Dynamic initialization error for setting const values using math functions
I’m trying to set some const parameters in a parameters header a la
const double a = 5.;
const double b = 6.;
const double ab = pow(a,b);
which throws
error: dynamic initialization is not supported for __device__, __constant__ and __shared__ variables.
This same code in C++ works fine. As far as I can tell it’s trigger by the usage of functions such as pow or sqrt. How can I avoid this issue?
Sorry to state the obvious: Don’t use dynamic initialization of device, constant and shared variables. Just pre-compute the desired constants and stick them into your header file. I would suggest pre-computing the constants with higher than target precision for optimal results.
CUDA is not C++, it’s a subset of C++. A pretty substantial subset, but a subset nonetheless.
