EMC Clock Speed stays at minimum
I am using a Jetson Xavier NX 8GB and use the internal EMMC memory for my application. It is flashed using the A/B Partitions and the image based OTA update mechanism. When I flash the devices for this use case it works fine. But when I do the first Image based OTA update the emc clock rate stays at 204 MHz after the reboot and will ever be on this rate, no matter what. Only if I reflash it via the OTG Port I get the 1.6GHz back working.
The strange thing is also this happens just on some of my devices. On most of them it works just fine.
Any idea where the problem could come from?
Best Regards
Andy
Please clarify which jetpack release are you using here.
Please also clarify how did you create the image for image based OTA.
The Linux4Tegra Version is 32.6.1 and I create it doing a backup of my golden record device, move this img to the bootloader folder and call the l4t_generate_ota_package.sh script with -s.
As said this works also fine for ~6 devices. But I got 2 new one which have the correct EMC clock rate after the initial flash with “sudo ROOTFS_AB=1 ./flash.sh -r jetson-xavier-nx-devkit-emmc mmcblk0p1”. But when I do the ota update once they will stick to the minimum EMC clock speed forever.
Attached you can find the log of the boot via the serial connection. There I found “emc_init: Missing emc dt table!” and “emc_debugfs_t194_init: no EMC tables, aborting”. Looks like the error is already at this point. Any idea on how to fix it?
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.368] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.369] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.369] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.370] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.376] W> device prod register failed
[0000.380] I> Boot-device: QSPI
[0000.383] I> Boot_device: QSPI_FLASH instance: 0
[0000.388] I> QSPI Flash Size = 32 MB
[0000.393] I> Qspi initialized successfully
[0000.394] I> qspi flash-0 params source = boot args
[0000.781] I> sdmmc DDR50 mode
[0000.784] I> sdmmc-3 params source = safe params
[0000.789] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.790] W> Cannot find any partition table for 00000003
[0000.797] I> Found 12 partitions in SDMMC_USER (instance 3)
[0000.798] I> Active Boot chain : 1
[0000.799] I> parsing oem signed section of bpmp-fw header done
[0000.800] I> bpmp-fw binary init read from storage
[0000.801] I> oem authentication of bpmp-fw header done
[0000.813] I> bpmp-fw binary done read from storage
[0000.814] I> bpmp-fw: Authentication init Done
[0000.815] I> parsing oem signed section of cpubl header done
[0000.815] I> cpubl binary init read from storage
[0000.817] I> bpmp-fw: Authentication Finalize Done
[0000.822] I> oem authentication of cpubl header done
[0000.830] I> cpubl binary done read from storage
[0000.831] I> cpubl: Authentication init Done
[0000.836] I> parsing oem signed section of rce header done
[0000.841] I> rce binary init read from storage
[0000.845] I> Relocating BR-BCT
[0000.848] I> cpubl: Authentication Finalize Done
[0000.853] I> oem authentication of rce header done
[0000.857] I> rce binary done read from storage
[0000.861] I> rce: Authentication init Done
[0000.866] I> parsing oem signed section of ape header done
[0000.871] I> ape binary init read from storage
[0000.875] I> rce: Authentication Finalize Done
[0000.879] I> oem authentication of ape header done
[0000.884] I> ape binary done read from storage
[0000.888] I> ape: Authentication init Done
[0000.892] I> parsing oem signed section of tos header done
[0000.898] I> tos binary init read from storage
[0000.902] I> ape: Authentication Finalize Done
[0000.906] I> oem authentication of tos header done
[0000.913] I> tos binary done read from storage
[0000.915] I> tos: Authentication init Done
[0000.919] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.925] I> bpmp-fw-dtb binary init read from storage
[0000.930] I> tos: Authentication Finalize Done
[0000.936] I> oem authentication of bpmp-fw-dtb header done
[0000.940] I> bpmp-fw-dtb binary done read from storage
[0000.944] I> bpmp-fw-dtb: Authentication init Done
[0000.950] I> parsing oem signed section of cpubl-dtb header done
[0000.955] I> cpubl-dtb binary init read from storage
[0000.960] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.011] I> oem authentication of cpubl-dtb header done
[0001.012] I> cpubl-dtb binary done read from storage
[0001.013] I> cpubl-dtb: Authentication init Done
