Hi there,
I was Testing OTA, for both non-A/B enabled and A/B enabled devices, and seems that there is a way that could end up with a bricked device, requiring a flash from boot recovery mode,which can only be done from a x86 machine at the moment…
The steps are as follows:
- Flash a JAXi with ROOTFS_AB=1 for let’s say R32-5:
ROOTFS_AB=1 sudo -E --preserve-env=ROOTFS_AB ./flash.sh jetson-agx-xavier-industrial mmcblk0p1 - Generate recovery image (I believe this is not used if ROOTFS_AB=1, although it should have been in this case).:
sudo ./tools/ota_tools/version_upgrade/build_base_recovery_image.sh jetson-agx-xavier-industrial R32-7 ~/src_sen/vcpu-32.5.1/NL4T_LinuxForTegra{,/rootfs} ~/src_sen/vcpu/NL4T_LinuxForTegra - Generate payload package (here let’s omit ROOTFS_AB=1 by mistake):
sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-agx-xavier-industrial R32-7 - Copy across utilities and package:
scp ota_tools_R32.7.1_aarch64.tbz2 bootloader/jetson-agx-xavier-industrial/ota_payload_package.tar.gz sen@vpm628.local: - Extrack things and start OTA:
sudo mkdir /ota
sudo mv ota_payload_package.tar.gz /ota
mkdir l4t && tar -C l4t -xf ota_tools_R32.7.1_aarch64.tbz2
cd l4t/tools/ota_tools/version_upgrade
sudo ./nv_ota_start.sh /dev/mmcblk0 /ota/ota_payload_package.tar.gz - The following happens:
Command: ./nv_ota_start.sh /dev/mmcblk0 /ota/ota_payload_package.tar.gz
init_ota_log /ota_log
Creating log dir at /ota_log
Create log file at /ota_log/ota_20231113-134113.log
OTA_LOG_FILE=/ota_log/ota_20231113-134113.log
Extract /ota/ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
2888-600-0008--1-2-jetson-agx-xavier-industrial-
check_prerequisites
get_chip_id chip_id
decompress_ota_package ota_package.tar /ota_work
decompress_ota_package: start at Mon 13 Nov 13:42:39 GMT 2023
Sha1 checksum for /ota_work/ota_package.tar (72a15c1bc3f2a4d6a1d09e1894298e1f7ba5a818) matches
decompress_ota_package: end at Mon 13 Nov 13:43:32 GMT 2023
nv_ota_update_without_layout_change.sh
Command: nv_ota_update_without_layout_change.sh
check_target_board /ota_work TARGET_BOARD
get_chip_id CHIP_ID
update_utilities_for_BUP_update /ota_work
enable_a_b_redundancy
get_rootfs_a_b_enabled ROOTFS_AB_ENABLED UNIFIED_AB_ENABLED
ROOTFS_AB_ENABLED=1
UNIFIED_AB_ENABLED=1
get_update_control /ota_work UPDATE_BOOTLOADER UPDATE_ROOTFS
UPDATE_BOOTLOADER=1, UPDATE_ROOTFS=1
update_bootloader /ota_work 1 0x19
get_update_slot bootloader 1 update_slot
update_slot=A
update_bootloader_with_UE /ota_work 0x19
Remove exsting /opt/ota_package/entry_table
Nvidia A/B-Redundancy Update tool Version 2.1
verifying update with unified a/b enabled
Verify bootloader update begins.
The rotate count has been restored.
The current slot 1 is marked as boot successful
SM: S1
The priority of current slot 1 has been restored.
Got bl payload file: /ota_work/bl_only_payload
current slot 1
SM: S11
Set slot 0 as unbootable and start updating.
Start running: /usr/sbin/nv_bootloader_payload_updater --no-dependent-partition /ota_work/bl_only_payload
Start running: /opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.sh -c
Got update payload: /ota_work/bl_only_payload
Tegra User Block Device: /dev/disk/by-partlabel
Tegra Boot Block Device: /dev/mtdblock0
HEADER: MAGIC NVIDIA__BLOB__V2
HEX_VALUE 16909857
BLOB_SIZE 6925445
HEADER_SIZE 48
NUMBER_OF_ELEMENTS 19
HEADER_TYPE 0
UNCOMP_SIZE 6925445
MB1_RATCHET_LV 0
MTS_RATCHET_LV 0
ROLLBACK_FUSE_LV 0
Device TN Spec: 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1
Device Compatible Spec: 2888-600-0008--1-2-jetson-agx-xavier-industrial-
Device is fused board.
