Emotion net config for Deepstream
• Hardware (T4/V100/Xavier/Nano/etc)
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I am trying to run Emotion net on deepstream:
enginePath=../../../../models/emotion/emotion.etlt_b32_gpu0_fp16.engine
etltPath=../../../../models/emotion/emotion.etlt
etltKey=nvidia_tlt
networkMode can be int8, fp16 or fp32
networkMode=fp16
batchSize=32
inputWidth=136
inputHeight=1
inputType=
label=0,neutral
label=1,happy
label=2,surprise
label=3,squint
label=4,disgust
label=5,scream
Is this config correct??
OR is this the config file??
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#model-file=/opt/nvidia/deepstream/deepstream-6.1/deepstream_tao_apps/apps/tao_detection/Age-and-Gender-Recognition/models/age_net.caffemodel
#proto-file=/opt/nvidia/deepstream/deepstream-6.1/deepstream_tao_apps/apps/tao_detection/Age-and-Gender-Recognition/models/age_deploy.prototxt
model-engine-file=/opt/nvidia/deepstream/deepstream-6.1/model.etlt_b32_gpu0_int8.engine
tlt-model-key=nvidia_tlt
tlt-encoded-model=/opt/nvidia/deepstream/deepstream-6.1/model.etlt
labelfile-path=/opt/nvidia/deepstream/deepstream-6.1/labels_emotion.txt
#int8-calib-file=/opt/nvidia/deepstream/deepstream-6.1/deepstream_tao_apps/apps/tao_detection/int8_calibration.txt
#enginePath=../../../../models/emotion/emotion.etlt_b32_gpu0_fp16.engine
#etltPath=../../../../models/emotion/emotion.etlt
etltKey=nvidia_tlt
#dynamic batch size
batch-size=32
0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=1
#output-blob-names=softargmax,softargmax:1,conv_keypoints_m80
output-blob-names = input_landmarks:0,softmax/Softmax:0
#0=Detection 1=Classifier 2=Segmentation 100=other
network-type=100
Enable tensor metadata output
output-tensor-meta=1
#1-Primary 2-Secondary
process-mode=2
gie-unique-id=2
operate-on-gie-id=1
net-scale-factor=1.0
offsets=0.0
input-object-min-width=5
input-object-min-height=5
#0=RGB 1=BGR 2=GRAY
model-color-format=2
[class-attrs-all]
threshold=0.0
What should I add, and what should I delete?
On the deepstream tao_apps it is said for emotion net, we can use Facial landmarks config, but when I use that there is a binding error, what is the actual config file contents???
Refer to deepstream_tao_apps/apps/tao_others at release/tao3.0_ds6.0.1 · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
A sample of emotions:
./deepstream-emotion-app 1 ../../../configs/facial_tao/sample_faciallandmarks_config.txt file:///usr/data/faciallandmarks_test.jpg ./emotion
This is what I am trying to tell…
The config file is from Facial landmarks!!!
The contents of the faciallandmarks.txt file::::
numLandmarks=80
maxBatchSize=32
inputLayerWidth=80
inputLayerHeight=80
This is of no use to me.
What is this config then?
enginePath: ../../../../models/emotion/emotion.etlt_b32_gpu0_fp16.engine
etltPath: ../../../../models/emotion/emotion.etlt
etltKey: nvidia_tlt
networkMode: fp16
batchSize: 32
inputWidth: 136
inputHeight: 1
inputType:
label:
  • 0,neutral
  • 1,happy
  • 2,surprise
  • 3,squint
  • 4,disgust
  • 5,scream
Please refer to the master branch.
or ./deepstream-emotion-app emotion_app_config.yml
Please check if you can run with the default setting successfully.
Have you seen the config file for the same?
I am trying to Run a Primary model [Face], then Run a Secondary Classifier [Emotion net]…
The secondary is failing!!
I have been looking into this repo, and what I don’t understand is why use faciallandmark config for emotion net.
Please refer to deepstream_tao_apps/apps/tao_others/deepstream-emotion-app at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
The application pipeline graph
emotion application pipeline
