Hello everyone, I surfed the internet and all the forum looking for solutions to enable SPI on Jetson Nano emmc production module but I didn’t find any tidy guide that works. I made many attempts but SPI still does not work. Unfortunately I know Jetson-io.py doesn’t work on this board. I hope in your support.
Have check below topic.
I tried several times to execute the various steps in the thread you indicated but I stole several hours of work and in the end I never had physical signals coming out of the SPI on the oscilloscope. It is very strange that there are no scripts from Nvidia for a production module or a simple guide that allows you to enable a pin in a short time. So please let me know if there is something acceptable because it is not possible to lose days of work to enable one pin.
There’s jetson-io for none EMMC module to configure those PINs.
What’s your BSP version?
cat /etc/nv_tegra_release
Attached is the dtb for r32.6.1 for your reference.
nano-spi.dtb (233.6 KB)
I have EMMC module (also called production module). Is there a script or a simple way to enable SPI? I trust in you help, I’m not interested in SD or none emmc modules because on that boards Jetson-io worked fine. Thank you.
Please @ShaneCCC , is it possible to have a tested step by step procedure if there is no script an there is no other simplest ways? Can you suggest here the procedure? Thanks
