Dynamic batch Tensor-RT inference output is incorrect
Description
Hi, I have an issue regarding dynamic batch size on CRNN-like model with Bi-LSTM inside. I encounter incorrect output when I am using batch > 1 (please see Test 2,3, and 4), thank you for your help.
FYI, I have tested other models (object detection, and other things with static shape), and they are working normally. Which means that the Tensor-RT+Python+OS has no issue (at least on CNN-like models).
Note: I could send you the model through the email, kindly await for your reply, thanks
[Test 1]
If use fixed conversion, aka.
trtexec --onnx=“ocr_recog.onnx” --shapes=‘x’:1x3x32x320 --saveEngine=“net_recog.trt” --explicitBatch --workspace=4096
and do inference on batch=1, the output will be nonzeros (0 to 1), which is correct!
Snapshot with batch=1:
[Test 2]
However, If I use model from [Test 1], then I modify the shape after the TRT-conversion using these:
self.context.active_optimization_profile = 0
orishape_ctx = self.context.get_binding_shape(0)
print('ori shape: ', orishape_ctx)
print('ori shape now: ', self.context.get_binding_shape(0), xshape)
self.allocate_buffers(x.shape)
The output will be correct for the first batch, not on batch > 1 (i.e. if I feed my model with 3 batch, batch 1’s output is correct, but batch 2 & 3 are incorrect).
Snapshot with batch>1:
[Test 3]
If I try to modify the fixed ONNX using build_engine as in this blog, this blog, or Nvidia repo, I could also built the model successfully.
Then, I try to load the model, and change the “-1” as in the blog link above, then all returned inference output is zero. I’ve also tried to send only batch: 1, and it also returns zero results (the result shape is correct, but the min, max, and std values are 0.0).
After that, I tries to use Logger with trt.Logger.VERBOSE, then I get these silent error:
[01/27/2022-15:30:14] [TRT] [E] 3: [executionContext.cpp::nvinfer1::rt::ShapeMachineContext::resolveSlots::1480] Error Code 3: API Usage Error (Parameter check failed at: executionContext.cpp::nvinfer1::rt::ShapeMachineContext::resolveSlots::1480, condition: allInputDimensionsSpecified(routine)
[01/27/2022-15:30:14] [TRT] [E] 2: [executionContext.cpp::nvinfer1::rt::ExecutionContext::enqueueInternal::366] Error Code 2: Internal Error (Could not resolve slots: )
Snapshot of [Test 3 and 4] with batch=1:
Snapshot of [Test 3 and 4] with batch>1:
[Test 4]
I’ve also tried to convert my text recognition model from ONNX to Tensor-RT with trtexec. It is successfully convereted. The command looks like this:
trtexec --onnx=“ocr_recog_dnm.onnx” --optShapes=‘x’:50x3x32x320 --minShapes=‘x’:1x3x32x320 --maxShapes=‘x’:100x3x32x320 --saveEngine=“net_recog.trt” --explicitBatch --workspace=4096
When I test the model with batch size: 1 or more, the output value will also always 0 (tested with min, max, mean, and std). And it also has the [Test 3]'s silent error.
Environment
Windows 10.
CUDA 11.1
Tensor-RT 8.2.1.8
Python 3.8.10
TensorRT Version: 8.2.1.8 (Windows version, after links the path to env. variable, then just pip install on the tensorrt_8xx/python/ folder).
GPU Type: RTX3070
Nvidia Driver Version: 471.41
CUDA Version: (11.1 on my env.path) (11.4 on nvidia-smi)
CUDNN Version: 8.2.1 (checked on cudnn_version.h in cudnn/include)
Operating System + Version: Win10 10.0.19044
Python Version (if applicable): 3.8.10
PyTorch Version (if applicable): 1.9.x
Relevant Files
Please kindly send your email, then I will send it immediately.
Please refer to the below link for Sample guide.
Refer to the installation steps from the link if in case you are missing on anything
However suggested approach is to use TRT NGC containers to avoid any system dependency related issues.
https://ngc.nvidia.com/catalog/containers/nvidia:tensorrt
In order to run python sample, make sure TRT python packages are installed while using NGC container.
/opt/tensorrt/python/python_setup.sh
In case, if you are trying to run custom model, please share your model and script with us, so that we can assist you better.
