DW_INTERNAL_ERROR on dwImageStreamer_producerSend call
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.0.8846
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to composite 4 camera images onto 1 image, 1920x1208 resolution cameras tiled 2x2 so the resulting image is 3840x2416. Below is my kernel for mixing images.
__global__ void kernel(uint16_t* dimage, size_t dpitch, const uint32_t dwidth, const uint32_t dheight,
                       uint16_t* simage1, uint16_t* simage2, uint16_t* simage3, uint16_t* simage4, uint8_t size, size_t spitch, const uint32_t swidth, const uint32_t sheight)
    const uint32_t tidx = blockDim.x * blockIdx.x + threadIdx.x;
    const uint32_t tidy = blockDim.y * blockIdx.y + threadIdx.y;
    const uint32_t sIdx = (uint32_t)(tidy / sheight)*2 + (uint32_t)(tidx / swidth); // 2 image per row
    if (tidx >= dwidth || tidy >= dheight || sIdx >= size) return;
    const uint32_t colIdx = tidx % swidth;
    const uint32_t rowIdx = tidy % sheight;
    if (sIdx == 0) {
      dimage[tidy*dpitch + 4*tidx+0] = simage1[rowIdx*spitch + 4*colIdx+0];
      dimage[tidy*dpitch + 4*tidx+1] = simage1[rowIdx*spitch + 4*colIdx+1];
      dimage[tidy*dpitch + 4*tidx+2] = simage1[rowIdx*spitch + 4*colIdx+2];
      dimage[tidy*dpitch + 4*tidx+3] = simage1[rowIdx*spitch + 4*colIdx+3];
    } else if (sIdx == 1) {
      dimage[tidy*dpitch + 4*tidx+0] = simage2[rowIdx*spitch + 4*colIdx+0];
      dimage[tidy*dpitch + 4*tidx+1] = simage2[rowIdx*spitch + 4*colIdx+1];
      dimage[tidy*dpitch + 4*tidx+2] = simage2[rowIdx*spitch + 4*colIdx+2];
      dimage[tidy*dpitch + 4*tidx+3] = simage2[rowIdx*spitch + 4*colIdx+3];
    } else if (sIdx == 2) {
      dimage[tidy*dpitch + 4*tidx+0] = simage3[rowIdx*spitch + 4*colIdx+0];
      dimage[tidy*dpitch + 4*tidx+1] = simage3[rowIdx*spitch + 4*colIdx+1];
      dimage[tidy*dpitch + 4*tidx+2] = simage3[rowIdx*spitch + 4*colIdx+2];
      dimage[tidy*dpitch + 4*tidx+3] = simage3[rowIdx*spitch + 4*colIdx+3];
    } else {
      dimage[tidy*dpitch + 4*tidx+0] = simage4[rowIdx*spitch + 4*colIdx+0];
      dimage[tidy*dpitch + 4*tidx+1] = simage4[rowIdx*spitch + 4*colIdx+1];
      dimage[tidy*dpitch + 4*tidx+2] = simage4[rowIdx*spitch + 4*colIdx+2];
      dimage[tidy*dpitch + 4*tidx+3] = simage4[rowIdx*spitch + 4*colIdx+3];
My kernel call
uint32_t iDivUp(const uint32_t a, const uint32_t b)
    return ((a % b) != 0U) ? ((a / b) + 1U) : (a / b);
void generateImage(dwImageHandle_t dimage, dwImageHandle_t *simage, const uint8_t size)
    dwImageProperties dprop, sprop;
    dwImage_getProperties(&dprop, dimage);
    dwImage_getProperties(&sprop, *simage);
    if (dprop.format != DW_IMAGE_FORMAT_RAW_UINT16 || sprop.format != DW_IMAGE_FORMAT_RAW_UINT16) {
        throw std::runtime_error("unsupported format in image samples generateImage");
    if (dprop.type == DW_IMAGE_CUDA && sprop.type == DW_IMAGE_CUDA) {
        dwImageCUDA *dimgCUDA, *simgCUDA;
