Dear SivaRamaKrishna,
Indeed you are right, the pitch mistake was a mistake, corrected.
Concerning the functions dwImageStreamer_returnReceivedCUDA and dwImageStreamer_waitPostedCPU I didn’t use them in fact. Because I dont really know how to use them. Should I call them once my first frame has been inferenced, and before the second frame can be converted ? I tried them in my source-code (before the return statement). As a consequence the program doens’t crash anymore after the first inference, still, I have a problem: the image seems duplicated three times during display and doens’t vary, when it should. I can’t display images using the [img] bbcode so I dont know how to show it to you.
I transmit you:
- The complete source-code of my NetworkStreamer class (frame retrieving and convertion)
- The sample calling its methods from the DriveNetApp class. (inferencing)
- The source code of the C++ class in charge of screenshoting a window’s desktop and transmit it via socket to the NetworkStreamer class on a linux desktop.
If you want to reproduce you will need two computer, Windows for the screenshot-streaming and Linux for the Driveworks and screen-shots reception. Or maybe you can simulate this behavior in another way, by grabbing an Interleaved RGB frame from a video file, then try to convert it to a planar RGB cuda frame.
==================================== [WINDOWS] StreamingClient =============================
—>>> StreamingClient.hpp:
// This code contains Ben Collado brain juice. Please make a donation.
//===> STANDARD <===
#include <vector>
#include <string>
#include <iostream>
//===> SOCKET COMM <===
#include <winsock.h>
#pragma comment(lib,"Ws2_32.lib")
#include <stdlib.h>
//===> OPENCV <===
#include "opencv2/opencv.hpp"
using namespace std;
using namespace cv;
class SocketClient
public:
//################################# M E T H O D S ##########################################
SocketClient();
SocketClient(string ip_address, int port);
~SocketClient();
void set_ip_address(string ip_address);
void set_server_port(int port);
int connect_to_serv();
int sendMessage(string message, const int BUFFERSIZE);
int sendMessage(char* imgData, size_t size);
void CheckErrorMessage();
void close();
protected:
int server_port;
int thisSocket;
struct sockaddr_in destination;
string ip_address;
//############################## V A R I A B L E S #########################################
—>>> StreamingClient.cpp:
#include <vector>
#include <string>
#include <iostream>
#include <stdlib.h>
//===> OPENCV <===
using namespace cv;
class SocketClient
public:
SocketClient();
~SocketClient();
void close();
protected:
int server_port;
int thisSocket;
string ip_address;
—>>> StreamingCLient.cpp:
// Streaming client.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <Windows.h>
#include "SocketClient.hpp"
Mat hwnd2mat(HWND hwnd)
HDC hwindowDC, hwindowCompatibleDC;
int height, width, srcheight, srcwidth;
HBITMAP hbwindow;
Mat src;
BITMAPINFOHEADER bi;
hwindowDC = GetDC(hwnd);
hwindowCompatibleDC = CreateCompatibleDC(hwindowDC);
SetStretchBltMode(hwindowCompatibleDC, COLORONCOLOR);
RECT windowsize; // get the height and width of the screen
GetClientRect(hwnd, &windowsize);
srcheight = windowsize.bottom;
srcwidth = windowsize.right;
height = 1080; //change this to whatever size you want to resize to
width = 1920;
src.create(height, width, CV_8UC4);
// create a bitmap
hbwindow = CreateCompatibleBitmap(hwindowDC, width, height);
bi.biSize = sizeof(BITMAPINFOHEADER); //http://msdn.microsoft.com/en-us/library/windows/window/dd183402%28v=vs.85%29.aspx
bi.biWidth = width;
bi.biHeight = -height; //this is the line that makes it draw upside down or not
bi.biPlanes = 1;
bi.biBitCount = 32;
bi.biCompression = BI_RGB;
bi.biSizeImage = 0;
bi.biXPelsPerMeter = 0;
bi.biYPelsPerMeter = 0;
bi.biClrUsed = 0;
bi.biClrImportant = 0;
// use the previously created device context with the bitmap
SelectObject(hwindowCompatibleDC, hbwindow);
// copy from the window device context to the bitmap device context
StretchBlt(hwindowCompatibleDC, 0, 0, width, height, hwindowDC, 0, 0, srcwidth, srcheight, SRCCOPY); //change SRCCOPY to NOTSRCCOPY for wacky colors !
