Is it possible to increase dynamically allocated SM (cudaFuncAttributeMaxDynamicSharedMemorySize) for the kernels launched with Dynamic Parallelism? My kernel runs OK with <= 48K of the dynamically allocated SM with Dynamic Parallelism, I can also directly launch kernel from the host code with >48K, but I was not able to call a kernel (that needs > 48K SM) from another kernel.
Code links:
Calling kernel from the host code (works with SM >48K):
Attempt to use Dynamic parallelism (works with <=48K), fails with >48K:
Host code: test_tp.cu:1674 (same file, link removed to fit into 3 links allowed)
Outer kernel called from host:
TileProcessor.cuh:2796 (same file, link removed to fit into 3 links allowed)
Robert, thank you for your reply. I am not an experienced CUDA developer, so I’m trying first to understand if this functionality is not yet implemented or I’m just doing something wrong. I think it is an important feature and not just for me, especially for the devices with later compute capability that have larger shared memory; in my case (7.5), I was just unlucky to hit between 48K (available with statically allocated SM) and 64K - maximal total SM. Later devices have larger SM but the same 48K for static allocation.
I find DP to be a very convenient feature. Among other advantages of the DP, I enjoy chaining multiple kernels where the next ones can only start when the previous ones are finished, and each kernel may have a different grid configuration. I can then expose to the host just the top-level kernel, which in turn calls all the others. It is especially convenient to launch kernels from Java (with jcuda) in a single call. The kernel itself is already tested from inside the convenient Nsight environment - the debug capability is unavailable in Java, where I have to replicate the top kernel’s functionality.
Andrey
PS. Line numbers in my earlier code links changed because it is the branch I’m currently working on.
I followed your advice and filed a bug report https://developer.nvidia.com/nvidia_bug/3503453 . It all went well at first, but since 01/24, I could not post my reply. I tried many times, from different computers and browsers, but I’m getting the same error message:
An AJAX HTTP error occurred.
HTTP Result Code: 500
Debugging information follows.
Path: /system/ajax
StatusText: Internal Server Error
ResponseText:
Can anything be done about it? I feel very uncomfortable because it looks like it is my fault that I’m failing to respond to the request for the additional details related to my bug report. Can that bug report be supplemented with my response or at least hidden until the website error is resolved?
Yuki, maybe I’m wrong but I suspect that the website problem maybe somehow related to the “publicly visible log.txt” - I do not see any. Where should it be? Search does not find another “log.txt” on the page itself and in the source view. Maybe it broke something with permissions and now only NVIDIA personnel can post on that page? Can you yourself see that log.txt ?
Additionallly, I asked another developer who is registered at NVIDIA - he can not access that page at all.
Where should I respond you? For now I’m doing it here, please see my response below.
Hi Yuki,
I do not understand your recommendation. In the textures_accumulate kernel, I need 58800 bytes of shared memory; I pass it to this sub-kernel in DP and non-DP modes. It does work in non-DP mode and does not work in DP mode. What do you mean by “not define its shared memory in sub kernel?” Where should I define it?
I just saw your reply here to my latest email . Sorry for the bug report system breakage .We’ve been checking with our IT engineers on it .
What about we focus on email chat and bring back the ticket result here ? Thanks .
Could this be related to a problem I’m having configuring the shared memory of a kernel which calls device kernels?
I have 1 kernel which calls three device kernels, and I need to configure the shared memory to one of the device kernels. I’m currently setting the functionAttribute of the global kernel since that is the one which can be configured <<<,>>>, but I’m getting a runtime error when I set the attribute with more than 48KB of memory as maxSharedMemPerMultiProcessor.
I can only configure the global kernel which calls device kernels with ~ Max - 10K bytes.
MaxSharedMemPerMultiProcessor : 65536
Removing some to get this running : 56536
I don’t know what you mean by global kernels and device kernels.
The entry point for a CUDA kernel is a function that is decorated with the __global__ keyword. If you are referring to something that is decorated with __device__ and not __global__, that function, by itself, is not a kernel.
cudaFuncSetAttribute()cannot be directly applied to a __device__ function:
The parameter specified by func must be declared as a __global__ function.
Has this issue (kernels launched by CUDA threads cannot use more than 48kB shared memory per thread block) been resolved now?
Update: I’ve just tested CUDA-12.3 with CDP2, calling a kernel using 66KiB shared memory per block on the device side succeeded after setting cudaFuncAttributeMaxDynamicSharedMemorySize on the host side.
With respect to the bug previously mentioned (3503453), that bug is closed with feature implemented. As you have noted, its necessary to use cudaFuncAttributeMaxDynamicSharedMemorySize to enable greater than 48K shared, with or without CDP. Based on what I see in the bug, I would expect any CUDA 12.0 or newer release to have this feature implemented, but I have not tested that. (The bug was originally reported against CUDA 11.2)
