Mcp2515 on jetson nano
  1. I have connect mcp2515 module to jetson nano 4gb board, like this:
  miso <-> pin21
  mosi <-> pin19
  sclk <-> pin23
  cs   <-> pin24
  int  <-> pin31
  vcc  <-> 5v0
  1. Then setting device tree of mcp251x by jetson-io.py
  2. I got some log form dmesg | grep mcp,return like this:
[    4.551542] mcp251x: loading out-of-tree module taints kernel.
[    4.551900] mcp251x: loading out-of-tree module taints kernel.
[    4.566984] mcp251x spi0.0 can0: MCP2515 successfully initialized.
  1. I try to use some command to send can bus message , like this:
sudo ifconfig can0 down
sudo ip link set can0 type can bitrate 250000
sudo ifconfig can0 up
cansend can0 123#DEADBEEF
But I can not received any message on another CAN-USB device which sent from jetson nano through mcp2515.
With the help of oscilloscope, I could saw spi signal on miso、mosi、sck、cs. I could not saw any voltage changed on TXCAN and RXCAN or CAN_H and CAN_L.
The CAN transceiver is TJA1050 , it is ok on other places.
  1. The result of ip -d -s link show can0, like this:
4: can0: <NOARP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
    link/can  promiscuity 0
    can state STOPPED restart-ms 0
          bitrate 250000 sample-point 0.850
          tq 200 prop-seg 8 phase-seg1 8 phase-seg2 3 sjw 1
          mcp251x: tseg1 3..16 tseg2 2..8 sjw 1..4 brp 1..64 brp-inc 1
          clock 10000000
          re-started bus-errors arbit-lost error-warn error-pass bus-off
          0          0          0          0          0          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    RX: bytes  packets  errors  dropped overrun mcast
    0          0        0       0       0       0
    TX: bytes  packets  errors  dropped carrier collsns
    0          0        157     157     0       0
What could be the problem?or, Is there a recommended debug method?
BR
Please refer to Jetson nano and mcp2515 can module - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums to see if can help.
Hi, kayccc,
Thanks for yuour reply.
This just leads to the problem I encountered before.
I compiled the jetson-mcp251x.dtbo file according to this method and copied it to the /boot directory,.
Then deleted /boot/tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo and /boot/tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo
But the MCP251x CAN Controllerdtbo file cannot be displayed when running jetson-io.py.
My software version is Jetpack 4.6.1 , hardware is jetson nano b01 4GB .
Here are some terminal logs:
# ll /boot/tegra210-p3448-0000-p3449-0000-a0*-mcp251x.dtbo*
-rw-r--r-- 1 root root 3.3K 2月  20 01:05 tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo.bak
-rw-r--r-- 1 root root 3.4K 2月  20 01:05 tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo.bak
# ll /boot/jetson*
-rw-r--r-- 1 root root 3.2K 3月  28 10:44 jetson-mcp251x.dtbo
# sudo /opt/nvidia/jetson-io/config-by-hardware.py -l
<Jetson.board.Board object at 0x7f876ad278>
Header 1 [default]: Jetson 40pin Header
  Available hardware modules:
  1. Adafruit SPH0645LM4H
  2. Adafruit UDA1334A
  3. FE-PI Audio V1 and Z V2
  4. ReSpeaker 4 Mic Array
  5. ReSpeaker 4 Mic Linear Array
Header 2: Jetson Nano CSI Connector
  1. Camera IMX219 Dual
  2. Camera IMX477 Dual
  3. Camera IMX477-A and IMX219-B
Header 3: Jetson M.2 Key E Slot
  No hardware configurations found!
BR.
I solved the problem of not displaying “MCP251X CAN Controller” by /opt/nvidia/jetson-io/config-by-hardware.py -l command.
The file “jetson-mcp251x.dts” form the topic (Jetson nano and mcp2515 can module - #289 by michael.sanne) need to add jetson-header-name = "Jetson 40pin Header";
like this :
        overlay-name = "MCP251x CAN Controller";
        jetson-header-name = "Jetson 40pin Header";     # Add this line to jetson-mcp251x.dts
        compatible = "nvidia,p3449-0000-b00+p3448-0000-b00\0nvidia,p3449-0000-a02+p3448-0000-a02";
I think Jetpack has upgraded , some code in the jetson-mcp251x.dts file from topic Jetson nano and mcp2515 can module - #289 by michael.sanne may no longer be available
I have fixed some error from the jetson-mcp251x.dts
# original : pinctrl-0 = <&hdr40_pinmux>;
pinctrl-0 = <&jetson_io_pinmux>;
# original : hdr40_pinmux: header-40pin-pinmux {
jetson_io_pinmux: exp-header-pinmux {
# original : pin19 {
hdr40-pin19 {
# others :
# original : pinxx {
hdr40-pinxx {
Here is my jetson-mcp251x.dts file. It can work well.
