Hi
I want to get dwImageCUDA as input to TensorRT Model, and i refer to ./sample_camera_gmsl.But encounter some problem.
the code below is runNvMedia_pipeline() in ./sample_camera_gmsl
void runNvMedia_pipeline(WindowBase *window, dwRendererHandle_t renderer, dwContextHandle_t sdk,
dwSensorHandle_t cameraSensor, int cameraWidth, int cameraHeight)
// RGBA image pool for conversion from YUV camera output
NvMediaDevice *nvmedia;
dwContext_getNvMediaDevice(&nvmedia, sdk);
std::vector<dwImageNvMedia *> rgbaImagePool;
for (int i = 0; i < 4; ++i) {
NVM_SURF_FMT_DEFINE_ATTR(surfFormatAttrs);
NVM_SURF_FMT_SET_ATTR_RGBA(surfFormatAttrs, RGBA, UINT, 8, PL);
NvMediaSurfaceType type = NvMediaSurfaceFormatGetType(surfFormatAttrs,
NVM_SURF_FMT_ATTR_MAX);
NvMediaSurfAllocAttr surfAllocAttrs[8];
uint32_t numSurfAllocAttrs = 0;
surfAllocAttrs[0].type = NVM_SURF_ATTR_WIDTH;
surfAllocAttrs[0].value = cameraWidth;
surfAllocAttrs[1].type = NVM_SURF_ATTR_HEIGHT;
surfAllocAttrs[1].value = cameraHeight;
surfAllocAttrs[2].type = NVM_SURF_ATTR_CPU_ACCESS;
surfAllocAttrs[2].value = NVM_SURF_ATTR_CPU_ACCESS_CACHED;
surfAllocAttrs[3].type = NVM_SURF_ATTR_ALLOC_TYPE;
surfAllocAttrs[3].value = NVM_SURF_ATTR_ALLOC_ISOCHRONOUS;
numSurfAllocAttrs = 4;
dwImageNvMedia *rgbaImage = new dwImageNvMedia();
NvMediaImage *rgbaNvMediaImage;
rgbaNvMediaImage = NvMediaImageCreateNew(nvmedia, type, surfAllocAttrs,
numSurfAllocAttrs, 0);
dwImageNvMedia_setFromImage(rgbaImage, rgbaNvMediaImage);
rgbaImagePool.push_back(rgbaImage);
// format converter
dwImageProperties cameraImageProperties;
dwSensorCamera_getImageProperties(&cameraImageProperties, DW_CAMERA_PROCESSED_IMAGE, cameraSensor);
dwImageProperties displayImageProperties = cameraImageProperties;
displayImageProperties.pxlFormat = DW_IMAGE_RGBA;
displayImageProperties.planeCount = 1;
dwImageFormatConverterHandle_t yuv2rgba = DW_NULL_HANDLE;
dwStatus status = dwImageFormatConverter_initialize(&yuv2rgba,
cameraImageProperties.type,
sdk);
if (status != DW_SUCCESS) {
std::cerr << "Cannot initialize pixel format converter" << std::endl;
exit(1);
// image API translator
dwImageStreamerHandle_t nvm2gl = DW_NULL_HANDLE;
dwImageStreamer_initialize(&nvm2gl, &displayImageProperties, DW_IMAGE_GL, sdk);
dwImageStreamerHandle_t nvm2cuda = DW_NULL_HANDLE;
status = dwImageStreamer_initialize(&nvm2cuda, &cameraImageProperties, DW_IMAGE_CUDA, sdk);
std::cerr << "\n ERROR dwImageStreamer_initialize: " <<dwGetStatusName(status)<<std::endl;
// Start Sensor and Processing
dwCameraProperties cameraProperties;
dwSensorCamera_getSensorProperties(&cameraProperties, cameraSensor);
g_run = dwSensor_start(cameraSensor) == DW_SUCCESS;
// Message msg;
while (g_run && !window->shouldClose()) {
dwCameraFrameHandle_t frameHandle;
dwImageNvMedia *frame = nullptr;
uint32_t camera = 0u;
dwStatus status = dwSensorCamera_readFrame(&frameHandle, camera, 1000000, cameraSensor);
std::cout << "\n ERROR readFrame: " << dwGetStatusName(status) << std::endl;
continue;