[0001.014] I> parsing oem signed section of eks header done
[0001.014] I> eks binary init read from storage
[0001.015] I> cpubl-dtb: Authentication Finalize Done
[0001.016] I> oem authentication of eks header done
[0001.020] I> eks binary done read from storage
[0001.024] I> eks: Authentication init Done
[0001.028] I> eks: Authentication Finalize Done
[0001.032] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE:  BL31: v1.3(release):b5eeb33f7
NOTICE:  BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
  [0001.376] I> Welcome to Cboot
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.376] I> Cboot Version: t194-cfa2bc91
[0001.378] I> CPU-BL Params @ 0xf2820000
[0001.382] I>  0) Base:0x00000000 Size:0x00000000
[0001.386] I>  1) Base:0xf1100000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
��[0001.391] I>  2) Base:0xf2000000 Size:0x00200000
��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
��[0001.406] I>  3) Base:0xf1200000 Size:0x00200000
��ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
��[0001.425] I>  4) Base:0xf1000000 Size:0x00100000
��ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
��[0001.439] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.478] I>  6) Base:0xf3800000 Size:0x00400000
[0001.482] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.487] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.491] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.496] I> 10) Base:0xf3000000 Size:0x00800000
[0001.500] I> 11) Base:0x40000000 Size:0x00040000
[0001.505] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.509] I> 13) Base:0x40046000 Size:0x00002000
[0001.514] I> 14) Base:0x40048000 Size:0x00002000
[0001.518] I> 15) Base:0xac000000 Size:0x00004000
��Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.523] I> 16) Base:0x4004a000 Size:0x00002000
[0001.613] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.617] I> 18) Base:0x4004c000 Size:0x00002000
[0001.622] I> 19) Base:0xf2200000 Size:0x00600000
[0001.626] I> 20) Base:0x4004e000 Size:0x00002000
[0001.631] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.635] I> 22) Base:0x00000000 Size:0x00000000
[0001.640] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.644] I> 24) Base:0xf6000000 Size:0x02000000
[0001.649] I> 25) Base:0x40050000 Size:0x00002000
[0001.653] I> 26) Base:0x40040000 Size:0x00006000
[0001.658] I> 27) Base:0xf1800000 Size:0x00400000
[0001.662] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.667] I> 29) Base:0xf1400000 Size:0x00400000
[0001.671] I> 30) Base:0x00000000 Size:0x00000000
[0001.676] I> 31) Base:0x00000000 Size:0x00000000
[0001.680] I> 32) Base:0xf8000000 Size:0x08000000
[0001.684] I> 33) Base:0x00000000 Size:0x00000000
[0001.689] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.693] I> 35) Base:0xab000000 Size:0x01000000
[0001.698] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.702] I> 37) Base:0xf2800000 Size:0x00800000
[0001.707] I> 38) Base:0x80000000 Size:0x20000000
[0001.711] I> 39) Base:0xb0000000 Size:0x08000000
[0001.716] I> 40) Base:0x00000000 Size:0x00000000
[0001.720] I> 41) Base:0x00000000 Size:0x00000000
[0001.725] I> 42) Base:0x00000000 Size:0x00000000
[0001.729] I> 43) Base:0x00000000 Size:0x00000000
[0001.734] I> 44) Base:0x00000000 Size:0x00000000
[0001.738] I> 45) Base:0x00000000 Size:0x00000000
[0001.742] GIC-SPI Target CPU: 0
[0001.745] Interrupts Init done
[0001.748] calling constructors
[0001.751] initializing heap
[0001.754] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.758] initializing threads
[0001.761] initializing timers
[0001.764] creating bootstrap completion thread
[0001.768] top of bootstrap2()
[0001.771] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.776] initializing platform
[0001.779] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.784] W> device prod register failed
[0001.788] I> Bl_dtb @0xaaf00000
[0001.793] W> "plugin-manager" doesn't exist, creating
[0001.796] W> "ids" doesn't exist, creating
[0001.800] W> "connection" doesn't exist, creating
[0001.804] W> "configs" doesn't exist, creating
[0001.819] E> failed to read label property for node 172592: 13
[0001.822] E> failed to read reg property for node 172656: 13
[0001.826] E> failed to read reg property for node 172708: 13
[0001.830] E> failed to read reg property for node 172792: 13
[0001.834] I> Find /i2c@3160000's alias i2c0
[0001.835] I> Reading eeprom i2c=0 address=0x50
[0001.866] I> Device at /i2c@3160000:0x50
[0001.866] I> Reading eeprom i2c=0 address=0x57
[0001.867] E> I2C: slave not found in slaves.