GetDIBits(hwindowCompatibleDC, hbwindow, 0, height, src.data, (BITMAPINFO *)&bi, DIB_RGB_COLORS); //copy from hwindowCompatibleDC to hbwindow
// avoid memory leak
DeleteObject(hbwindow);
DeleteDC(hwindowCompatibleDC);
ReleaseDC(hwnd, hwindowDC);
return src;
int main()
//**********************< SOCKET CLIENT INSTANCIATION >***********************
string linux_desktop = "192.168.6.74";
int port = 27015;
int bytes = 0;
//======< Initialize the connection >======
SocketClient client = SocketClient(linux_desktop, port);
//======< Connect to the server >======
if (!client.connect_to_serv()){
cerr << "CONNECTION TO THE SERVER FAILED !\n";
client.CheckErrorMessage();
client.close();
return 0;
int width = 1920;
int height = 1080;
//**********************< SCREEN CAPTURE STUFF >***********************
//======< Get the desktop handle >======
HWND hwndDesktop = GetDesktopWindow();
Mat src;
namedWindow("output", WINDOW_NORMAL);
src = (src.reshape(1, 0));
int frameId = 1;
int key = 0;
bool micro_test = false;
if (micro_test){
src = hwnd2mat(hwndDesktop);
imshow("output", src);
waitKey(0);
//======< Display & Send the frame >======
while (key != 27)
//======< Convert the Window's handle to an OpenCV matrix >======
/*cout << ">>> Frame infos:\n"
<< "- Depth of the matrix = " << src.depth() << endl
<< "- Num rows = " << src.rows << endl
<< "- Num cols = " << src.cols << endl
<< "- Num channels = " << src.channels() << endl
<< "- Is continuous = " << src.isContinuous() << endl
<< "- Step = " << src.step.buf << " + " << src.step << endl
<< "- DataStart = " << src.datastart << endl
<< "- DataEnd = " << src.dataend << endl
<< "- DataLimit = " << src.datalimit << endl
<< src.flags << endl; */
//======< SEND THE FRAME >======
bytes = client.sendMessage((char *)src.data, src.total()*src.elemSize());
cout << "["<<frameId<<"]Num bytes sent = " << bytes << endl;
if (bytes < 0){
cerr << "ERROR WHEN SENDING FRAME -[" << frameId << "]-\n";
client.close();
return 0;
++frameId;
//imshow("output", src);
return 0;
====================================[LINUX] NetworkStreamer ===============================
---->> NetworkStreamer.hpp
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <unistd.h>
// Driveworks
#include <dw/core/Context.h>
#include <dw/sensors/Sensors.h>
#include <dw/sensors/camera/Camera.h>
#include <dw/image/Image.h>
#include <dw/image/FormatConverter.h>
#include <dw/isp/SoftISP.h>
// C++ Std
#include <memory>
#include <vector>
#include <type_traits>
#include <chrono>
#include <thread>
#include <string>
#include <iostream>
// Common
#include <framework/Checks.hpp>
#include <framework/SimpleStreamer.hpp>
#include <framework/SimpleFormatConverter.hpp>
#include <framework/SimpleCamera.hpp>
// Frame reception
#include "SocketServer.hpp"
// Frame management
using namespace cv;
namespace dw_samples
namespace common
class NetworkStreamer
public:
NetworkStreamer(int server_port, dwContextHandle_t app_context);
~NetworkStreamer();
void close();
//============ Initialization ===================
string establish_connection();
//============ I & O =============================
dwImageGeneric* readFrame();
struct Frame {
Frame(uint32_t width_, uint32_t height_):
width(width_),
height(height_),
data(width * height * 3) {
const uint32_t width;
const uint32_t height;
std::vector<uint8_t> data;
std::vector<uint8_t> R;
std::vector<uint8_t> G;
std::vector<uint8_t> B;
Frame& operator=(const Frame& rhs) = delete;
int frameId = 0;
protected:
// =========== Init the struct ===================
void initializeFrame();
void init_images_properties();
void init_streamers();
void init_converters();
int init_images();
//============ Conversions =======================
void copyConvert_matToFrame_interleaved(Mat *cv_frame);
void copyConvert_matToFrame_interleaved(uchar *frame_data);
void copyConvert_matToFrame_planar(uchar *frame_data);
//=============== Global stuff ========================
dwContextHandle_t app_context;
//=============== General Stuff =======================
uint32_t width = 1920;
uint32_t height = 1080;
int channels = 3;
