• Hardware RTX
• Network Type : Detectnet_v2
• TLT Version dockers:
nvidia/tao/tao-toolkit-tf:
v3.21.11-tf1.15.5-py3:
• Training spec file
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Issue : getting empty TFRecords.
Log:
tao detectnet_v2 dataset_convert -d $SPECS_DIR/detectnet_v2_tfrecords_kitti_trainval.txt -o $DATA_DIR/tfrecords/kitti_trainval/kitti_trainval
2022-02-12 17:37:03,802 [INFO] root: Registry: ['nvcr.io']
2022-02-12 17:37:03,849 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
2022-02-12 17:37:03,926 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/sitevisit/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2022-02-12 12:07:08,804 [INFO] iva.detectnet_v2.dataio.build_converter: Instantiating a kitti converter
2022-02-12 12:07:08,804 [INFO] root: Instantiating a kitti converter
2022-02-12 12:07:08,804 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib: Creating output directory /workspace/tao-experiments/data/tfrecords/kitti_trainval
2022-02-12 12:07:08,804 [INFO] root: Generating partitions
2022-02-12 12:07:08,805 [INFO] iva.detectnet_v2.dataio.kitti_converter_lib: Num images in
Train: 0 Val: 0
2022-02-12 12:07:08,805 [INFO] root: Num images in
Train: 0 Val: 0
2022-02-12 12:07:08,805 [INFO] iva.detectnet_v2.dataio.kitti_converter_lib: Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2022-02-12 12:07:08,805 [INFO] root: Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2022-02-12 12:07:08,805 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib: Cumulative object statistics
2022-02-12 12:07:08,805 [INFO] root: Cumulative object statistics
Wrote the following numbers of objects:
2022-02-12 12:07:08,805 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib: Class map.
Label in GT: Label in tfrecords file
2022-02-12 12:07:08,805 [INFO] root: Class map.
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2022-02-12 12:07:08,805 [INFO] root: For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2022-02-12 12:07:08,805 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib: Tfrecords generation complete.
2022-02-12 12:07:08,805 [INFO] root: TFRecords generation complete.
2022-02-12 17:37:09,610 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I resized my images to the size 1280 x 960 as I thought it might be a size related error, but didn’t help.
Same command and combination of spec file with different image-label set produces valid tfrecords. What am I doing wrong here?
