I’m trying to enable SPI CAN on NANO, and have followed some topics related, but things just don’t work out.
Use Pin 110, 108, 104, 106 (SPI1_CS0, SPI1_MISO, SPI1_MOSI, SPI1_SCK) and an interrupt pin 130 to MCP2515.
I altered some files as below:
.../tegra210-porg-gpio-p3448-0002-b00.dtsi | 6 +----
.../tegra210-porg-pinmux-p3448-0002-b00.dtsi | 8 +++----
.../kernel-dts/tegra210-porg-p3448-common.dtsi | 28 ++++++++++++++++++----
3 files changed, 29 insertions(+), 13 deletions(-)
diff --git a/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi b/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
index ac8bda8..650b165 100644
--- a/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
+++ b/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
@@ -27,10 +27,6 @@
gpio_default: default {
gpio-input = <
TEGRA_GPIO(BB, 0)
- TEGRA_GPIO(B, 4)
- TEGRA_GPIO(B, 5)
- TEGRA_GPIO(B, 6)
- TEGRA_GPIO(B, 7)
TEGRA_GPIO(DD, 0)
TEGRA_GPIO(E, 6)
TEGRA_GPIO(S, 5)
@@ -58,6 +54,7 @@
TEGRA_GPIO(H, 2)
TEGRA_GPIO(H, 5)
TEGRA_GPIO(H, 6)
+ TEGRA_GPIO(I, 0)
TEGRA_GPIO(CC, 4)
gpio-output-low = <
@@ -67,7 +64,6 @@
TEGRA_GPIO(H, 3)
TEGRA_GPIO(H, 4)
TEGRA_GPIO(H, 7)
- TEGRA_GPIO(I, 0)
TEGRA_GPIO(I, 2)
gpio-output-high = <
diff --git a/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi b/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
index 60e5bb4..109a069 100644
--- a/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
+++ b/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
@@ -505,7 +505,7 @@
spi2_mosi_pb4 {
nvidia,pins = "spi2_mosi_pb4";
- nvidia,function = "rsvd2";
+ nvidia,function = "spi2";
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
@@ -513,7 +513,7 @@
spi2_miso_pb5 {
nvidia,pins = "spi2_miso_pb5";
@@ -521,7 +521,7 @@
spi2_sck_pb6 {
nvidia,pins = "spi2_sck_pb6";
@@ -529,7 +529,7 @@
spi2_cs0_pb7 {
nvidia,pins = "spi2_cs0_pb7";
diff --git a/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi b/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi
index 57cb90c..dcb2ac9 100644
--- a/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi
+++ b/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi
@@ -205,8 +205,17 @@
+ can_clock: can_clock{
+ phandle = <0x12c>;
+ linux,phandle = <0x12c>;
+ compatible = "fixed-clock";
+ #clock-cells = <0>;
+ clock-frequency = <8000000>;
+ clock-accuracy = <100>;
spi@7000d400 { /* SPI 1 to 40 pin header */
- status = "okay";
+ status = "disabled";
spi@0 {
compatible = "spidev";
reg = <0x0>;
@@ -229,13 +238,24 @@
spi@7000d600 { /* SPI 2 to 40 pin header */
status = "okay";
+ num-cs = <1>;
+ cs-gpios = <&gpio TEGRA_GPIO(B, 7) GPIO_ACTIVE_LOW>;
spi@0 {
- compatible = "spidev";
+ status = "okay";
+ compatible = "microchip,mcp2515";
reg = <0x0>;
- spi-max-frequency = <33000000>;
+ clocks = <&can_clock>;
+ interrupt-parent = <&gpio>;
+ interrupts = <TEGRA_GPIO(I, 0) 0x01>;
+ vdd-supply = <&battery_reg>;
+ xceiver-supply = <&battery_reg>;
+ spi-max-frequency = <10000000>;
controller-data {
nvidia,enable-hw-based-cs;
- nvidia,rx-clk-tap-delay = <6>;
+ nvidia,cs-setup-clk-count = <0x1e>;
+ nvidia,cs-hold-clk-count = <0x1e>;
+ nvidia,rx-clk-tap-delay = <0x1f>;
+ nvidia,tx-clk-tap-delay = <0x0>;
spi@1 {
2.7.4
0001-modify-for-SPI-CAN.patch (4.3 KB)
Then update pinmux as Pinmux Changes as follow:
6.Rebuild the device tree image:
$ cd <src_path>/kernel/kernel-4.9/
$ make ARCH=arm64 tegra_defconfig
$ make ARCH=arm64 dtbs
7.Copy the updated device tree image to the L4T release tree:
$ cp arch/arm64/boot/dts/tegra210-p3448-0002-p3449-0000-b00.dtb <path-to-L4T-release>/kernel/dtb/
And flash,
sudo ./flash.sh -r -k DTB jetson-nano-emmc mmcblk0p1
sudo ./flash.sh -r -k RP1 jetson-nano-emmc mmcblk0p1
Now check on target.
~$ sudo cat /sys/kernel/debug/pinctrl/pinctrl-handles | grep spi2
type: MUX_GROUP controller 700008d4.pinmux group: spi2_mosi_pb4 (37) function: spi2 (55)
type: CONFIGS_GROUP controller 700008d4.pinmux group spi2_mosi_pb4 (37)config pull=1
type: MUX_GROUP controller 700008d4.pinmux group: spi2_miso_pb5 (38) function: spi2 (55)
type: CONFIGS_GROUP controller 700008d4.pinmux group spi2_miso_pb5 (38)config pull=1
type: MUX_GROUP controller 700008d4.pinmux group: spi2_sck_pb6 (39) function: spi2 (55)
type: CONFIGS_GROUP controller 700008d4.pinmux group spi2_sck_pb6 (39)config pull=1
type: MUX_GROUP controller 700008d4.pinmux group: spi2_cs0_pb7 (40) function: spi2 (55)
type: CONFIGS_GROUP controller 700008d4.pinmux group spi2_cs0_pb7 (40)config pull=1
type: MUX_GROUP controller 700008d4.pinmux group: spi2_cs1_pdd0 (41) function: rsvd1 (42)
type: CONFIGS_GROUP controller 700008d4.pinmux group spi2_cs1_pdd0 (41)config pull=1
~$ sudo grep "Name:\|I:\| B:" /sys/kernel/debug/tegra_gpio
Name:Bank:Port CNF OE OUT IN INT_STA INT_ENB INT_LVL
B: 0:1 80 80 80 80 00 00 000000
I: 2:0 07 07 03 00 00 00 000000
But get the result:
~$ dmesg | grep spi
[ 0.448818] iommu: Adding device 7000d600.spi to group 7
[ 3.689779] mcp251x spi1.0: Cannot initialize MCP2515. Wrong wiring?
[ 3.698816] mcp251x spi1.0: Probe failed, err=19
Have followed threads below, but SPI CAN never worked.
Any help is appreciated.
Thanks,
