Here are the steps you can follow:
- Choose a GPIO pin on J41 (40 pin header) and enable interrupts on that pin.
- Make proper connections from MCP2515 to SPI controller on J41. There are 2 SPI controller present on J41. I have connected two MCP chips on respective SPI controller with INT pin connected to chosen GPIO.
- Make changes in Nano DTB:
can_clock: can_clock {
compatible = “fixed-clock”;
#clock-cells = <0>;
clock-frequency = <20000000>;
clock-accuracy = <100>;
spi@7000d400 { /* SPI 1 to 40 pin header */
status = “okay”;
spi@0 {
compatible = “microchip,mcp2515”;
reg = <0x0>;
spi-max-frequency = <10000000>;
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x7>;
clocks = <&can_clock>;
interrupts = <&gpio TEGRA_GPIO(Z, 0) 0x1>; // GPIO pin chosen from 40 pin header
controller-data {
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
nvidia,tx-clk-tap-delay = <0x0>;
spi@7000d600 { /* SPI 2 to 40 pin header */
status = “okay”;
spi@0 {
reg = <0x0>;
nvidia,rx-clk-tap-delay = <0x6>;
interrupts = <&gpio TEGRA_GPIO(V, 0) 0x1>;
controller-data {
4) Make changes in Nano pinmux and GPIO dtb:
Enable SPI0 and SPI1 with SPI functionality by configuring pins(tristate disable, input enable, change function property…)
Add GPIO entry in gpio-input section.
Flash with the change in DTB.
Now on device after boot, run following commands:
ip link set can0 type can bitrate 500000
ip link set can0 up
ip link set can1 type can bitrate 500000
ip link set can1 up
candump -x any
cansend can0 123#abcdabcd
Thanks,
Shubhi
