Tensorrt inference on multiple batches
Description
Hi, I am trying to run inference on multiple batches in tensorrt. However, I can not get the right output. My desired output shape for one image is [14,] and I want to run the model with batches of 32 images. When running the code below, the out of the trt_outputs is an array with shape [448] (14 * 32), but only the 14 first elements have been updated. The rest are all zero. Would very much appreciate help! I do not belive there is anything wrong with the hardware or a bug with tensorrt.
To begin I exported a tflite model that takes a 80x80 image input to onnx and specified batch size to 32 (in the onnx model). The input shape for the onnx model is therefore [32x3x80x80]. Then, I created a trt engine with the following commands:
./trtexec --onnx=/model.onnx --maxBatch=32  --fp16  --saveEngine=/engine.trt
I have also tried engines with the following command:
./trtexec --onnx=/model.onnx  --fp16  --saveEngine=/engine.trt
./trtexec --onnx=/model.onnx --minShapes=input:32x3x80x80 --optShapes=input:32x3x80x80  --maxShapes=input:32x3x80x80 --fp16  --saveEngine=/engine.trt
I then use the following script to run inference:
class HostDeviceMem(object):
    """ Helper data class. """
    def __init__(self, host_mem, device_mem):
        self.host = host_mem
        self.device = device_mem
    def __str__(self):
        return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
    def __repr__(self):
        return self.__str__()
class TrtDetector(object):
    COLOUR_CHANNELS = 3  # RGB
    def __init__(self, engine_path, img_size):
        """ Init function
            @param engine_path:  Path to the TensorRT serialised engine
            @param img_size:     Size of each image dimension
        self.TRT_LOGGER = trt.Logger()
        self.img_size = img_size
        self.engine = self.get_engine(engine_path)
        self.context = self.engine.create_execution_context()
        self.buffers = self.allocate_buffers(batch_size=32)
        self.context.set_binding_shape(0, (1, self.COLOUR_CHANNELS, img_size, img_size))
    def get_engine(self, engine_path):
        """ Load serialised engine from file """
        with open(engine_path, "rb") as f, trt.Runtime(self.TRT_LOGGER) as runtime:
            return runtime.deserialize_cuda_engine(f.read())
    def allocate_buffers(self, batch_size):
        """ Allocate necessary buffers for inference on the GPU
            @param batch_size: Size of the batches
            @return
                - inputs: buffer for inputs
                - outputs: buffer for outputs
                - bindings: device bindings
                - stream: GPU stream, sequence of operations
        inputs = []
        outputs = []
        bindings = []
        stream = cuda.Stream()
        for binding in self.engine:
            size = trt.volume(self.engine.get_binding_shape(binding)) * batch_size
            dtype = trt.nptype(self.engine.get_binding_dtype(binding))
            # Allocate host and device buffers
            host_mem = cuda.pagelocked_empty(size, dtype)
            device_mem = cuda.mem_alloc(host_mem.nbytes)
            # Append the device buffer to device bindings
            bindings.append(int(device_mem))
            # Append to the appropriate list
            if self.engine.binding_is_input(binding):
                inputs.append(HostDeviceMem(host_mem, device_mem))
            else:
                outputs.append(HostDeviceMem(host_mem, device_mem))
        return inputs, outputs, bindings, stream
    def do_inference(self, bindings, inputs, outputs, stream):
        """ Inference on the GPU """
        # Transfer input data to the GPU
        [cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
        # Run inference
        self.context.execute_async_v2(bindings=bindings, stream_handle=stream.handle)
        # Transfer predictions back from the GPU
        [cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
        # Synchronize the stream
        stream.synchronize()
        # Return only the host outputs
        return [out.host for out in outputs]
def detect(self, imgs):
        """ Run detections on batch of images
            @param imgs: Input images
        # Pre-processing
        images_input = pre_process(imgs)
        # images_input.shape = 32x3x80x80
        # Do inference on GPU
        inputs, outputs, bindings, stream = self.buffers
        inputs[0].host = images_input
        trt_outputs = self.do_inference(
            bindings=bindings, inputs=inputs, outputs=outputs, stream=stream
        return trt_outputs
The preprocessing function mentioned in detect is as follows:
def pre_process(imgs):
    """ Perform pre processing on a batch of images
        @param imgs:   Images to pre process
    imgs_for_inference = []
    for img in imgs:
        img = cv2.resize(img, (80, 80))
        img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
        img = np.transpose(img, (2, 0, 1)).astype(np.float32)
        img /= 255.0
        img = np.ascontiguousarray(img)
        imgs_for_inference.append(img)
    imgs_for_inference = np.array(imgs_for_inference).astype('float16')
    return imgs_for_inference
Then to run everything I do:
if __name__ == "__main__":
    input_img_path = '/my_img.jpg'
    img = cv2.imread(input_img_path)
    # array of 32 images
    imgs = np.array([img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img, img])
    model = TrtDetector("/engine.trt", 80)
    model.detect(imgs)
Could you please let us know the TensorRT version you’re using. We recommend you to please try on the latest version.
If you still face this issue., please share with us the ONNX model and complete script to to try from our end for better debugging.
Thank you.
Here is a github repo with a minimal working example: https://github.com/trt_multi_batch
Here are the onnx and trt weights (32x3x80x80): https://drive.google.com/drive/folders/1yEkltE1Kqw9leOOc844lYf4XSyXH8Uv3?usp=sharing
To generate the trt-engine I specifically run:
./trtexec --onnx=/model_batch32.onnx --explicitBatch  --fp16 --saveEngine=/engine_batch32.trt
When adding --dumpOutput I get the expected output.
However, contrary to what I stated in the first post, I now seem to get all non-zero outputs. But, it is still not working since all the outputs from each batch are identical.
I guess there could be something going wrong when I am setting the input? I get the exact same results without setting inputs[0].host = imgs.ravel() in line 92.
Also, I am not sure if I am setting the binding shape correctly in line 37. It doesn’t seem to matter if I put (32, 3, 80, 80) or (1, 3, 80, 80)
Tensorrt version - 7.1.3
Cuda - 10.2
Cudnn - 8.0
running on jetson xavier with jetpack 4.4
I am not able to update the above
Looks like your model has static inputs and the also script has some mistakes.
We recommend you to please generate an ONNX model with a dynamic input shape.
And please refer to the following sample and doc to run inference.
Thank you.
Thanks works great!
