Enabling SPI on Jetson Nano 2GB
I have used Jetson IO to configure the 40 pin header in the Nano 2GB for SPI1 (LT: 32.4.4).
I was wondering if there are any SPI libraries that are provided that can be used to test the connection, modify word length, speed, etc.? I noticed that spidev is not in the native SD card image.
For the dev spi node you need to enable it by the jetson-io.
Also you can search the SPI relative topic to get more information.
I’m also trying to get SPI running on my nano. I have used jetson-io to attempt to enable SPI 1. It shows as enabled after reboot, but it does not actually work. There is nothing in /dev named SPI and lsmod does not list spidev. I have also installed spidev via pip3 install spidev. I think I’m missing a crucial step here, but I do not know what it is. I have tried the loopback test and get ā€œcan’t open device: No such file or directory Aborted (core dumped)ā€
Do I need to build a device tree? I have this all running on a Raspberry Pi, which I’m fairly comfortable with. It seems like the jetson-io should make it similar, but I’m lost with the dtc stuff, so if you know of somewhere that could walk me through that step-by-step, I would really appreciate it.
Need modeprobe spidev to load spidev module to generate /dev/spidev.x.x
Thanks for the quick reply! I used modprobe (I assume the ā€˜e’ was a typo) as follows:
sudo modprobe spidev
and something that seems like magic happened. I now have the devices and lsmod shows spidev. Awesome!
Now I can get the spi test loop working and it receives what it sent. Also awesome!
Now I run my actual code (which is to a RFM69 radio module) and it says
ā€œImportError: No module named spidevā€ when my code tries ā€œimport spidevā€
How do I point it to the spidev module? I know it is there…
May need install spidev python module.
pip3 install spidev
