DGPU - A4000
• DeepStream Version
6.2
N/A
• TensorRT Version
8.5.2
Driver version 535
We wanted to know if ECC should be enabled or disabled on the GPU (A4000) while running deepstream 6.2 applications. Is there any impact on ECC on the deepstream pipeline?
It has nothing to do with DeepStream. It depends on your requirement. To enable ECC may cause extra GPU consumption while accelerating GPU compute and accuracy. You should weigh the pros and cons by yourself.