        dwImage_getCUDA(&dimgCUDA, dimage);
        uint16_t **simage_ = (uint16_t **) malloc(sizeof(uint16_t *) * size);
        for (uint8_t i = 0; i < size; ++i) {
          dwImage_getCUDA(&simgCUDA, simage[i]);
          simage_[i] = static_cast<uint16_t*>(simgCUDA->dptr[0]);
        dim3 numThreads = dim3(32, 4, 1);
        kernel <<<dim3(iDivUp(dprop.width, numThreads.x),
                       iDivUp(dprop.height, numThreads.y)),
                numThreads >>>(static_cast<uint16_t*>(dimgCUDA->dptr[0]), dimgCUDA->pitch[0], dprop.width, dprop.height,
                               static_cast<uint16_t*>(simage_[0]), static_cast<uint16_t*>(simage_[1]), static_cast<uint16_t*>(simage_[2]), static_cast<uint16_t*>(simage_[3]), size, simgCUDA->pitch[0], sprop.wid$
        dwTime_t timestamp;
        dwImage_getTimestamp(&timestamp, *simage);
        dwImage_setTimestamp(timestamp, dimage);
    } else {
        throw std::runtime_error("unsupported type in image samples generateImage");
Both the kernel and kernel call are from example image_streamer_simple.
Initializing SoftISP
  m_ispOutput = DW_SOFTISP_PROCESS_TYPE_DEMOSAIC | DW_SOFTISP_PROCESS_TYPE_TONEMAP;
  // initializes software ISP for processing RAW RCCB images
  // - the SensorCamera module
    dwSoftISPParams softISPParams;
//    CHECK_DW_ERROR(dwSoftISP_initParamsFromCamera(&softISPParams, &m_cameraProperties));
    softISPParams.cameraType = DW_CAMERA_GENERIC;
    softISPParams.cameraRawFormat = DW_CAMERA_RAW_FORMAT_CRBC;
    softISPParams.cameraRevision = 0;
    softISPParams.method = DW_TONEMAP_METHOD_AGTM;
    softISPParams.width  = 3840;
    softISPParams.height = 2416;
    // format => CRBC
    CHECK_DW_ERROR(dwSoftISP_initialize(&m_isp, &softISPParams, m_sdk));
    CHECK_DW_ERROR(dwSoftISP_setCUDAStream(m_stream, m_isp));
    //CHECK_DW_ERROR(dwSoftISP_setDemosaicMethod(DW_SOFTISP_DEMOSAIC_METHOD_DOWNSAMPLE, m_isp));
    //CHECK_DW_ERROR(dwSoftISP_setDenoiseMethod(DW_SOFTISP_DENOISE_METHOD_NONE, m_isp));
    CHECK_DW_ERROR(dwSoftISP_setDemosaicMethod(DW_SOFTISP_DEMOSAIC_METHOD_INTERPOLATION, m_isp));
    CHECK_DW_ERROR(dwSoftISP_setDenoiseMethod(DW_SOFTISP_DENOISE_METHOD_BILATERAL, m_isp));
    // we need to allocate memory for a demosaic image and bind it to the ISP
    dwImageProperties rcbProperties{};
    if (m_ispOutput & DW_SOFTISP_PROCESS_TYPE_DEMOSAIC) {
      // getting the properties directly from the ISP
      CHECK_DW_ERROR(dwSoftISP_getDemosaicImageProperties(&rcbProperties, m_isp));
      CHECK_DW_ERROR(dwImage_create(&m_rcbImage, rcbProperties, m_sdk));
      CHECK_DW_ERROR(dwImage_getCUDA(&m_rcbCUDAImage, m_rcbImage));
      // bind the image as the output for demosaic process to the ISP, will be filled at the call of
      // dwSoftISP_processDeviceAsync
      CHECK_DW_ERROR(dwSoftISP_bindOutputDemosaic(m_rcbCUDAImage, m_isp));
    // in order to visualize we prepare the properties of the tonemapped image
