This code compiles correctly
struct MyVec4
__device__ MyVec4() {}
float x, y, z, w;
struct MyMat4 { MyVec4 col0, col1, col2, col3; };
__constant__ MyMat4 myMatrix;
__constant__ MyVec4 myArrayOfVectors[4];
But altering the MyMat4 definition slightly causes the error “dynamic initialization is not supported for device, constant and shared variables”
struct MyMat4 { MyVec4 cols[4]; };
Removing the ctor from MyVec4 works around the issue; but this is not practical in the real use case, the empty ctor is necessary to denote that the class does allow default no-initialization construction.
Am I overlooking something, or are there oddities in detecting whether dynamic initialization is necessary?
