import cv2
import numpy as np
# Create a VideoCapture object and read from input file
# If the input is the camera, pass 0 instead of the video file name
#gst_str_1 = ("rtsp://192.168.10.78/media/live/2/1")
gst_str_1 = ("rtspsrc location=rtsp://admin:123456@192.168.10.51/stream0 latency=0 ! rtph265depay ! h265parse ! nvv4l2decoder ! nvvidconv ! video/x-raw , format=(string)BGRx ! videoconvert ! appsink")
cap = cv2.VideoCapture(gst_str_1, cv2.CAP_GSTREAMER)
# Check if camera opened successfully
if (cap.isOpened()== False):
print("Error opening video stream or file")
# Read until video is completed
while(cap.isOpened()):
# Capture frame-by-frame
ret, frame = cap.read()
if ret == True:
# Display the resulting frame
#cv2.imshow('Frame',frame)
# Press Q on keyboard to exit
if cv2.waitKey(25) & 0xFF == ord('q'):
break
# Break the loop
else:
break
cap.release()
cv2.destroyAllWindows()
Result
python camera_1080p_51.py
Failed to query video capabilities: Inappropriate ioctl for device
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NVMEDIA: Reading sys.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 279
For running gstreamer with OpenCV, since appsink only accepts CPU buffers, so there is memcpy() to copy video/x-raw(memory:NVMM) to video/x-raw. To reduce CPU loading, suggest you use tegra_multimedia_api instead of OpenCV.
The CPU loading of using omxh264enc and nvv4l2decoder is identical.
import cv2
import numpy as np
if ret == True:
break
# Break the loop
else:
break
cap.release()
@Ravik 1- you use this codes? link 2- can you share your decoder code? 3 - in the deep-stream-python-apps, in the deepstream-imagedata-multistream codes, How I can stop visualization? I want don’t show me any visualization and only do decoder. and I want to use nvv4l2decoder instead of decodebin decoder because i want to use drop-frame-interval option.