    dwImageProperties rgbaImageProperties = rcbProperties;
    rgbaImageProperties.format = DW_IMAGE_FORMAT_RGBA_UINT8;
    rgbaImageProperties.type = DW_IMAGE_CUDA;
    dwImageProperties mixImageProperties = rgbaImageProperties;
    mixImageProperties.format = DW_IMAGE_FORMAT_RAW_UINT16;
    mixImageProperties.type = DW_IMAGE_CUDA;
    CHECK_DW_ERROR(dwImage_create(&m_mixImage, mixImageProperties, m_sdk));
    // allocate the rgba image
    CHECK_DW_ERROR(dwImage_create(&m_rgbaImage, rgbaImageProperties, m_sdk));
    CHECK_DW_ERROR(dwImage_getCUDA(&m_rgbaCUDAImage, m_rgbaImage));
    CHECK_DW_ERROR(dwSoftISP_bindOutputTonemap(m_rgbaCUDAImage, m_isp));
    CHECK_DW_ERROR(dwImageStreamer_initialize(&m_streamerCUDAtoCPU, &rgbaImageProperties, DW_IMAGE_CPU, m_sdk));
reading frames from 4 cameras and calling kernel
static gboolean
read_frame(gpointer data)
  dwStatus status = DW_NOT_READY;
  for (uint8_t cameraPort = 0; cameraPort < MAX_PORTS_COUNT; ++cameraPort) {
    if (m_activeCamerasPerPort[cameraPort] == 0) continue;
    for (uint8_t cameraSiblingID = 0; cameraSiblingID < m_activeCamerasPerPort[cameraPort]; ++cameraSiblingID) {
      // return frame
      if (m_frame[cameraPort*MAX_SIBLINGS_COUNT + cameraSiblingID]) {
        status = dwSensorCamera_returnFrame(&m_frame[cameraPort*MAX_SIBLINGS_COUNT + cameraSiblingID]);
        if (status != DW_SUCCESS)
          return false;
      // read from camera
      status = dwSensorCamera_readFrame(&m_frame[cameraPort*MAX_SIBLINGS_COUNT + cameraSiblingID], cameraSiblingID, timeout, m_camera[cameraPort]);
        return false;
      // get an image with the desired output format (async operation)
      dwSensorCamera_getImageAsync(&m_frameImage[cameraPort*MAX_SIBLINGS_COUNT + cameraSiblingID], DW_CAMERA_OUTPUT_CUDA_RAW_UINT16, m_frame[cameraPort*MAX_SIBLINGS_COUNT + cameraSiblingID]);
        return false;
  CHECK_CUDA_ERROR(cudaStreamSynchronize(m_stream));
  if (status == DW_SUCCESS) {
    dwImageCUDA *imgCUDA;
    dwImage_getCUDA(&imgCUDA, m_mixImage);
    printf("generating image %x\n", static_cast<uint16_t*>(imgCUDA->dptr[0]));
    generateImage(m_mixImage, (dwImageHandle_t *)&m_frameImage[0], m_activeCameras);
    printf("generated image %x\n", static_cast<uint16_t*>(imgCUDA->dptr[0]));
  return status == DW_SUCCESS;
sending mixed image to SoftISP to get the tonemap and stream it to the cpu
  if (!read_frame(NULL)) {
    printf("read_frame returned false\n");
    buffer = gst_buffer_new_allocate (NULL, sizeof(guint8) * size, NULL);
    /* increment the timestamp every 1/30 second */
    GST_BUFFER_PTS (buffer) = ctx->timestamp;
    GST_BUFFER_DURATION (buffer) = gst_util_uint64_scale_int (1, GST_SECOND, 30);
    ctx->timestamp += GST_BUFFER_DURATION (buffer);
    g_signal_emit_by_name (appsrc, "push-buffer", buffer, &ret);
    gst_buffer_unref (buffer);
    return;
  dwImageProperties prop;
  dwImage_getProperties(&prop, m_mixImage);