if( cameraProperties.outputTypes & DW_CAMERA_PROCESSED_IMAGE) {
status = dwSensorCamera_getImageNvMedia(&frame, DW_CAMERA_PROCESSED_IMAGE, frameHandle);
if( status != DW_SUCCESS ) {
std::cout << "\n ERROR getImageNvMedia " << dwGetStatusName(status) << std::endl;
// get embedded lines
if( cameraProperties.outputTypes & DW_CAMERA_DATALINES) {
const dwImageDataLines* dataLines = nullptr;
status = dwSensorCamera_getDataLines(&dataLines, frameHandle);
// parse the data
if( status == DW_SUCCESS ) {
status = dwSensorCamera_parseDataNvMedia(&sensorData, dataLines, cameraSensor);
#if (VIBRANTE_PDK_MAJOR == 5)
#else
std::cout << "Exposure Time (s): " << sensorData.exposureMidpointTime << "\r";// std::endl;
#endif
} else {
std::cout << "Could not parse embedded data: " << dwGetStatusName(status) << "\r"; //std::endl;
} else {
std::cout << "Error getting datalines: " << dwGetStatusName(status) << "\r"; //std::endl;
// Convert from YUV to RGBA
if (frame && rgbaImagePool.size() > 0) {
dwImageNvMedia *rgbaImage = rgbaImagePool.back();
rgbaImagePool.pop_back();
//std::cout << " CONVERSION YUV->RGBA\n";
status = dwImageFormatConverter_copyConvertNvMedia(rgbaImage, frame, yuv2rgba);
std::cout << "\n ERROR copyConvert: " << dwGetStatusName(status) << std::endl;
} else {
// Send via ImageStreamer to get GL image back
status = dwImageStreamer_postNvMedia(rgbaImage, nvm2gl);
std::cout << "\n ERROR postNvMedia: " << dwGetStatusName(status) << std::endl;
} else {
dwImageGL *frameGL = nullptr;
status = dwImageStreamer_receiveGL(&frameGL, 60000, nvm2gl);
if (status == DW_SUCCESS && frameGL) {
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
// render received texture
dwRenderer_renderTexture(frameGL->tex, frameGL->target, renderer);
dwImageStreamer_returnReceivedGL(frameGL, nvm2gl);
dwImageCUDA *cudaImage = nullptr;
status = dwImageStreamer_receiveCUDA( &cudaImage, 600000, nvm2cuda);
if (status == DW_SUCCESS && cudaImage) {
dwImageStreamer_returnReceivedCUDA(cudaImage, nvm2cuda);
/////////////// insert cudaImage to TensorRT Model ///////////////
else{
std::cout << "\n ERROR dwImageStreamer_receiveCUDA: " << dwGetStatusName(status) << std::endl;
// any image returned back, we put back into the pool
dwImageNvMedia *retimg = nullptr;
dwImageStreamer_waitPostedNvMedia(&retimg, 33000, nvm2gl);
if (retimg)
rgbaImagePool.push_back(retimg);
dwSensorCamera_returnFrame(&frameHandle);
if (window)
window->swapBuffers();
dwSensor_stop(cameraSensor);
dwImageStreamer_release(&nvm2gl);
for (auto frame : rgbaImagePool) {
NvMediaImageDestroy(frame->img);
delete frame;
dwImageFormatConverter_release(&yuv2rgba);
I try to get dwImageCUDA by insert some code at line 58~62 and line 137~148 . But i got error as below. Thank u ~~~~
ERROR dwImageStreamer_reveiveCUDA: DW_TIME_OUT
ImageStreamer: cannot receive, EGLstream busy
when i add
status = dwImageStreamer_postNvMedia(rgbaImage, nvm2cuda);
before dwImageStreamer_receiveCUDA(), it always show error type incompatible.
