I have compiled OpenCV with support gstreamer support using this script: JEP/install_opencv4.5.0_Jetson.sh at master · AastaNV/JEP · GitHub
When I execute the following code:
import cv2
mainVideoResolution = (2592, 1944)
thumbnailVideoResolution = (640, 480)
cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)2592, height=(int)1944,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! queue ! appsink drop=1", cv2.CAP_GSTREAMER)
print(cap)
if not cap.isOpened():
print('Failed to open camera')
exit
mainVideo = cv2.VideoWriter("appsrc ! queue ! videoconvert ! video/x-raw,format=BGRx ! nvvidconv ! nvv4l2h264enc insert-sps-pps=1 insert-vui=1 ! rtph264pay ! udpsink host=127.0.0.1 port=5004", cv2.CAP_GSTREAMER, 0, 30.0, mainVideoResolution)
if not mainVideo.isOpened():
print('Failed to open mainVideo')
cap.release()
exit
thumbnailVideo = cv2.VideoWriter("appsrc ! queue ! videoconvert ! video/x-raw,format=BGRx ! nvvidconv ! video/x-raw(memory:NVMM),width=320,height=240 ! nvv4l2h264enc insert-sps-pps=1 insert-vui=1 ! rtph264pay ! udpsink host=127.0.0.1 port=5005", cv2.CAP_GSTREAMER, 0, 30.0, thumbnailVideoResolution)
if not thumbnailVideo.isOpened():
print('Failed to open rtpudp82')
thumbnailVideo.release()
cap.release()
exit
while True:
ret_val, img = cap.read()
if not ret_val:
break
mainVideo.write(img)
thumbnailVideo.write(img)
mainVideo.release()
cap.release()
The CPU usage is almost 100% but GPU usage is about 0%. Why that happens if I use gstreamer which supports hardware acceleration.
If execute similar code:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=NV12, width=2592, height=1944' ! tee name=t ! queue ! nvv4l2h264enc insert-sps-pps=true ! h264parse ! rtph264pay pt=96 ! udpsink host=127.0.0.1 port=5004 sync=false t. ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM), width=640, height=480' ! nvv4l2h264enc insert-sps-pps=true ! h264parse ! rtph264pay pt=96 ! udpsink host=127.0.0.1 port=5005 sync=false
form bash I have CPU usage at about 45% and still 0% usage of GPU?
I check the resource usage using jtop.
- Why there is no GPU usage during using gstreamber both from Python OpenCV and from bash?
- Why there is that big difference when I use gstreamer with openCV compared to using pure gstreamer?