ENTRY_TABLE:
PART POS LEN VER TNSPEC TYPE UPDATABLE
spe-fw 2328 94960 12913 0 1
mb2 97288 181328 12913 0 1
cpu-bootloader 278616 471008 12913 0 1
secure-os 749624 410560 12913 0 1
bpmp-fw 1160184 856352 12913 0 1
eks 2016536 5136 12913 0 1
adsp-fw 2021672 81312 12913 0 1
rce-fw 2102984 271904 12913 0 1
mts-preboot 2374888 24016 12913 0 1
mts-mce 2398904 143200 12913 0 1
mts-proper 2542104 3430416 12913 0 1
sc7 5972520 65504 12913 0 1
bpmp-fw-dtb 6038024 182496 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 0 1
bootloader-dtb 6220520 221920 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 0 1
VER 6442440 101 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 0 1
mb1 6442541 250432 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 2 1
BCT 6692973 2888 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 2 1
MB1_BCT 6695861 30928 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 0 1
MEM_BCT 6726789 198656 12913 2888-600-0008-H.0-1-2-jetson-agx-xavier-industrial-mmcblk0p1 0 1
Saving Entry table to /opt/ota_package/entry_table
spe-fw write: slot = 0 offset = 2883584 bytes = 94960
mb2 write: slot = 0 offset = 3407872 bytes = 181328
cpu-bootloader write: slot = 0 offset = 14942208 bytes = 471008
secure-os write: slot = 0 offset = 19660800 bytes = 410560
bpmp-fw write: slot = 0 offset = 31719424 bytes = 856352
eks write: slot = 0 offset = 24903680 bytes = 5136
adsp-fw write: slot = 0 offset = 25427968 bytes = 81312
rce-fw write: slot = 0 offset = 27525120 bytes = 271904
mts-preboot write: slot = 0 offset = 3932160 bytes = 24016
mts-mce write: slot = 0 offset = 4456448 bytes = 143200
mts-proper write: slot = 0 offset = 4980736 bytes = 3430416
sc7 write: slot = 0 offset = 13369344 bytes = 65504
bpmp-fw-dtb write: slot = 0 offset = 34865152 bytes = 182496
bootloader-dtb write: slot = 0 offset = 18087936 bytes = 221920
VER write: slot = 0 offset = 37486592 bytes = 101
MB1_BCT write: slot = 0 offset = 786432 bytes = 30928
MB1_BCT write: slot = 0 offset = 851968 bytes = 30928
MB1_BCT write: slot = 0 offset = 983040 bytes = 30928
MB1_BCT write: slot = 0 offset = 1179648 bytes = 30928
MEM_BCT write: slot = 0 offset = 2359296 bytes = 198656
BCT slot = 0 write: offset = 16384 bytes = 2888
BCT slot = 0 write: offset = 0 bytes = 2888
BCT slot = 1 write: offset = 32768 bytes = 2888
BCT slot = 1 write: offset = 65536 bytes = 2888
BCT slot = 1 write: offset = 98304 bytes = 2888
BCT slot = 1 write: offset = 131072 bytes = 2888
BCT slot = 1 write: offset = 163840 bytes = 2888
BCT slot = 1 write: offset = 196608 bytes = 2888
BCT slot = 1 write: offset = 229376 bytes = 2888
Update bup successfully
SM: S12
Setting slot 0 as active boot slot
Unified bootloader and rootfs a/b is enabled, please reboot manually!
SMD base part CRC invalid
Primary SMD is corrupted!
Secondary SMD is corrupted!
Got payload file: /ota_work/xusb_only_payload
A/B has been disabled. Need to enable A/B.
Error: installing bootloader updates failed: -22
Failed to run "/usr/sbin/nv_update_engine -i bl-only --payload /ota_work/xusb_only_payload --no-reboot"
Failed to run "update_bootloader_with_UE /ota_work 0x19"
Failed to run "update_bootloader /ota_work 1 0x19"
- Try to reboot:
sudo reboot - Following happens:
[ 2686.467069] watchdog: watchdog0: watchdog did not stop!
[ 2686.484394] systemd-shutdow: 42 output lines suppressed due to ratelimiting
[ 2686.743906] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 2686.751294] reboot: Restarting system
����Shutdown state requested 1
Rebooting system ...
WARNING: at platform/drivers/cchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x1
[0000.059] I> rst_source : 0xb
[0000.062] I> rst_level : 0x1
[0000.066] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 64 MB
[0000.082] I> Qspi initialized successfully
[0000.086] E> LOADER: Failed to verify SMD.
[0000.090] I> Primary SMD copy is invalid, try with secondary copy..
[0000.096] E> LOADER: Failed to verify SMD.
[0000.100] E> LOADER: Failed to verify SMD & SMD_b.
[0000.104] E> Heap corrupted !!!
If I set the ROOTFS_AB=1 when generating the OTA, then it works, but without it, I would expect either a layout change or the SMD contents to be checked before writing them, or otherwise resored on error…
Let me know if there is a way to recover from this, other then testing all in a twin system…
