Hi all,
I’m trying to capture frames from RTSP stream using GStreamer in order to access HW decoding but it seems not working.
I compiled Opencv 4.0 using this script: https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.0.0_Nano.sh
required cause original Opencv installed in jetson nano distro returns an error using GST pipeline as input
Now using this simple code:
import cv2
import gi
gi.require_version('Gst', '1.0')
if __name__ == '__main__':
gst = "rtspsrc location=rtsp://admin:Password@192.168.0.200:554/ latency=200 ! queue ! rtph264depay ! h264parse ! queue ! h264parse ! omxh264dec ! videoconvert ! appsink"
cap = cv2.VideoCapture(gst)
if not cap.isOpened():
print("capture failed")
exit()
while True:
ret, frame = cap.read()
if ret:
frame = cv2.resize(frame, (1280,720)) # I know it could increase CPU usage but also removing it doesn't change
cv2.imshow('frame', frame)
if (cv2.waitKey(1) & 0xFF == ord('q')):
break;
cap.release()
cv2.destroyAllWindows()
If I check CPU utilization with top command I get: 160-190%
but if I launch:
gst-launch-1.0 rtspsrc location=rtsp://admin:Password@192.168.0.200:554 latency=200 ! queue ! rtph264depay ! h264parse ! queue ! h264parse ! omxh264dec ! nveglglessink -e
I have a CPU utilization of: 34%
So seems that using gst-launch-1.0 HW decoding works but not using Python and opencv.
Python building result:
>>> import cv2
>>> print cv2.getBuildInformation()
General configuration for OpenCV 4.0.0 =====================================
Version control: unknown
Extra modules:
Location (extra): /home/viper/opencv-4.0.0/opencv_contrib-4.0.0/modules
Version control (extra): unknown
Platform:
Timestamp: 2019-09-13T09:09:00Z
Host: Linux 4.9.140-tegra aarch64
CMake: 3.10.2
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: RELEASE
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++ Compiler: /usr/bin/c++ (ver 7.4.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release):
Linker flags (Debug):
ccache: NO
Precompiled headers: YES
Extra dependencies: m pthread cudart_static -lpthread dl rt nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda/lib64 -L/usr/lib/aarch64-linux-gnu
3rdparty dependencies:
OpenCV modules:
To be built: aruco bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dpm face features2d flann freetype fuzzy gapi hdf hfs highgui img_hash imgcodecs imgproc java_bindings_generator line_descriptor ml objdetect optflow phase_unwrapping photo plot python2 python3 python_bindings_generator reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
Disabled: world
Disabled by dependency: -
Unavailable: cnn_3dobj cvv java js matlab ovis sfm ts viz
Applications: apps
Documentation: NO
Non-free algorithms: NO
GUI:
GTK+: YES (ver 2.24.32)
GThread : YES (ver 2.56.4)
GtkGlExt: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
TIFF: build (ver 42 - 4.0.9)
JPEG 2000: build (ver 1.900.1)
OpenEXR: build (ver 1.7.1)
HDR: YES
SUNRASTER: YES
PXM: YES
PFM: YES
Video I/O:
DC1394: NO
FFMPEG: YES
avcodec: YES (ver 57.107.100)
avformat: YES (ver 57.83.100)
avutil: YES (ver 55.78.100)
swscale: YES (ver 4.8.100)
avresample: YES (ver 3.7.0)
GStreamer:
base: YES (ver 1.14.5)
video: YES (ver 1.14.5)
app: YES (ver 1.14.5)
riff: YES (ver 1.14.5)
pbutils: YES (ver 1.14.5)
v4l/v4l2: linux/videodev2.h
Parallel framework: pthreads
Trace: YES (built-in)
Other third-party libraries:
Lapack: NO
Eigen: YES (ver 3.3.4)
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.5.1)
NVIDIA CUDA: YES (ver 10.0, CUFFT CUBLAS)
NVIDIA GPU arch: 53
NVIDIA PTX archs:
OpenCL: YES (no extra features)
Include path: /home/viper/opencv-4.0.0/opencv-4.0.0/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 2:
Interpreter: /usr/bin/python2.7 (ver 2.7.15)
Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15+)
numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
packages path: lib/python2.7/dist-packages
Python 3:
Interpreter: /usr/bin/python3 (ver 3.6.8)
Libraries: /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.8)
numpy: /usr/local/lib/python3.6/dist-packages/numpy/core/include (ver 1.17.1)
packages path: lib/python3.6/dist-packages
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Install to: /usr/local
Any idea? I don’t really know how to quit from this condition…
