When I read rtsp streams directly using components of Gstreamer, the latency was very low. Here is the code.
gst-launch-1.0 rtspsrc location=“rtspt://admin:wzu123456@192.168.1.64:554/h264/ch1/main/av_stream” latency=0 ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! xvimagesink sync=false
But what happens when I use Gstreamer in opencv and the latency gets high. How do I fix this?
Here is the opencv code and the associated errors.
import cv2
import queue
import time
import threading
q = queue.Queue()
pipeline = 'rtspsrc location=rtsp://admin:wzu123456@192.168.1.64:554/h264/ch1/main/av_stream latency=0 ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! appsink sync=false '
def Receive():
print("start Reveive")
cap = cv2.VideoCapture(pipeline, cv2.CAP_GSTREAMER)
ret, frame = cap.read()
q.put(frame)
while ret:
q.put(frame)
def Display():
print("Start Displaying")
while True:
if q.empty() != True:
frame = q.get()
cv2.imshow("frame", frame)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
if __name__ == '__main__':
p1 = threading.Thread(target=Receive)
p2 = threading.Thread(target=Display)
p1.start()
p2.start()
(ocr) wzu@wzu-desktop:~/jjh/pythonProject14$ python gs.py
start Reveive
Start Displaying
(python:10266): GStreamer-CRITICAL **: 14:54:07.578: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(python:10266): GStreamer-CRITICAL **: 14:54:07.578: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(python:10266): GStreamer-CRITICAL **: 14:54:07.578: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(python:10266): GStreamer-CRITICAL **: 14:54:07.578: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(python:10266): GStreamer-CRITICAL **: 14:54:07.578: gst_structure_get_string: assertion 'structure != NULL' failed
(python:10266): GStreamer-CRITICAL **: 14:54:07.578: gst_mini_object_unref: assertion 'mini_object != NULL' failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 2560x1440 (x 14), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 2560, nFrameHeight = 1440
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (1063) open OpenCV | GStreamer warning: unable to query duration of stream
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (1100) open OpenCV | GStreamer warning: Cannot query video position: status=1, value=0, duration=-1
^CException ignored in: <module 'threading' from '/home/wzu/archiconda3/envs/ocr/lib/python3.8/threading.py'>
File "/home/wzu/archiconda3/envs/ocr/lib/python3.8/threading.py", line 1388, in _shutdown
lock.acquire()
KeyboardInterrupt:
^C