[0001.867] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.868] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.869] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.876] E> eeprom: Failed to read I2C slave device
[0001.881] I> Eeprom read failed 0x3526070d
[0001.886] I> Find /i2c@c240000's alias i2c1
[0001.889] I> Reading eeprom i2c=1 address=0x50
[0001.895] E> I2C: slave not found in slaves.
[0001.897] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.905] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.910] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.920] E> eeprom: Retry to read I2C slave device.
[0001.925] E> I2C: slave not found in slaves.
[0001.929] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.937] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.942] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.952] E> eeprom: Failed to read I2C slave device
[0001.957] I> Eeprom read failed 0x3526070d
[0001.961] I> create_pm_ids: id: 3668-0001-301-F, len: 15
[0001.966] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.977] I> Adding plugin-manager/ids/3668-0001-301=/i2c@3160000:module@0x50
[0001.985] W> "i2c@3160000" doesn't exist, creating
[0001.988] W> "module@0x50" doesn't exist, creating
[0001.994] I> Adding plugin-manager/cvm
[0001.997] W> "chip-id" doesn't exist, creating
[0002.001] I> Adding plugin-manager/chip-id/A02P
[0002.005] I> Plugin-manager override starting
[0002.010] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.021] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.026] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.035] I> Disable plugin-manager status in FDT
[0002.035] I> Plugin-manager override finished successfully
[0002.037] I> gpio framework initialized
[0002.043] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.050] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.056] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.063] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.071] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.078] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.084] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.091] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.099] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.105] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.113] I> fixed regulator driver initialized
[0002.121] I> register 'maxim' power off handle
[0002.122] I> virtual i2c enabled
[0002.123] I> registered 'maxim,max20024' pmic
[0002.128] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.134] I> Boot-device: QSPI
[0002.137] I> Boot_device: QSPI_FLASH instance: 0
[0002.143] I> QSPI source rate = 204000 Khz
[0002.145] I> Requested rate for QSPI clock = 34000 Khz
[0002.151] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.156] I> QSPI Flash Size = 32 MB
[0002.163] I> Qspi initialized successfully
[0002.164] I> qspi flash-0 params source = boot args
[0002.167] I> create_pm_ids: id: 3668-0001-301-F, len: 15
[0002.172] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.188] I> sdmmc-3 params source = safe params
[0002.190] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.209] W> Cannot find any partition table for 00000003
[0002.222] I> Found 12 partitions in SDMMC_USER (instance 3)
[0002.234] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.238] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.238] I> hdmi cable connected
[0002.240] W> set volts not configured for 'vdd-1v0'
[0002.242] W> set volts not configured for 'vdd-1v8-hs'
[0002.242] I> retrieved tmds range from prod_list_hdmi_soc
[0002.246] E> invalid display type
[0002.247] E> cannot find any other nvdisp nodes
[0002.257] E> I2C: Timeout while polling for transfer complete. Last value 0x00000002.
[0002.258] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.260] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.265] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 3.
[0002.275] E> could not read edid
[0002.285] I> hdmi_enable, starting HDMI initialisation
[0002.291] I> hdmi_enable, HDMI initialisation complete
[0002.307] I> Load in CBoot Boot Options partition and parse it
[0002.308] E> Error -9 when finding node with path /boot-configuration
[0002.309] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.309] I> Using default boot order
[0002.310] I> boot-dev-order :-
[0002.313] I> 1.sd
[0002.315] I> 2.usb
[0002.317] I> 3.nvme
[0002.319] I> 4.emmc
[0002.321] I> 5.net
[0002.323] I> Hit any key to stop autoboot:	4	3	2	1
[0004.330] initializing target
[0004.330] calling apps_init()
[0004.331] starting app kernel_boot_app
[0004.342] I> found decompressor handler: lz4-legacy
[0004.342] I> decompressing BMP blob ...
