Enable INT8 mode for a YOLO/ONNX model in DeepStream
🖥️ Environment
  • DeepStream version: 7.0.0
  • TensorRT version (C++/DeepStream): 8.6.1.6
  • TensorRT version (Python): 10.13.2.6 (note: mismatch, but DS links against 8.6.1.6)
  • CUDA version: 11.5 (from nvcc)
  • GPU driver: 535.230.02
  • GPU: NVIDIA RTX A4000 (16GB)
  • CUDA reported by driver: 12.2
  • OS: Ubuntu 22.04.5 LTS, kernel 6.8.0-65-generic
Implementation
  1. Model: Custom trained YOLOv8 (Ultralytics export)
  2. Export:
    yolo export model=custom_yolov8.pt format=onnx opset=12
  3. ONNX opset: 12
  4. Precision: Trying INT8 (with calibration table)
\[property\]
net-scale-factor=0.0039215697906911373
model-color-format=0
int8-calib-file=/home/proglint-ai10/interns/Optimization/quantisation/Quantization-YOLOv8/calib.table
onnx-file=checkout.onnx
labelfile-path=cash_checkout.txt
network-mode=1                 # INT8
num-detected-classes=18
interval=0
gie-unique-id=3
process-mode=1
network-type=0
network-input-order=0          # NCHW
cluster-mode=2
maintain-aspect-ratio=1
scaling-filter=1
symmetric-padding=1
offset=114;114;114;
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=../nvdsinfer_custom_impl/libnvdsinfer_custom_impl_Yolo.so
\[class-attrs-all\]
nms-iou-threshold=0.50
topk=300
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1129 Build engine failed from config file
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:821 failed to build trt engine.
ERROR: NvDsInferContextImpl::buildModel() build engine file failed
ERROR: NvDsInferContextImpl::generateBackendContext() build backend context failed
ERROR: NvDsInferContextImpl::initialize() generate backend failed, check config file settings
WARN  : error: Failed to create NvDsInferContext instance
NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Can Anyone help me how to debug this? I’ve followed everything available in the git and forums. Nothing seems working i donno what am i missiong
Please use “trtexec” to check your onnx model and the calib file first.
The DeepStream 7.0 GA is bsed on CUDA 12.2 version. Please make sure you have followed the DeepStream compatibility limitation. Installation — DeepStream documentation
Does exporting TensorRT INT8 engine directly from Ultralytics work?
Please consult the author of Ultralytics for their own work.
You can verify the ONNX model and your calibration file with “trtexec” to check what is the issue with the model itself.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
