Hi. I have a large number of arrays (WinWidth*WinHeight exactly). Each array have fixed size == 32.
I need to sort them as fast as it possible.
I wrote buble sort, but it is too slow. What sorting algorithm will be better to use in my case?
btw. my bubble sort.
template
int ARR_SIZE, // array size. shold be less or eq that CTA_SIZE
class T, // type of array elements
template <class> class LESS // LESS<T>::exec(A,B) return true if A < B
__device__ void BubleSort(T data[])
int idInChunck = threadIdx.x % ARR_SIZE;
int chunckOffset = (threadIdx.x/ARR_SIZE)*ARR_SIZE;
for(int i=0;i<ARR_SIZE;i++)
int index = (idInChunck+i) % ARR_SIZE + chunckOffset;
if(threadIdx.x%2 == 0 && index+1 < ARR_SIZE + chunckOffset)
T A = data[index];
T B = data[index+1];
if(!LESS<T>::exec(A,B))
data[index] = B;
data[index+1] = A;
__syncthreads();
For small arrays you should be able to use a sorting network (see Knuth). Hopefully nvcc will convert min/max expressions into suitable branchless instruction sequences but I haven’t verified this.
