Hi Guys,
I intend to annotate the EGL image recieved from camera with some text overlays and encode the annotated image . Please let me know what is the best way to achieve it.
Hi Guys,
Hi dumbogeorge,
Could you refer to below used in https://github.com/dusty-nv/jetson-inference to see if helps?
https://github.com/dusty-nv/jetson-inference/blob/master/util/cuda/cudaFont.h
Hi dumbogeorge,
Have you tried the suggestion?
Any result can be shared?
Hi kayccc,
Thanks for the leads. However, the implementation in these samples make of CUDA applied on RGBA frames. I would ideally like to check from you if there are any annotation samples annotating EGL frames.
Please let me know in case I can refer to some samples which use EGL frames.
We don’t have sample for this. Other users may have more experience of putting text overlay via EGL APIs.
