I am trying to enable SPI1 on my Jetson Nano 4GB developer board.
Running jetson-io works and retains the settings between reboots.
But, I have yet to see /dev/spi* created
I am running code from
https://developer.nvidia.com/jetson-nano-sd-card-image
jetson-nano-jp46-sd-card-image.zip
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t210ref, EABI: aarch64, DATE: Mon Jul 26 19:20:30 UTC 2021
Please have below command to enable the spidev module.
sudo modprobe spidev
That is the article I was following to begin with.
This worked!
I am surprised that I find no mention of this command in any of the articles I found for using SPI on Jetson.
I have to re-issue this command each time I boot. Is there a permanent solution?
Yes, you can add this command to a start up script for it.
system
Closed
November 24, 2021, 2:21am
11
