solo_wh
November 14, 2024, 3:47am
1
Hi nvidia team:
I want to use AO_HV_SOC_GPIO50(PBB.02) as pps-in, and use ppstest tool to monitor the signal, but it seem’s not working. here is my debug info.
On Jetson agx orin 64 with Jetpack 6.0
1.Modify <egra234-p3737-0000+p3701-xxxx-nv-common.dtsi> as follows:
define PPS_GPIO TEGRA234_AON_GPIO(BB, 2)
pps {
compatible =“pps-gpio”;
gpios = <&gpio PPS_GPIO GPIO_ACTIVE_HIGH>;
/assert-falling-edge; /
status =“okay”;
dtb:
tegra234-p3737-0000+p3701-0005-nv.zip (38.8 KB)
2.pinmux:
nvidia@tegra-ubuntu:~$ sudo busybox devmem 0x0c303050 w 0x0000c055
0x0000C055
3.config:
CONFIG_PPS_CLIENT_KTIMER=y
CONFIG_PPS_CLIENT_LDISC=y
CONFIG_PPS_CLIENT_GPIO=y
and ppstest detects that /dev/pps0 times out, it seem’s not working.
nvidia@tegra-ubuntu:~$ sudo ppstest /dev/pps1
trying PPS source “/dev/pps1”
found PPS source “/dev/pps1”
ok, found 1 source(s), now start fetching data…
time_pps_fetch() error -1 (Connection timed out)
full dmesg:
dmesg.txt (66.5 KB)
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
solo_wh
November 14, 2024, 5:52am
3
Hi,thanks for reply, Is that for pps gpio config?
Hi solo_wh,
Could you share the block diagram of your connection with PPS signal?
Have you also measured if there PPS signal input from PBB.02?
solo_wh
November 15, 2024, 8:07am
6
1.custom board for AGX Orin 64G
2.orin<-pps <-fpga
3. PPS signal input from
PBB.02:
Have you also tried to capture from /dev/pps0?
Please also share the result of $ cat /proc/interrupts|grep -i pps on your board
solo_wh
November 25, 2024, 1:57am
10
this is pps0 :
But this pps0 doesn’t look like actual data because I turned off the PPS input, and pps0 still has output
okay, /dev/pps1 should be the one from PPS signal.
please configure this line as following since PBB.02 belongs to GPIO AON controller.
gpios = <&gpio_aon PPS_GPIO GPIO_ACTIVE_HIGH>;