[0004.358] I> Kernel type = Normal
[0004.358] I> ########## SD (0) boot ##########
[0004.359] I> No sdcard
[0004.359] I> -0 params source =
[0004.359] E> Blockdev open: exit error
[0004.359] E> SD boot failed, err: 724238353
[0004.360] I> ########## USB (0) boot ##########
[0004.379] I> Validate XUSB-FW ...
[0004.379] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
[0004.381] I> Encryption fuse is not ON
[0004.382] I> USB Firmware Version: 60.09 release
[0004.437] I> regulator of usb2-0 already enabled
[0004.442] I> regulator of usb2-1 already enabled
[0004.447] I> regulator of usb2-2 already enabled
[0005.514] I> USB 2.0 port 2 new high-speed USB device detected
[0005.515] W> Change usb2 root port id to 3
[0005.515] W> Change usb2 root port id to 2
[0005.517] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada000, cmd_ring.dma = 0xa4ada0c0
[0005.618] I> Start to enumerate device
[0005.619] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada000, cmd_ring.dma = 0xa4ada0c0
[0005.624] I>
[0005.624] I> Enumerated USB Device 05e3:0610
[0005.624] I>
[0005.626] I> Hub:
[0005.626] I> 	Downstream ports        : 4
[0005.626] I> 	Power switching         : Ganged
[0005.626] I> 	Compound device         : No
[0005.627] I> 	Over-current protection : Global
[0005.631] I> 	Hub avg delay           : 4 ns
[0005.635] I> Set interface = 1 (alt setting)
[0005.640] I> Enable hub ports
[0005.647] I> Device detected on port 1
[0005.649] I> Device detected on port 3
[0006.661] I> Reset port 1
[0006.717] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada000, cmd_ring.dma = 0xa4ada0c0
[0006.818] I> Start to enumerate device
[0006.819] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x04)
[0009.829] W> xusbh_wait_irq: Timed out! status = 0x00
[0012.839] W> xusbh_wait_irq: Timed out! status = 0x00
[0012.840] E> Failed to enumerate USB device
[0012.842] I> Reset port 3
[0012.898] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ada100, cmd_ring.dma = 0xa4ada0c0
[0012.999] I> Start to enumerate device
[0013.000] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x04)
[0016.010] W> xusbh_wait_irq: Timed out! status = 0x00
[0019.020] W> xusbh_wait_irq: Timed out! status = 0x00
[0019.021] E> Failed to enumerate USB device
[0019.021] E> failed to start xhci controller
[0019.021] E> Error in init of XUSB host driver, err: 7979000c
[0019.022] W> Failed to initialize device 5-0
[0019.022] E> USB boot failed, err: 2037973004
[0019.023] I> ########## NVME (0) boot ##########
[0019.027] I> Initializing nvme device instance 0
[0019.031] I> Initializing nvme controller
[0019.035] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0019.041] I> vpcie3v3-supply not found
[0019.045] I> vpcie12v-supply not found
[0019.049] W> Failed to get nvidia,plat-gpios
[0019.053] I> tegrabl_pcie_soc_preinit: (0):
[0019.057] I> Unpowergate
[0019.060] I> tegrabl_car_clk_disable(0) ...
[0019.063] I> tegrabl_car_rst_set(CORE, 0) ...
[0019.067] I> tegrabl_car_rst_set(APB, 0) ...
[0019.071] I> tegrabl_car_clk_enable(0) ...
[0019.075] I> tegrabl_car_rst_clear(APB, 0) ...
[0019.080] I> tegrabl_set_ctrl_state(0)
[0019.083] I> CLR PCIE_APB:6
[0019.086] I> tegrabl_pcie_soc_init: (0):
[0019.090] I> APPL initialization ...