// Is a new frame available
bool frame_is_pending;
// Temp frame
Frame temp_frame = Frame(width, height);
//=============== Network Stuff =======================
int server_port;
string client_address;
// Server
SocketServer *Server;
//=============== OpenCV Stuff ========================
Mat cv_frame;
//======== DriveWorks Frame management ===============
int frameID;
//*** Properties of the input, display, processed image
dwImageProperties input_properties{}; //CPU-RGB
dwImageProperties cuda_RGB2_properties{}; //CUDA-RGB
dwImageProperties cuda_RGB_properties{}; //CPU-RGB with planeCount =3 & pxlType = FLOAT16
//*** Image containers
dwImageCPU cpu_RGB_FRAME{};
dwImageCUDA *cuda_RGB_FRAME;
//*** Image converters
std::unique_ptr<GenericSimpleFormatConverter> RGBuint8_to_RGBfp16_converter;
//*** Image streamers (CPU->CUDA)
dwImageStreamerHandle_t CPU_to_CUDA_streamer = DW_NULL_HANDLE;
---->> NetworkStreamer.cpp :
#include "NetworkStreamer.hpp"
namespace common
//=================== CONSTRUCTORS & GETTERS ===============
NetworkStreamer::NetworkStreamer(int server_port, dwContextHandle_t app_context){
this->server_port = server_port;
this->app_context = app_context;
frameId = 0;
cout<<"\n====================================\n";
cout<<">>> WAITING FOR CLIENT CONNECTION !\n";
cout<<"======================================\n";
Server = new SocketServer();
Server->create_SocketServer();
initializeFrame();
init_converters();
init_streamers();
if (not init_images()) cout<<"Images memory allocations failed !!!\n"<<endl;
NetworkStreamer::~NetworkStreamer(){
void NetworkStreamer::close(){
Server->closeServer();
delete(Server);
dwImageStreamer_release(&CPU_to_CUDA_streamer);
dwImageCPU_destroy(&cpu_RGB_FRAME);
//========================== P U B L I C =========================
//####### networking stuff: create socket , connect ###############
string NetworkStreamer::establish_connection(){
// Connect with the streaming client
if (not Server->waitForConnection()){
throw std::runtime_error("[SocketServer] Error when establishing the connection !");
return "ERROR";
client_address = Server->get_client_address();
return client_address;
//=*=*=*=*=*=*=*=*=*=*|| Catch a frame ||*=*=*=*=*=*=*=*=*==*=*
dwImageGeneric* NetworkStreamer::readFrame()
//=====< Retrieve the RGBQUAD-encoded frame >=====
int frame_byte_size = width*height*4; //The input RGB image has one temp pixel channel
cout<< ">>> Waiting frame ["<<frameId<<"]\n";
uchar frame_data[frame_byte_size];
int bytes = Server->receiveData(frame_data, frame_byte_size);
if (bytes == 0) {
std::cout << "Camera reached end of stream." << std::endl;
else if (bytes == -1) {
cout<<"Error reading from stream ! (no frame)\n";
else if (bytes != frame_byte_size){
cout<<"Error reading from camera ! (corrupted frame)"<<endl;
cout<<"\nOOps\n";
//=====< First conversion phase >=====
try{
copyConvert_matToFrame_planar(frame_data);
catch (...){
cout<<"BORDEL DE MERDE\n";
cout<<"frame_data converted to dwImageCPU"<<endl;
//====< Initialize the dwImages with their properties! >=====
dwImageCPU_create(&cpu_RGB_FRAME, &input_properties);
// Timestamp the dwImageCPU, using the global time base, and planar pixel layout
dwContext_getCurrentTime(&cpu_RGB_FRAME.timestamp_us, app_context);
cout<<"CPU frame initialized"<<endl;
cpu_RGB_FRAME.data[0] = &(temp_frame.R[0]);
cpu_RGB_FRAME.data[1] = &(temp_frame.G[0]);
cpu_RGB_FRAME.data[2] = &(temp_frame.B[0]);
cpu_RGB_FRAME.pitch[0] = width * 3;
cpu_RGB_FRAME.pitch[1] = width * 3;
cpu_RGB_FRAME.pitch[2] = width * 3;
cpu_RGB_FRAME.prop.width = width;
cpu_RGB_FRAME.prop.height = height;
//----------- STREAMING: RGB(cpu) => RGB(cuda) ---------------------------
// Post
dwStatus result = dwImageStreamer_postCPU(&cpu_RGB_FRAME, CPU_to_CUDA_streamer);
if(DW_SUCCESS != result) {
throw std::runtime_error("Failed to post the CPU_RGB image");
cout<<">>> POST(cpu->cuda) = "<<dwGetStatusName(result)<<endl;
// Receive converted
result = dwImageStreamer_receiveCUDA(&cuda_RGB_FRAME, 5000, CPU_to_CUDA_streamer);
throw std::runtime_error("Failed to receive the CUDA_RGB image");
