R32_3_4.sha1sum
Sha1 checksum for /ota_work/recovery.dtb.R32_3_4 (e15debad31566963bc76df34731f0c7a32e1abc3) matches
Backed up kernel and kernel-dtb partition under /ota_work before writing them
Writing base recovery image into /dev/disk/by-partlabel/recovery
Read back base recovery image into /ota_work/image.tmp and verify it
Reading 49487872 bytes from /dev/disk/by-partlabel/recovery: 1KB block=48328 remainder=0 offset=49487872
Verifying image /ota_work/image.tmp with sha1 chksum file /ota_work/recovery.img.R32_3_4.sha1sum
Sha1 checksum for /ota_work/image.tmp (bcf90830ae148d659aef6d6a37545ba40a8819e4) matches
Writing base recovery dtb into /dev/disk/by-partlabel/recovery-dtb
Read back base recovery dtb into /ota_work/image.tmp and verify it
Reading 208928 bytes from /dev/disk/by-partlabel/recovery-dtb: 1KB block=204 remainder=32 offset=208896
Verifying image /ota_work/image.tmp with sha1 chksum file /ota_work/recovery.dtb.R32_3_4.sha1sum
Sha1 checksum for /ota_work/image.tmp (e15debad31566963bc76df34731f0c7a32e1abc3) matches
write_kernel_bootctrl /ota_work images-R32-ToT
512+0 records in
512+0 records out
262144 bytes (262 kB, 256 KiB) copied, 0.00452857 s, 57.9 MB/s
Backed up kernel-bootctrl partition under /ota_work before writing them
Writing bootctrl update file into /dev/disk/by-partlabel/kernel-bootctrl
Read back bootctrl update file into /ota_work/image.tmp and verify it
Reading 20 bytes from /dev/disk/by-partlabel/kernel-bootctrl: 1KB block=0 remainder=20 offset=0
backup_extlinux_conf /ota_work
Backing up /boot/extlinux/extlinux.conf
Rootfs is to be updated in recovery kernel once device is rebooted.
4.Then I restarted the device, but the device didn’t boot properly and kept restarting.
The log printed by the serial port is:
start-log.txt (94.5 KB)
Where is the problem?
Hi fnaiot ,
If you are using ‘l4t_initrd_flash.sh ’ script to flash image on NVMe, you don’t need modify ‘nv_boot_control.conf ’ file., the config file will show correct data.
What is your BASE_BSP, ToT_BSP and TARGET_BSP?
Are you flash r32.6.1 image on Xavier-NX-devkit?
david.L
February 23, 2022, 7:42am
10
carolyuu:
BASE_BSP
The BASE_BSP is the default build system by SDKManger.
ToT_BSP and TARGET_BSP is the same path.Compared with the BASE_BSP system, I modified the kernel, device tree, and installed some debs.
They can all be run individually.
I flash R32.6.1 image on NX-devkit.
I think the real thing to point out here is you have some customization and we don’t know whether those customization is causing this trouble.
From the beginning, @carolyuu is doing her test under different scenario as your case.
Please use pure jetpack to validate this problem first and then start your customization.
david.L
February 23, 2022, 10:49am
12
I use pure jetpack to test the OTA.
The BASE_BSP, ToT_BSP and TARGET_BSP is the same path.And it worked.
Maybe there is something wrong with my rootfs.
Is there a way to copy the system.img directly from the device and then make an OTA file?
david.L
February 24, 2022, 9:14am
13
I know why it fails.
Linux_for_Tegra/tools/kernel_flash/flash_l4t_nvme.xml
The “num_sectors” doesn’t match my nvme.
system
Closed
March 10, 2022, 9:15am
14