[0019.093] I> poweron phys
[0019.096] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0019.102] I> tegrabl_power_on_phy: controller 0 not available
[0019.107] E> Failed to power on phy on controller-0
[0019.113] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0019.117] I> Failed to initialize SoC Host PCIe controller
[0019.123] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x1
[0019.129] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0019.135] W> Failed to open NVME-0, err = 80800601
[0019.140] W> Failed to initialize device 10-0
[0019.144] E> NVME (0) boot failed, err: 0x80800601
[0019.149] I> ########## NVME (1) boot ##########
[0019.153] I> Initializing nvme device instance 1
[0019.158] I> Initializing nvme controller
[0019.162] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0019.168] I> vpcie3v3-supply not found
[0019.172] I> vpcie12v-supply not found
[0019.175] W> Failed to get nvidia,plat-gpios
[0019.179] I> tegrabl_pcie_soc_preinit: (1):
[0019.183] I> Unpowergate
[0019.186] I> tegrabl_car_clk_disable(1) ...
[0019.190] I> tegrabl_car_rst_set(CORE, 1) ...
[0019.194] I> tegrabl_car_rst_set(APB, 1) ...
[0019.198] I> tegrabl_car_clk_enable(1) ...
[0019.202] I> tegrabl_car_rst_clear(APB, 1) ...
[0019.206] I> tegrabl_set_ctrl_state(1)
[0019.210] I> CLR PCIE_APB:6
[0019.213] I> tegrabl_pcie_soc_init: (1):
[0019.216] I> APPL initialization ...
[0019.220] I> poweron phys
[0019.222] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0019.228] I> tegrabl_power_on_phy: controller 1 not available
[0019.234] E> Failed to power on phy on controller-1
[0019.239] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0019.244] I> Failed to initialize SoC Host PCIe controller
[0019.249] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(1); error=0x1
[0019.256] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0019.262] W> Failed to open NVME-1, err = 80800601
[0019.267] W> Failed to initialize device 10-1
[0019.271] E> NVME (1) boot failed, err: 0x80800601
[0019.275] I> ########## NVME (2) boot ##########
[0019.280] I> Initializing nvme device instance 2
[0019.284] I> Initializing nvme controller
[0019.289] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0019.295] I> vpcie3v3-supply not found
[0019.298] I> vpcie12v-supply not found
[0019.302] W> Failed to get nvidia,plat-gpios
[0019.306] I> tegrabl_pcie_soc_preinit: (2):
[0019.310] I> Unpowergate
[0019.313] I> tegrabl_car_clk_disable(2) ...
[0019.316] I> tegrabl_car_rst_set(CORE, 2) ...
[0019.321] I> tegrabl_car_rst_set(APB, 2) ...
[0019.325] I> tegrabl_car_clk_enable(2) ...
[0019.329] I> tegrabl_car_rst_clear(APB, 2) ...
[0019.333] I> tegrabl_set_ctrl_state(2)
[0019.337] I> CLR PCIE_APB:6
[0019.339] I> tegrabl_pcie_soc_init: (2):
[0019.343] I> APPL initialization ...
[0019.346] I> poweron phys
[0019.349] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0019.355] I> tegrabl_power_on_phy: controller 2 not available
[0019.361] E> Failed to power on phy on controller-2
[0019.366] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0019.370] I> Failed to initialize SoC Host PCIe controller
[0019.376] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0019.382] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0019.389] W> Failed to open NVME-2, err = 80800601
[0019.393] W> Failed to initialize device 10-2
[0019.397] E> NVME (2) boot failed, err: 0x80800601
[0019.402] I> ########## NVME (3) boot ##########
[0019.407] I> Initializing nvme device instance 3
[0019.411] I> Initializing nvme controller
[0019.415] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0019.421] I> vpcie3v3-supply not found
[0019.425] I> vpcie12v-supply not found
[0019.428] W> Failed to get nvidia,plat-gpios
[0019.433] I> tegrabl_pcie_soc_preinit: (3):
[0019.437] I> Unpowergate
[0019.439] I> tegrabl_car_clk_disable(3) ...
[0019.443] I> tegrabl_car_rst_set(CORE, 3) ...
[0019.447] I> tegrabl_car_rst_set(APB, 3) ...
[0019.451] I> tegrabl_car_clk_enable(3) ...
[0019.455] I> tegrabl_car_rst_clear(APB, 3) ...
[0019.460] I> tegrabl_set_ctrl_state(3)
[0019.463] I> CLR PCIE_APB:6
[0019.466] I> tegrabl_pcie_soc_init: (3):
[0019.469] I> APPL initialization ...