cout<<">>> cuda_rgb_FRAME filled: "<<dwGetStatusName(result)<<endl;
//----------- CONVERSION: RGB(cuda)_uint8 => RGB(cuda)_fp16 ---------------------------
dwImageGeneric *imgInput = GenericImage::fromDW(cuda_RGB_FRAME);
dwImageGeneric *imgOutput = RGBuint8_to_RGBfp16_converter->convert( imgInput );
frameId++;
//====== Releases ====
// the UserSensor does not need returning of its frame, but we need to reclaim
// the resources from the streamer anyway
dwImageCPU* returnedFrame;
dwImageStreamer_waitPostedCPU(&returnedFrame, 32000, CPU_to_CUDA_streamer);
dwImageStreamer_returnReceivedCUDA(cuda_RGB_FRAME, CPU_to_CUDA_streamer);
return imgOutput;
//========================== P R I V A T E =======================
void NetworkStreamer::initializeFrame(){
for (uint32_t row = 0 ; row < height ; row++) {
for (uint32_t col = 0 ; col < width ; ++col) {
for(uint32_t ch = 0 ; ch < 3 ; ++ch) {
temp_frame.data[3*(row*width+col) + ch] = static_cast<uint8_t>(static_cast<int32_t>(row));
void NetworkStreamer::init_images_properties(){
//======< Input frame properties >======
input_properties.width = width;
input_properties.height = height;
input_properties.planeCount = 3;
input_properties.pxlType = DW_TYPE_UINT8;
input_properties.pxlFormat = DW_IMAGE_RGB;
input_properties.type = DW_IMAGE_CPU;
//=====< cuda_RGB_properties >=============
cuda_RGB_properties = input_properties;
cuda_RGB_properties.type = DW_IMAGE_CUDA;
//=====< cuda_RGB2_properties: FP16 >======
cuda_RGB2_properties = cuda_RGB_properties;
cuda_RGB2_properties.pxlType = DW_TYPE_FLOAT16;
void NetworkStreamer::init_converters(){
RGBuint8_to_RGBfp16_converter.reset( new GenericSimpleFormatConverter(cuda_RGB_properties, cuda_RGB2_properties, app_context) );
cout<<"<<< RGB_to_YUV converter initialized."<<endl;
void NetworkStreamer::init_streamers(){
dwImageStreamer_initialize(&CPU_to_CUDA_streamer,
&input_properties,
DW_IMAGE_CUDA,
app_context);
void NetworkStreamer::copyConvert_matToFrame_planar(uchar *frame_data){
uint32_t index_s;
//cout<<"Size of target vector = "<<temp_frame.data.size()<<"\n";
//cout<<"\nConverstart\n";
//cin.get();
//cout<<"CRASH TEST !"<<endl;
//cout<<frame_data[8294398]<<endl;
//cout<<temp_frame.data[6220799]<<endl;
//cin.get();
for (uint32_t col = 0 ; col < width ; col++) {
index_s = 4*(row*width+col);
temp_frame.R.push_back(static_cast<uint8_t>( frame_data[index_s]+0 ));
temp_frame.G.push_back(static_cast<uint8_t>( frame_data[index_s]+1 ));
temp_frame.B.push_back(static_cast<uint8_t>( frame_data[index_s]+2 ));
cout<<"NICE !!"<<endl;
void NetworkStreamer::copyConvert_matToFrame_interleaved(Mat *cv_frame){
cout<<"Size of source vector = "<<cv_frame->total()*cv_frame->elemSize()<<endl;
int index_d, index_s;
for(uint32_t ch = 0 ; ch < 3 ; ch++) {
index_d = 4*(row*width+col)+ch;
index_s = 3*(row*width+col)+ch;
temp_frame.data[index_s] = static_cast<uint8_t>( cv_frame->data[index_d] );
int NetworkStreamer::init_images(){
dwStatus success = dwImageCPU_create(&cpu_RGB_FRAME, &input_properties);
//success = dwImageCUDA_create(&cuda_RGB_FRAME, &cuda_RGB_properties, DW_IMAGE_CUDA_PITCH);
//success = dwImageCUDA_create(&cuda2_RGB_FRAME, &cuda2_RGB_properties, DW_IMAGE_CUDA_PITCH);
//success = dwImageCUDA_create(&cuda_RGBA_FRAME, &cuda_RGBA_properties, DW_IMAGE_CUDA_PITCH);
if (success != DW_SUCCESS) return 0;
return 1;
============================== DriveNetApp.cpp call ===========================================
void DriveNetApp::getNextFrame(dwImageCUDA** nextFrameCUDA, dwImageGL** nextFrameGL)
*nextFrameCUDA = GenericImage::toDW<dwImageCUDA>(camera->readFrame());
if (*nextFrameCUDA == nullptr) {
camera->resetCamera();
} else {
*nextFrameGL = streamerCUDA2GL->post(GenericImage::toDW<dwImageCUDA>(converterToRGBA->convert(GenericImage::fromDW(*nextFrameCUDA)) ));
Grab the frame from the network
void DriveNetApp::getNextFrame_from_network(dwImageCUDA** nextFrameCUDA, dwImageGL** nextFrameGL)
*nextFrameCUDA = GenericImage::toDW<dwImageCUDA>(networkStreamer->readFrame());
cout<<"===>> NEXTFRAMECUDA = NULLPTR !! <<===\n";
} else {
Thank you :)
