I am using the a typical pipeline (see below) to feed my Opencv/Python program frames. My CPU is running at 100% , while my GPU is only 25%. Is there anything I can do to put more work on the GPU?
The optimal-performance solution is to pass NVMM[video/x-raw(memory:NVMM)] buffers in the pipelines. However, with python, it only accepts CPU[video/x-raw,format=BGR] buffers. This requires copying NVMM buffers to CPU buffers and takes certain CPU loading.
On Jetson Nano with ‘sudo jetson_clcoks’ being executed, it might be good for 1920x1080p30. But the resolution of your usecase is close to 4K, which shall exceed hardware capability.
Suggest you try pure gstreamer or tegra_multimedia_api.
Is there any way for me to be able to do opencv processing on the device with the CSI camera? I am trying to make a live-streaming system. I need to do a little bit of panning/zooming and text overlays on the stream
Hi @DaneLLL
Is this link use pure gstreamer for decoding? Don’t have this code bottleneck of gstreamer+opencv(copying NVMM buffer to CPU buffer)? I see in this code in lines 123,125 use numpy and opencv lib, Aren’t these lines of code bottleneck like gstreamer+opencv?
The SH link is not working. Anyway you can provide new instructions for jetpack 4.4?
I am having similar issues, the Gstreamer is using only CPU.
OpenCV 4.4.0
Sorry for not being clear. I noticed gst_cv_gpumat.cpp had no license header, so I was wondering what the license was. My understanding is without such an explicit license, it’s “all rights reserved” in which case I can’t use it. There is a permissive license on the Makefile, but to me it’s not explicit this applies to the .cpp.
Bump? Very much appreciate clarification on the license for gst_cv_gpumat.cpp. I’m using the Argus/MMAPI example code instead at the moment, but that’s more work.
Except the part of using cuda filters in OpenCV, the permission is same as jetson_multimedia_api samples:
* Copyright (c) 2016-2020, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
In the sample it utilizes cuda filter in OpenCV for demonstration purpose. For other purpose, you probably need to check the license, too.