[0019.473] I> poweron phys
[0019.476] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0019.482] I> tegrabl_power_on_phy: controller 3 not available
[0019.487] E> Failed to power on phy on controller-3
[0019.493] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0019.497] I> Failed to initialize SoC Host PCIe controller
[0019.502] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x1
[0019.509] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0019.515] W> Failed to open NVME-3, err = 80800601
[0019.520] W> Failed to initialize device 10-3
[0019.524] E> NVME (3) boot failed, err: 0x80800601
[0019.529] I> ########## NVME (4) boot ##########
[0019.533] I> Initializing nvme device instance 4
[0019.538] I> Initializing nvme controller
[0019.542] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0019.548] I> vpcie3v3-supply not found
[0019.551] I> vpcie12v-supply not found
[0019.555] W> Failed to get nvidia,plat-gpios
[0019.559] I> tegrabl_pcie_soc_preinit: (4):
[0019.563] I> Unpowergate
[0019.566] I> tegrabl_car_clk_disable(4) ...
[0019.570] I> tegrabl_car_rst_set(CORE, 4) ...
[0019.574] I> tegrabl_car_rst_set(APB, 4) ...
[0019.578] I> tegrabl_car_clk_enable(4) ...
[0019.582] I> tegrabl_car_rst_clear(APB, 4) ...
[0019.586] I> tegrabl_set_ctrl_state(4)
[0019.590] I> CLR PCIE_APB:6
[0019.593] I> tegrabl_pcie_soc_init: (4):
[0019.596] I> APPL initialization ...
[0019.599] I> poweron phys
[0019.602] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0019.608] I> tegrabl_power_on_phy: power on phy @0x3f40000
[0019.741] I> PCIe controller-4 link is up
[0019.741] I> tegra_pcie_info[4].cfg0_base = 0x36000000
[0019.741] I> tegra_pcie_info[4].cfg1_base = 0x36020000
[0019.742] I> tegra_pcie_info[4].atu_dma_base = 0x36040000
[0019.742] I> tegra_pcie_bus[4].mem = 0x36200000
[0019.742] I> Scanning busnr: 0 devfn: 0
[0019.743] I> PCIe IDs: 0x1ad110de
[0019.746] I> PCIe RID_CC: 0x60400a1
[0019.749] I> Scanning busnr: 1 devfn: 0
[0019.753] I> PCIe IDs: 0x28061b21
[0019.756] I> PCIe RID_CC: 0x6040001
[0019.759] I> PCI Config: I/O=0x36100000, Memory=0x36200000
[0019.765] I> MEM bar_num=4 bar=0x36200000
[0019.768] I> IO bar_num=5 bar=0x36100000
[0019.772] I> Number of PCIe devices detected: 2
[0019.777] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(4); error=0x0
[0019.784] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0019.790] W> Failed to open NVME-4, err = 80800612
[0019.794] W> Failed to initialize device 10-4
[0019.799] E> NVME (4) boot failed, err: 0x80800612
[0019.803] I> ########## NVME (5) boot ##########
[0019.808] I> Initializing nvme device instance 5
[0019.812] I> Initializing nvme controller
[0019.817] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0019.822] I> vpcie3v3-supply not found
[0019.826] I> vpcie12v-supply not found
[0019.830] W> Failed to get nvidia,plat-gpios
[0019.834] I> tegrabl_pcie_soc_preinit: (5):
[0019.838] I> Unpowergate
[0019.840] I> tegrabl_car_clk_disable(5) ...
[0019.844] I> tegrabl_car_rst_set(CORE, 5) ...
[0019.848] I> tegrabl_car_rst_set(APB, 5) ...
[0019.853] I> tegrabl_car_clk_enable(5) ...
[0019.856] I> tegrabl_car_rst_clear(APB, 5) ...
[0019.861] I> tegrabl_set_ctrl_state(5)
[0019.864] I> CLR PCIE_APB:6
[0019.867] I> tegrabl_pcie_soc_init: (5):
[0019.871] I> APPL initialization ...
