Hi NV_Team,
I am using JetPack4.4/4.5 to do Nano spi1 loop test all failed. I have modify the pinmux of spi1 configuration and remove ‘C’ in gpio definition.
I have removed all of the gpio group B and C from this file hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
tegra210-porg-pinmux-p3448-0002-b00.dtsi
spi1_mosi_pc0 {
nvidia,pins = "spi1_mosi_pc0";
nvidia,function = "spi1";
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
spi1_miso_pc1 {
nvidia,pins = "spi1_miso_pc1";
spi1_sck_pc2 {
nvidia,pins = "spi1_sck_pc2";
spi1_cs0_pc3 {
nvidia,pins = "spi1_cs0_pc3";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
spi1_cs1_pc4 {
nvidia,pins = "spi1_cs1_pc4";
tegra210-porg-p3448-common.dtsi
spi@7000d400 { /* SPI 1 to 40 pin header */
status = "okay";
spi@0 {
status = "okay";
compatible = "spidev";
reg = <0x0>;
spi-max-frequency = <33000000>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <7>;
spi@1 {
status = "okay";
reg = <0x1>;
controller-data {
nvidia@nano:~/tools/spi$ sudo ./spidev_test -D /dev/spidev0.0 -v -p ss
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | 73 73 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | ss
RX | 00 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | ..
nvidia@nano:~$ sudo cat /sys/kernel/debug/tegra_gpio
Name:Bank:Port CNF OE OUT IN INT_STA INT_ENB INT_LVL
A: 0:0 64 40 40 04 00 00 000000
B: 0:1 f0 00 00 00 00 00 000000
C: 0:2 1f 00 00 00 00 00 000000
D: 0:3 00 00 00 00 00 00 000000
E: 1:0 40 40 00 00 00 00 000000
nvidia@nano:~$ sudo cat /sys/kernel/debug/tegra_pinctrl_reg |grep 'spi'
Bank: 1 Reg: 0x70003050 Val: 0x0000e044 -> spi1_mosi_pc0
Bank: 1 Reg: 0x70003054 Val: 0x0000e044 -> spi1_miso_pc1
Bank: 1 Reg: 0x70003058 Val: 0x0000e044 -> spi1_sck_pc2
Bank: 1 Reg: 0x7000305c Val: 0x0000e048 -> spi1_cs0_pc3
Bank: 1 Reg: 0x70003060 Val: 0x0000e048 -> spi1_cs1_pc4
I have checked this topic, but not worked, can you help to check my configration about SPI on Nano?
