Efficient kernel sort algorithm for very small Arrays
Hi, Guys
i need a fast sorting algorithm for small Arrays. I already tried out the bitonic sort algorithm from the example code, but the performace was horrible. Sorting a 256 elements array takes 5 ms,
on a 560 gtx.
The globale Kernel:
__global__ void initCCL (const uchar* device_fdata,uchar* device_buffer,uint* buffer,int width,int height,int pitch,int block2Log) {
	const uint x =  blockIdx.x *blockDim.x+ threadIdx.x;
	const uint y = blockIdx.y *blockDim.y+ threadIdx.y;
	const uint idx = x + y * pitch;
	const int localIdx = threadIdx.x + blockDim.y * threadIdx.y;
	__shared__ uint unionBuffer[TILE_SIZE];
	__shared__ uint updateBuffer[TILE_SIZE];
	__shared__ uint2 tupelBuffer[TILE_SIZE*3];
	__shared__ uint2 tupelSwapBuffer[TILE_SIZE*3];
	__shared__ uint s_key[TILE_SIZE*3];
	__shared__ uint s_ident[TILE_SIZE*3];
	uint px = device_fdata[idx];
	updateBuffer[localIdx] = 0;
	s_key[localIdx] = 0;
	s_ident[localIdx] =localIdx;
	* Every Pixel in  a Quad is connected to each other
	* so every Pixel is the same group
	uint quadid = QUADID(threadIdx.x,threadIdx.y);
	//quadid = (px>0)*quadid;
	if(px < 1) {
		quadid= 0;
	}else {
	unionBuffer[localIdx] = quadid;
	__syncthreads();
	const uint tn = THREADSNEEDED(2);
	uint currentVal = 0;
	uint rt,r,rb;
	if(localIdx< 64) {
		if(localIdx < tn){
		const uint temp2 = localIdx * 2 + ((localIdx /7)*2) +1;
		currentVal = unionBuffer[temp2];
		rt = unionBuffer[LIMIT_MIN(temp2 -16,0)];
		r = unionBuffer[temp2+1];
		rb = unionBuffer[LIMIT_MAX(temp2+17,255)];
		uint2 a = {currentVal*3,rt} ;
		sizeswap(a);
		tupelBuffer[localIdx] = a;
		s_key[localIdx *3 ] = a.y;
		uint2 b = {currentVal,r};
		sizeswap(b);
		tupelBuffer[localIdx*3+1] = b;
		s_key[localIdx *3 +1 ] = b.y;
		uint2 c = {currentVal,rb};
		sizeswap(c);
		tupelBuffer[localIdx*3+2] = c;
		s_key[localIdx * 3 +1 ]= b.y;
		s_ident[localIdx *   3] = localIdx *   3;
		s_ident[localIdx * 3+1] = localIdx * 3+1;
		s_ident[localIdx * 3+2] = localIdx * 3+2;
		}else {
			//Build Min Buffer
	if(localIdx < 128)
	bitonic_merge_sort(s_key,s_ident,localIdx,256);
	__syncthreads();
	//Reduce the tupel buffer
	device_buffer[idx] = unionBuffer[localIdx];
And the sorting Algorithm:
inline __device__ void bitonic_merge_sort (uint* s_key,uint* s_val,const uint& localIdx,const uint& arrayLength,uint dir){
	     for(uint size = 2; size < arrayLength; size <<= 1){
        //Bitonic merge
        uint ddd = dir ^ ( (localIdx& (size / 2)) != 0 );
        for(uint stride = size / 2; stride > 0; stride >>= 1){
            __syncthreads();
            uint pos = 2 * localIdx - (localIdx & (stride - 1));
            Comparator(
                s_key[pos +      0], s_val[pos +      0],
                s_key[pos + stride], s_val[pos + stride],
                ddd
//ddd == dir for the last bitonic merge step
        for(uint stride = arrayLength / 2; stride > 0; stride >>= 1){
            __syncthreads();
            Comparator(
                dir
__syncthreads();
Any Idea why the code is so slow?
thx
For such small arrays, why not sort them on the host? I would imagine the poor performance would be because most of the 5 ms consists of GPU overhead.
You could try radix sort from Duanne Meril since you are sorting integers but for an array of 256 elements i don’t know if it will be faster than bitonic sort
I need to sort them in the Kernel, because i have to eliminate dublicates. The algorithm you see isnt complete, so it would be a big overhead to transfer back und elimate dublicates.