// SPDX-License-Identifier: GPL-2.0-only
 * Jetson Device-tree overlay for
 *   MCP2515
 * Copyright (c) 2020 Seeed Technology Co,Ltd - https://www.seeed.cc.
 * All rights reserved.
/dts-v1/;
/plugin/;
#include <dt-bindings/pinctrl/pinctrl-tegra.h>
#include <dt-bindings/gpio/tegra-gpio.h>
   	fragment@0 {
		target-path = "/";
		__overlay__ {
			clocks {
				can_clock: can_clock {
					compatible = "fixed-clock";
					#clock-cells = <0>;
					clock-frequency = <16000000>;
					clock-accuracy = <100>;
	fragment@1 {
		target = <&spi0>;
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <0>;
			spi@0 {
				status = "okay";
				compatible = "microchip,mcp2515";
				reg = <0x0>;
				spi-max-frequency = <10000000>;
				nvidia,enable-hw-based-cs;
				nvidia,rx-clk-tap-delay = <0x7>;
				clocks = <&can_clock>;
				interrupt-parent = <&gpio>;
				interrupts = <TEGRA_GPIO(Z, 0) 0x1>;
				controller-data {
					nvidia,cs-setup-clk-count = <0x1e>;
					nvidia,cs-hold-clk-count = <0x1e>;
					nvidia,rx-clk-tap-delay = <0x1f>;
					nvidia,tx-clk-tap-delay = <0x0>;
			spi@1 {
				status = "disabled";
	fragment@2 {
		target = <&spi1>;
		__overlay__ {
			#size-cells = <0>;
			spi@0 {
			spi@1 {
				status = "okay";
				reg = <0x0>;
				interrupts = <TEGRA_GPIO(V, 0) 0x1>;
				controller-data {
	fragment@3 {
		target = <&pinmux>;
		__overlay__ {
			pinctrl-names = "default";
				hdr40-pin19 {
					nvidia,pins = "spi1_mosi_pc0";
					nvidia,function = "spi1";
					nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
					nvidia,tristate = <TEGRA_PIN_DISABLE>;
					nvidia,enable-input = <TEGRA_PIN_ENABLE>;
				hdr40-pin21 {
					nvidia,pins = "spi1_miso_pc1";
				hdr40-pin23 {
					nvidia,pins = "spi1_sck_pc2";
				hdr40-pin24 {
					nvidia,pins = "spi1_cs0_pc3";
					nvidia,pull = <TEGRA_PIN_PULL_UP>;
				hdr40-pin37 {
					nvidia,pins = "spi2_mosi_pb4";
					nvidia,function = "spi2";
				hdr40-pin22 {
					nvidia,pins = "spi2_miso_pb5";
				hdr40-pin13 {
					nvidia,pins = "spi2_sck_pb6";
				hdr40-pin18 {
					nvidia,pins = "spi2_cs0_pb7";
Hi, kayccc
I have use usb_vbus_en0_pcc4 as interrupt pin of mcp2515 , here is part of my dts.
fragment@1 {
		target = <&spi0>;
		__overlay__ {
			#size-cells = <0>;
			spi@0 {
				status = "okay";
				reg = <0x0>;
				interrupts = <TEGRA_GPIO(CC, 4) 0x1>;
				controller-data {
			spi@1 {
The result of dmesg on system booting:
# sudo dmesg  | grep mcp
[    4.758626] mcp251x: loading out-of-tree module taints kernel.
[    5.777759] mcp251x spi0.0: MCP251x didn't enter in conf mode after reset
[    5.799715] mcp251x spi0.0: Probe failed, err=16
[    5.806688] mcp251x: probe of spi0.0 failed with error -16
I think maybe the interrupt config is error. How should I write the source about usb_vbus_en0_pcc4 as interrupt pin of mcp2515?
BR
Check if this helps.