  dwTime_t timestamp;
  dwImage_getTimestamp(&timestamp, m_mixImage);
  printf("timestamp %u format %d type %d width %d height %d memoryLayout %d\n", timestamp, prop.format, prop.type, prop.width, prop.height, prop.memoryLayout);
  // raw images need to be processed through the softISP
  dwImageCUDA* rawImageCUDA;
  CHECK_DW_ERROR(dwImage_getCUDA(&rawImageCUDA, m_mixImage));
  CHECK_DW_ERROR(dwSoftISP_bindInputRaw(rawImageCUDA, m_isp));
  // request the softISP to perform a demosaic and a tonemap. This is for edmonstration purposes, the demosaic
  // output will not be used in this sample, only the tonemap output
  CHECK_DW_ERROR(dwSoftISP_setProcessType(m_ispOutput, m_isp));
  CHECK_CUDA_ERROR(dwSoftISP_processDeviceAsync(m_isp));
  // stream that tonemap image to the CPU domain
  CHECK_DW_ERROR(dwImageStreamer_producerSend(m_rgbaImage, m_streamerCUDAtoCPU));
  // receive the streamed image as a handle
  dwImageHandle_t frameCPU;
  CHECK_DW_ERROR(dwImageStreamer_consumerReceive(&frameCPU, timeout, m_streamerCUDAtoCPU));
  // get an image from the frame
  dwImageCPU *imgCPU;
  CHECK_DW_ERROR(dwImage_getCPU(&imgCPU, frameCPU));
  guint8 *data_cp = (guint8 *) malloc(sizeof(guint8) * size);
  memcpy(data_cp, imgCPU->data[0], sizeof(guint8) * size);
  buffer = gst_buffer_new_wrapped (data_cp, sizeof(guint8) * size);
  // returned the consumed image
  CHECK_DW_ERROR(dwImageStreamer_consumerReturn(&frameCPU, m_streamerCUDAtoCPU));
  // notify the producer that the work is done
  CHECK_DW_ERROR(dwImageStreamer_producerReturn(nullptr, timeout, m_streamerCUDAtoCPU));
This is the error
parameters output-format=raw+data,camera-type=ar0231-rccb-bae-sf3324,camera-group=a,camera-count=4,format=raw,fifo-size=3,slave=0
nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP
Max96712 Rev 2 detected!
MAX96712: Enable periodic AEQ on Link 0
MAX96712: Enable periodic AEQ on Link 1
MAX96712: Enable periodic AEQ on Link 2
MAX96712: Enable periodic AEQ on Link 3
MAX96705: Pre-emphasis set to 0xaa
Sensor AR0231 RCCB Rev7 detected!
stream ready at rtsp://0.0.0.0:8554/video
w 3840 h 2416
generating image d6150000
generated image d6150000
timestamp 3493126299 format 4000 type 2 width 3840 height 2416 memoryLayout 1
terminate called after throwing an instance of 'std::runtime_error'
  what():  [2021-11-11 08:06:02] DW Error DW_INTERNAL_ERROR executing DW function:
 at /home/nvidia/my_ws/src/camera_gmsl/main.cpp:236
Aborted (core dumped)
Thanks in advance for your help!
Dear @mkahra14,
Do you see no issue when you comment big image generation code and testing the image streamer workflow?
Sorry @SivaRamaKrishnaNV , I didn’t quite understand your question. Earlier I was mixing camera images on the CPU but it was slow, so I came up with this code.
I have solved the problem, as the image format is RAW_UINT16 i thought that the type for each element was uint16 but it turns out it should be uint8_t.