[0019.874] I> poweron phys
[0019.877] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0019.883] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0019.888] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0019.894] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0019.899] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0019.904] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0019.910] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0019.915] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0019.920] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0021.026] C> Failed to link up controller-5
[0021.027] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0021.027] I> Failed to initialize SoC Host PCIe controller
[0021.027] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0021.028] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0021.028] W> Failed to open NVME-5, err = 80800612
[0021.033] W> Failed to initialize device 10-5
[0021.037] E> NVME (5) boot failed, err: 0x80800612
[0021.042] I> ########## Fixed storage boot ##########
[0021.046] I> Loading kernel-bootctrl from partition
[0021.051] I> Loading partition kernel-bootctrl at 0xa4b90000 from device(0x1)
[0021.066] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0021.066] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0021.072] I> Already published: 00010003
[0021.076] I> Look for boot partition
[0021.079] I> Fallback: assuming 0th partition is boot partition
[0021.085] I> Set 1th partition is boot partition
[0021.090] I> Detect filesystem
[0021.117] I> Loading extlinux.conf ...
[0021.117] I> Loading extlinux.conf binary from rootfs ...
[0021.117] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0021.166] I> Loading extlinux.conf sig file from rootfs ...
[0021.167] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0021.204] I> Validate extlinux.conf ...
[0021.204] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0021.205] E> digest on binary did not match!!
[0021.205] C> OEM authentication of extlinux.conf payload failed!
[0021.205] W> Failed to validate extlinux.conf binary from rootfs (err=1077936152, fail=0)
[0021.207] W> Security fuse not burned, ignore validation failure
[0021.213] I> restore load_size to 880
[0021.217] I> L4T boot options
[0021.220] I> [1]: "primary kernel"
[0021.223] I> Enter choice:
[0024.226] I> Continuing with default option: 1
[0024.226] I> Loading kernel ...
[0024.226] I> Loading kernel binary from rootfs ...
[0024.227] I> rootfs path: /sdmmc_user/boot/Image
[0024.676] I> Loading kernel sig file from rootfs ...
[0024.676] I> rootfs path: /sdmmc_user/boot/Image.sig
[0024.701] I> overload load_size to 34691080 (from 34691088)
[0024.701] I> Validate kernel ...
[0024.702] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0025.018] I> Encryption fuse is not ON
[0025.069] I> Loading kernel-dtb ...
[0025.070] I> No kernel-dtb binary path
[0025.070] I> Continue to load from partition ...
[0025.070] I> A/B: bin_type (38) slot 1
[0025.071] I> Loading kernel-dtb_b from partition
[0025.071] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0025.085] I> Validate kernel-dtb ...
[0025.085] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0025.088] I> Encryption fuse is not ON
[0025.091] I> Loading ramdisk from rootfs ...
[0025.091] I> Loading ramdisk binary from rootfs ...
[0025.093] I> rootfs path: /sdmmc_user/boot/initrd
[0025.211] I> Loading ramdisk sig file from rootfs ...
[0025.212] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0025.243] I> overload load_size to 7238344 (from 7238352)
[0025.243] I> Validate ramdisk ...
[0025.243] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0025.310] I> Encryption fuse is not ON
[0025.350] I> Kernel hdr @0xa4b90000
[0025.350] I> Kernel dtb @0x90000000
[0025.350] I> decompressor handler not found
[0025.351] I> Copying kernel image (34691080 bytes) from 0xa4b90000 to 0x80080000 ... [0025.383] I> Done
[0025.384] I> Updated bpmp info to DTB
[0025.385] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0025.385] I> Updated initrd info to DTB
[0025.386] W> WARN: Fail to override "console=none" in commandline
[0025.386] I> Active rootfs suffix: _b
[0025.387] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0025.389] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0025.396] I> Active slot suffix: _b
[0025.399] I> add_boot_slot_suffix: slot_suffix = _b
[0025.404] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix=_b tegra_fbmem=0x800000@0xa06b2000 lut_mem=0x2008@0xa06af000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0025.434] I> Updated bootarg info to DTB
[0025.438] W> MAC addr invalid!
[0025.441] E> Failed to get WIFI MAC address
[0025.445] W> MAC addr invalid!
[0025.447] E> Failed to get Bluetooth MAC address
[0025.452] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:67:66:5d
[0025.459] W> "plugin-manager" doesn't exist, creating
[0025.463] I> Adding /chosen/plugin-manager/cvm
[0025.467] W> "chip-id" doesn't exist, creating
[0025.472] I> Adding /chosen/plugin-manager/chip-id
[0025.476] W> "configs" doesn't exist, creating
[0025.480] I> Adding /chosen/plugin-manager/configs
[0025.485] W> "ids" doesn't exist, creating
[0025.489] I> Adding /chosen/plugin-manager/ids
[0025.493] W> "odm-data" doesn't exist, creating
[0025.498] I> Adding /chosen/plugin-manager/odm-data
[0025.505] W> "memory" doesn't exist, creating
[0025.507] I> [0] START: 0x80000000, END: 0xac000000
[0025.511] I> [1] START: 0xac004000, END: 0xf0ad0000
[0025.516] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0025.521] I> dram_block larger than 80000000
[0025.525] I> [3] START: 0x100000000, END: 0x280000000
[0025.530] I> added [base:0x80000000, size:0x2c000000] to /memory
[0025.536] I> added [base:0xac200000, size:0x44800000] to /memory
[0025.541] I> added [base:0x100000000, size:0x180000000] to /memory
[0025.548] I> Updated memory info to DTB
[0025.551] E> add_disp_param: failed to get display params for du=1
[0025.557] W> "reset" doesn't exist, creating
[0025.562] I> Adding ecid(000000016430b00808000000140501c0) to DT
[0025.567] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0025.572] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0025.577] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0025.581] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0025.586] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0025.591] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0025.596] I> Deleted cpu@6 node in DT
[0025.599] I> Deleted cpu@7 node in DT
[0025.603] I> Deleted cluster3 node in FDT
[0025.607] I> Update arm-pmu in FDT
[0025.610] I> - update property: interrupts
[0025.614] I> - update property: interrupt-affinity
[0025.619] W> "misc-data" doesn't exist, creating
[0025.623] I> Boot-device: QSPI
[0025.626] W> Unknown boot device
[0025.629] I> Add storage-qspi to plugin-manager/misc-data
[0025.634] W> Unknown storage device
[0025.637] I> Add serial number:1420822057568 as DT property
[0025.643] I> Plugin-manager override starting
[0025.647] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0025.654] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0025.660] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0025.668] I> Disable plugin-manager status in FDT
[0025.669] I> Plugin-manager override finished successfully
[0025.675] I> tegrabl_load_kernel_and_dtb: Done
[0025.720] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (revo@ai) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #4 SMP PREEMPT Wed Apr 13 16:10:06 CST 2022
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a06b2000
[    0.000000] Found lut_mem: 00002008@a06af000
[    1.026643] pca953x 2-0020: failed reading register
[    2.002592] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    2.002695] tegradc 15200000.nvdisplay: failed to register ihub bw client
[    2.006592] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    2.006664] tegradc 15210000.nvdisplay: failed to register ihub bw client
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[    5.705230] cgroup: cgroup2: unknown option "nsdelegate"
[    5.796103] systemd[2314]: /lib/systemd/system-generators/netplan failed with exit status 127.
��[    7.716649] random: crng init done
[    7.716900] random: 7 urandom warning(s) missed due to ratelimiting
[    7.942077] using random self ethernet address
[    7.942340] using random host ethernet address
[    8.512694] using random self ethernet address
[    8.512933] using random host ethernet address
Ubuntu 18.04.6 LTS ubuntu ttyTCU0
ubuntu login: [   19.383230] Bridge firewalling registered
[   19.747565] igb 0004:05:00.0: exceed max 2 second
[   40.236470] mttcan c310000.mttcan can0: entered error warning state
[   40.238395] mttcan c310000.mttcan can0: entered error passive state
[  677.707278] hrtimer: interrupt took 373088 ns
I guess the issue here is your jetpack release is too old.
New Xaiver NX has PCN update which has DRAM component update. New DRAM needs new memory config otherwise it would have problem.
Which would be the first Jetpack version which supports the new DRAM? The support of our carrier board supplier is unfortunately very bad in providing the needed informations to build the jetpack.
For rel-32, rel-32.7.4 will definitely support this module.
